Question about Technics SL-1200MK2 Turntable
Tech 1200 mk2 - really bad buzzing, VERY low sound from record
I bought this deck cheap, it had really bad buzzing (i already replaced the RCA's, the ground...i also had to replace the spindle) i've tried new cartrides, different channels on my mixer(every other deck i try it works great). I'm at a bit of a loss here, I was just wondering if there is a good trouble shooting manual around for these. I don't want to get into replacing the tone arm or something if thats not the problem. I've also tried different power outlets. Everything is pointing towards the deck, but i'm not too sure what is wrong. Any of you have any ideas?
cheers!!
tim
  • timgkelly Mar 05, 2009
    i used my ohm meter and checked continuity from the wires on the headshell to the ends of the RCA's. they all check out. I've tried each one to ground and none are shorted to ground. Is it possible another device in the deck is causing this? perhaps a bad motor ground?
If you've had it open to replace the RCAs you're obviously alright with a screw driver. with some concentration the arm is not that hard to remove and reassemble etc.You might as well try to look at the state of the wiring in the one you already have, if you are going to consider replacing it. You have to pull out the old one anyway if you are going to replace it, and once it is out its not hard at all to unscrew the metal s part of the tonearm from the plastic part at the gimbal and then have a look at the state of the black earth wire screw connection. But before you go to all the trouble, check the state of the bearings in the gimball - if some idiot has overtightened them then you may be in some trouble because they are easily damaged that way. just have a careful wriggle to see if there is any play. beyond that, if the arm has really been abused then the silver plastic at the gimball can be cracked, but that maybe hard to see until you remove it. If all that is ok, then There is nothing apart from wiring that can be an issue here - and that is user servicable - corrosion at the earth screw connection in the arm, issues with the connections to the little circuit board where the wiring from the arm attatches to the rcas etc. You have very little to loose in trying to fix what you already have.
Posted on Mar 09, 2009
  • 515 Answers
Well, if you already replaced the RCA cables, the only other issue will be either your tonearm, or your cartridge.
If I was to guess, I would say you have a bad tonearm. Only because you've done everything else, and the issue still persists.
You will have to replace the tonearm, as there are no user serviceable parts for the tonearm. There is very thin ground wire that comes from the tonearm, which is inside the tube, but to get to this is extremely difficult, and not worth the time and effort. It's easier to replace.
TECHNICS TONEARM
Good Luck!
- OPTiC
Technics Repair Videos
Technics DJ Repair
DJ Equipment Sales
Technics Parts
Posted on Mar 04, 2009
  • TERMiNAL OPTiC
    TERMiNAL OPTiC Mar 05, 2009
    Continuity only checks for a connection from 1 point to another. It will not detect interference. For that you'll need a oscilloscope. Trust me when I tell you it's the tonearm. I work on an average of 8-10 Technics 1200s/wk here @ the shop, for the past 15 years, and I am the only Authorized Technics Service Technician left in the U.S., so I know what I am talking about.
    If you are certain that the soldering work done on the RCA cables is correct, and you've ruled out the cartridge/stylus, there is nothing left but the tonearm.
    - OPTiC
    Technics DJ Repair
    DJ Equipment Sales
    Technics Parts
I HAVE JUST BOUGHT TWIN CASSETTE DECK AIWA AD-WX727 ON EBAY AND TRYING TO WORK IT. BOTH CASSETTE PLAYERS ARE WORKING O.K BUT WILL NOT RECORD CAN YOU HELP. I HAVE FOLLOWED THE MANUAL BUT NO JOY.
It is often a bad idea to buy dual cassette type decks. They never work very well except for one unit I have seen which was the Sony ES model. It was not cheap at $1200 a unit. You might get it to work but the performance of these is poor even when new. Avoid dual cassette deck at all costs.
Jul 01, 2016 | Audio Players & Recorders
My record players sound quality is really low and idk what the problem is. The vinyls aren't dusty and it used to be so much louder so can you please help?
Unless you are connecting to a different amplifier and the sound is low on that, the likely cause is the pre-amp of the amplifier. Since the record deck uses a separate pre-amp on your amp it won't affect the other functions. You can confirm that it's gone by removing the wires from the cartridge. With the amp on and deck still connected touch the wires with your finger. If there is only a small buzz from two of the wires, this will confirm the pre-amp is the problem. However if you hear a loud buzz from them, the cartridge is faulty.
