Question about Honda Pressure Washer PSI 3000
I have belt driven ici 2600prospray pressure washer that wears belts out very fast and they break
  • kaburton Mar 03, 2009
    i have tried adjusting tensions different belts my pullies are in line after about 5 hrs of use the belt breaks i thought it might have something to do with when i realse the handle the by pass is not working and pressure builds in pump and pump pulley doesnot turn wearing the builts just a thought i know there is a valve that realses water out of pump when it circlelates and gets to hot if i new how it was supposed to work i could prob get a head start there is alot of black bealt dust when i take cover off is pump pully not turning while engine pully is always turning something is causing builts to eat up i have replaced all seals in pump and when it works it works great i wish i understood the bypass better
  • Dean
    Dean May 11, 2010
    Can you adjust belt tension on the pressure washer?
    Sounds like the belts may be tensioned too tight. If you can release the tension a little you should find they last longer. Of course, they should not be tensioned so loose that they slip.
  • 174 Answers
You have to find the bypass valve and lube it with water proof grease and be sure the o-rings are in good shape
Posted on Jun 16, 2009
How to fix broken washer
loose clutch assembly or loose worn belt if belt driven
Mar 28, 2015 | Roper Washing Machines
May i wash blankets in th washing machine
Wahing blankets in the washer depends on the washer and it depends on th blanket. If its a thin blank or small quilt than usually yes. If you have a comforter than I recommend taking to laundry mat. Top load washer is designed for between 18-28lbs of laundry. It may not feel that heavy but soak it with water than feel how heavy. If its a direct drive washer and you put too much weight in it the couple will break. If its belt driven you can break the belt or wear out the moter. If its a front load washer they are designed to hold more but The motor can only handle so much weight or it burns out. The belt could also break if its too much weight. The simplest way of determining it is if the blanket does not soak up alot of water ( thin blanket ) than its ok If blanket soaks up alot of water (comforter) take to laundry mat. I hope this helped. Anymore questions please comment me back.
Jul 30, 2011 | Kitchen Ranges
Brushes don't move. vacuum motor works
The brushes on the roller are driven by a wide, short rubber belt. These belts get old, worn, overheated, and break periodically.
It should be a fairly simple matter to unscrew & remove the plate, revealing the belt and roller assembly. You can get a replacement belt at Sears or nearly any vacuum shop.
While replacing the belt, it would be a good idea to take scissors or a knife (careful!) and remove the hair & other material that's wound around your roller. One thing that can cause a belt to break is when you're vacuuming & accidently pick up a string, a shoelace, a piece of cord... you know how fast that gets wound around the brush roller and locks it up? At that point, the belt is still trying to rotate the roller (which won't rotate)... and within seconds, the belt will get extremely hot. This can cause it to break, or reduce its life significantly.
This should be an easy fix, requiring nothing more than a replacement belt and a screwdriver. Good luck!
Mar 03, 2011 | Kenmore 31913 Progressive Direct Drive...
Have a 11hp power washer pump not sucking water, how do i fix ?
Hey there...
Is the washer a direct drive or belt drive unit? If it is a direct drive ( the pump bolts directly to the engine) then the pump needs to be force fed the water, either by city pressure or a transfer pump. If it is belt driven, the lower rpm's should pull water, so more detail would be needed...
Feb 01, 2010 | Honda 8 HP Engine
I have a Kenmore Elite 3 Speed washer, Model number 110-22982-100. It wont spin, but the pump is working. Do you know if this is belt driven or if it has a coupler? I need repair diagrams if you have...
Your washer is a direct-drive model which means it uses a motor coupling instead of a drive belt. The symptoms your washer exhibits is typical of a motor coupling gone bad.
If the washer will fill and drain, but won't agitate or spin, the most common cause is a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. This configuration is known as a "direct-drive" system. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased for about $10 - $15. The following websites are great sources for replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If you have any questions about this repair, or if you require additional assistance, pease post back and let me know. I hope this helps you.
Jan 29, 2010 | Kenmore 24032\24036 Top Load Washer
The drum bangs against the washer during the fast spin. Pieces of plastic broke off. What could be the problem.
If your drum is belt driven, it may need adjustment. It should run straight from the motor wheel, directly around the barrel circumference. Chec for excessive wear. GOOD LUCK.....ABORN
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
My Roper washer Model# RAX4232JQ0 won't agitate or spin. Is it shaft driven or with a belt. I've tried everything. Even checked the switch for the lid.
The washer uses a direct drive system. What this means is that it uses a motor coupling in place of the drive belt. It sounds like to me that you have a broken motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you have questions, or require additional assistance, please let me know. I hope this has been helpful to you. NOTE: Roper is manufactured by Whirpool, so the instructions I provided will apply to your washer.
Jul 10, 2009 | Roper RAS6233KQ Top Load Washer
Kenmore 70 series washer does not agitate or spin and has loud clicking noise coming from area of either motor or transmission also found what looks like a belt broken laying on top of transmission but...
The problem you have sounds like a broken motor coupling. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The piece that you found could be part of the rubber bushing that sheared off. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupling can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
May 04, 2009 | Kenmore 15864/15862 Top Load Washer
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Belt Keeps Breaking
Maybe it cause a too tied belt.
Oct 03, 2006 | Kenmore 98702 Stacked Washer/Dryer
Honda Pressure Washer PSI 3000 Logo
169 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
