Question about Maytag Performa PAV3200
Leaves clothes very wet and soapy
Leaves my clothes very very wet and often there is soap in them, any ideas?
    Scholar:
  • 106 Answers
Your pump is clogged. This stops the machine from spinning out or rinsing. You have to locate the thing, (comes under the tub, lower end of big black tube) take the clamps out to clear the muck. Refit as you have dismantled. First try to drain out the water completely or you will flood your room.
Posted on Mar 03, 2009
Tv acts like remote buttons press and held or does not respond
Sometimes the buttons stick. Use a very wet soapy cloth and wet all the buttons. Leave for 2 minutes. Turn the remote upside down so that the buttons are facing the ground and use the wet cloth to wet and press all the buttons. We a dry cloth to clean them again. Turn it over and test each button moves freely.
Jul 14, 2017 | Televison & Video
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Tip
Laptop or Monitor Cleaning
LCD and plasma screens have a anti-glare coating or anti-reflective coating. This is so any bright light doesn't reflect and wash out the picture. It does help but it also makes cleaning the screen a bit of a problem.
As this is a coating on glass it is actually possible to clean t off by using the wrong cleaner. There are great glass cleaners out there but most are chemically based and too aggressive. In other words they attack the coating.
So what do you use? Paper towels, a drop of dish washing or liquid soap and water. And you need to use a bit of a technique or you will see smears or smudges on the screen.
You need to get two sheets of paper towels. One is your dry wipe. Wet one with water. Then add a drop of liquid soap or detergent. Give it a couple of gentle squeezes to distribute the soap. Then give it a bit harder one to get rid of excess water. Depending on the coating you may want a second piece that has only water and just damp not wet.
Now we clean the screen. First take the soapy towel and wipe down the screen getting it wet. You don't want running water just enough to wet the screen. If you have the soap right you will just see the odd bubble. Once you have the screen wet, wait about 30 seconds and now scrub it using the soapy towel with a circular motion. If there is anything on the screen it should come off. If something is stubborn just keep scrubbing it or use a fingernail to scratch it off and wipe with the soapy after.
Now we need to get the soap off. If the screen dries and has streaks you may need to use the wet un-soaped towel to wipe/rinse of the soap before drying. To dry the screen we want to use the dry towel and use large circular motions. Go over it once and turn it over so the dry side is being used. Keep using those big round motions and at the same time ease up of how hard you push the towel. The idea is to have little pressure on the towel as you finish. That's the trick to getting it streak free.
This takes a minute to do but lets you safely clean your display without damaging the coatings. It also works on any glass surface.
on Jul 07, 2010 | Computers & Internet
Tip
How to clean your screen (TV-Laptop-Monitor)
on Apr 16, 2010 | Televison & Video
Clothes come out musty
I would put in some bleach and clothes that can handle it without damage and run a wash cycle. Leave the door open when you are done using the machine, or at least un-latched. There are commercial products, but bleach will do the same thing. You have stuff growing on the gizzards inside the drum, and bleach will likely kill them. They like dark & humid places.. guess what... that's your washer with the door kept latched.
Aug 15, 2014 | Kenmore Elite HE5t Washer
Washing machine leaves clothes wet and soapy
most lightly the draining system is not working or not working effective enough,take the drain hose out at back lower till it is below bottom of the drum ,if water freely runs out ,there's a possible restriction in the pump impellor or pump has failed,if water doesnt flow freely out at a low level there is a blockage in pipe work
May 07, 2009 | Amana Washing Machines
Clothes come out wet and soapy
check your manual for cleanout procedure for pump assy. the lower panel acess left side, perahps theres debris in pump no t alllowing proper drainage of water
Mar 23, 2008 | LG WM1812C Front Load Washer
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
