Question about Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover
New Noritz won't fire up-No OP
Brand new Model N-069M-1 with remote RC-7646M-2 won't fire
S/N 2006.02-022227
2 Hot water faucets wide open ... lots of water flow
Natural Gas supply on, 120 VAC supply verified (plumber and electrician pointing finger at each other, but no one knows how to trouble shoot
Symptoms - No OP, no pilot lite
  • 523 Answers
Check this page could help you.
http://www.noritz.com/professionals/support/faqs/
Posted on Mar 02, 2009
N-069m pulsating when hot water is turned off.
Do you have a well our on city water? Check in coming water pressure make sure it is not over 60psi
Sep 14, 2014 | Noritz 6.9 Gallon Residential Tankless...
My Noritz remote controller RC 7646M-2 shows a yellow/orange "Priority" light. Is this normal, or is it telling me something?
There is something wrong with your remote control. Almost all remote controls emit infrared rays, and is invisible to human eye.
Jan 21, 2013 | Televison & Video
Tank will not turn on when sink hot water is turned on
Do other faucets in the house work ok? if so the kitchen faucet may not be creating enough water flow to trigger the noritz. The Noritz have a flow meter inside of them (depending on the year they where made, older units require 3/4 GPM, newer models require 1/2 GPM). If the kitchen faucet is not turning on the hot water, you can check the angle stop and make sure it is open all the way. Also check the aerator on the faucet to make sure it is not plugged and restricting the flow.
Jan 02, 2011 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Water Heater Keeps Going Off
is there a check valvle on hot water side of heater,a flow restriction of some sort, water pressure to the heater, a filter in the line, line pressure in the heater kicks out burner, when you turn on the water, line pressure drops, heater comes on, when you turn on water in other part of house, heater should not fire, so there has to be a check valve somewhere,in heater?
Jan 24, 2010 | Noritz 6.9 Gallon Residential Tankless...
Noritz remote controller "RC-7646m-1" seems to need to be restarted several times throughout the day. Usually what happens is out of nowhere, it'll just lose it's temperature reading (at usually 140), and...
You are actually getting a 90 error code. This error code occurs if the unit is dirty and overheating. I'd recommend contacting a servicer to clean your heater with compressed air. They'll need to remove the fan motor and manifold plate to fully clean the burner chamber and heat exchanger.
Jan 21, 2010 | Noritz 6.3 Gallon Residential Tankless...
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover Logo
104 people viewed this question
Top Noritz Plumbing Experts
Kyocera HP Expert
Paul Carew
Muzammil Razzaq
Muzammil Razzaq
Are you a Noritz Plumbing Expert? Answer questions, earn points and help others