If you have knowledge of electronics you can trace the pre-amp inside the amp. It's probably a small IC that has gone, which if you can get the replacement part should cure the problem.
If you are connecting the deck to another amp, then that amp might not have a Magnetic Cartridge Pre-amp built in, but you can buy these separately.
Mar 17, 2015 | Audio Players & Recorders
Hi there, i just bought 2 Technics mkii
well" for a start, they need to go into a phono socket, this amplifies them.
i take it you bought 2 decks with the intentions of mixing, so you gonna need a mixer.
MIXER & DECKS SET UP:
1.decks into phono channels 1&2
2. black GROUND wires, go to GND screw on back of mixer
3. RCA master / booth Outputs on mixer to AUX / LINE-IN on amp.(not phono)
Oct 09, 2013 | Technics SL-1210 Turntable
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Sep 26, 2012 | Technics SL-1200 Turntable
Deck produces no sound at all, amp and pre amp is fine, hum through amp when wires to the cartridge are pressed, even touching the stylus makes a slight sound but when put on the record no sound what so...
Bad cartridge if you get a buzz from touching the wires to it once they are removed. That shows that the system is working but the output from the cartridge is rubbish!
Jul 30, 2011 | Technics SL-1210 Turntable
My Toshiba RD-85DTSB has recently developed a buzzing both during playback of programmes recorded before the problem developed, or just when you are watching the TV through the DVD recorder. It is not the...
Hello
Ensure that ur AV cord is plugged in properly into the Audio Video outlet on the back of your tv.If this does not solve the problem then the buzzing sound u hear is that of theFBT-the Highvoltage Flyback Transformer 100% already dead also other possible components on the Highvoltage Deflection circuitries are dead too.
The TV must be troubleshoot by a qualify tv Tech.This tv is not going to be cheap to troubleshoot and repair by a Tv tech.The FBT alone replacement alone,will cost u like $200 already
Jun 28, 2011 | Televison & Video
Technics 1200, no sound out right speaker
And it will be. I can almost steak my life on it. Easy to replace. Most djs had to already. Most off us went to Radio Shack and bought the 6 foot gold RCA's and cut them in half for both decks. Its not that hard to do. Any problems message me.
Oct 29, 2009 | Technics SL-1200MK2 Turntable
New RCAS on Technics 1200 Getting a Loud Buzzing Noise
It is not suggested that you remove the ground cable. Performing the mod for the ground by soldering a bridge on the circuit board doesn't really do anything either than remove that buzz/ground hum. You've essentially removed the wire that grounds the turntable cabinet to the earth. The buzz is gone, but now your turntable is no longer grounded properly.
I would suggest replacing the ground cable to it's original state, then attach the Monster cables.
If this does not work, then either there is an issue with the soldering to the board, or the board itself might be damaged. You might want to look at the trace paths to make sure none are lifted, or damaged in any way on the board. Another issue might be faulty tonearm wires or not properly soldered wires.
FYI, monster cables are not good for this purpose. I would suggest the following cables:
MOGAMI RCA CABLES
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 20, 2009 | Technics SL-1200MK2 Turntable
No sound out of deck
If you've already replaced the RCA /Phono cables, then the only other item that would cause this kind of problem is your tonearm, and it will need to be replaced.
- OPTiC
DJ Turntable Repair Expert
A DJ Pro Audio Co.
Dec 05, 2008 | Technics SL-1200 Turntable
I have a technics 1200 mk2 turntable. It turns on properly, and appears to work, but when I place the needle on the record, I get nothing through the speakers. I don't know if the connection is being...
Turntable signal problems are difficult to locate because of the extremely low signal levels. Are you sure that you have the output of the turntable connected to a Phono input? If connected to a standard AUX or Tape input, you won't hear anything. Check for signal by turning on the unit and touching lightly the needle. You should hear a scratching sound. If not, start with a new needle.
Keep us posted.
Dan
Aug 14, 2008 | Technics Audio Players & Recorders
Technics SL-1200MK2 Turntable Logo
590 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
