Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
I need a picture diagram of how to wire up two different baseboard heaters with seperate thermoststs on the same wire in the breaker box.Never done this before and I don't want to burn down my home.
    Problem Solver:
  • 12 Answers
It can not be done. if you want 2 seperate thermastats servicing 2 seperate baseboards, then what you will have is 2 seperate circuits, one for each thermastat and baseboard. If you are talking about only at the breaker box, then that can be done.... assuming that the total amperage does not exceed the wire rating or the breaker..... if that is the case you will have to install a junction box and split the wiring BEFORE it goes to each seperate heating unit.
Posted on Sep 29, 2009
wbwill
  • 68 Answers
SOURCE: Baseboard heater connect
A longer explanation is needed on these questions or I am not finding the whole question. I volunteer on allexperts.com and it is much clearer what help someone needs. Write to me at wbwill@sbcglobal.net or through allexperts.com and I will help you wire this. A baseboard heater should not be that complicated to wire up.
It should wire up like a 240 volt dryer, with the proper wire size and proper double pole breaker.
The heater will have the amperage and voltage rating on the unit, take that information and then measure how far from the breaker box you will be, to a hardware store. They can tell you and sell you the wire and breaker. aLSO TELL THEM WHAT BRAND BREAKER BOX YOU HAVE, it is written on the box somewhere.
The wire size will determined by the amps and the distance, the breaker will be sized to protect the wire, there will be either 2 hots and a neutral, or 2 hots and a neutral and a ground, older 240 devices were all three wire, now days most are four, the hardware store can tell you. You might have a red, black and white and green wire. Red would be one hot lead, black another hot, white neutral, green ground. The device will have either have the wires in a connection box or lugs labeled for hot, hot, neutral and ground. One way you wire nut the wire to each, the other you place under the lugs, at the breaker the hots are both ran through their own breaker, called a double breaker, the white will go on the neutral buss, and the green ground will go to the ground bar.
Hope this helps, it should not be a difficult job. or write me at wbwill@sbcglobal.net
Posted on Nov 15, 2008
SOURCE: baseboard heater
Make sure BOTH fuses on each heater circuit test ok -- they are no doubt 220V -- hence 2 fuses
Posted on Nov 08, 2007
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
  • 252 Answers
SOURCE: I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
nothing wrong w/ 10/3 @ 20A. use the red and black and don't use the white. dosent matter which is which (blk and red).
Posted on Mar 22, 2009
appman67
  • 33 Answers
SOURCE: Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
Posted on May 03, 2009
Need a wiring diagram to hook up a wall thermastat from breaker box to the thermastat to the baseboard heater
Please view the videos below how to install...Good Luck ...Jim
VERY IMPORTANT TO DETERMINE YOUR VOLTAGE TO YOUR HEATER. HEATERS ARE EITHER 120 OR 240 VOLT!
BE SURE POWER IS OFF!
This video will show you how to install the wire and breaker for a 230 volt soursehttp://www.youtube.com/watch?annotation_id=annotation_582499&feature=iv&v=LXQoOWbU3DE
These two video will show you how to install the heater and thermostat.
http://www.youtube.com/watch?v=dJ459OxxM2Y&feature=related
http://www.youtube.com/watch?feature=player_detailpage&v=ze6xqM38tTY
Feb 17, 2011 | Honeywell (CT62B1015) Baseboard Heater
Bought a Fahrenheat 5' baseboard heater and a single pole thermostat to replace an old heater. What's the difference between a single and double pole thermostat? Which should I use? I have a 240v line...
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier. http://www.marleymep.com/en/multimedia-library/pdf/fahrenheat-pdf/products/f2500-series/F2500wiring.pdf
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
Turned t stat off baseboard is still hot and has been for 2 days
Turn off the power to the baseboard at the breaker box. Remove the cover on the thermostat, check that there is no power going to it, remove the thermostat from the wall and bring it to yor local electrical supply house for a replacement. Most liokely the contacts are welded closed. Make a small diagram of the wiring or take a picture to be able to put the new one on without confusion.
Oct 18, 2009 | Honeywell Programmable Thermostat Heater
May 03, 2009 | QMark FBE15002 electric baseboard heater...
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Mar 22, 2009 | Fahrenheat Electric Hydronic Baseboard...
What size breaker do I need for a 240 volt electric clothes dryer
check on the wiring diagram. You may be looking at 2-15 amp or 2-20 amp breakers.
Nov 12, 2008 | Fahrenheat Electric Convector Baseboard...
Please i need help with 240v wiring to heater
i have the answer, i just did mine...though u already have your answer since this post was published a while back ago...if not write me back...
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
I have a fahrenheat F2548 baseboard heater, there were not any wiriing diagrams or installation instructions in the box where can I find the wiring diagram,
Aug 04, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
523 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
