Question about XO Vision XOD1742BT Car DVD Player
Can I hook up an amplifer to this unit?
I want to hook up an amp, does this unit have that option? I wanted to know before I purchased it.
  • 905 Answers
Yes you can hook an amp to this unit!
it has two audio output jacks for connection to an amp. and you can see that in the specifications at the bottom of this page http://www.fixya.com/support/p920224-xo_vision_xod1742bt_car_dvd_player
Posted on Mar 02, 2009
  • jason Mar 02, 2009
    here is the specs.
    Specifications
    Product MPN
    MPNXOD1742BT
    Key Features
    Supported Audio Formats Audio CD, MP3, WMA, MP4
    Supported Video Formats Video CD (VCD), DVD, MPEG-4, DivX, SVCD, AVI
    Number of Audio Channels 4 Channels
    Included Units In-Dash Player, In-Dash Monitor, Flip-Down Monitor, Amplifier
    Supported Media Types DVD Video, VCD, SVCD, DVD-R, DVD-RW, DVD+R, DVD+RW, CD (Audio), CD-R, CD-RW
    Control
    Remote ControlWith Remote Control
    Changer Control CapabilitiesCD
    Tuner
    Radio Tuner AM, FM
    Monitor
    Aspect Ratio16:9
    Monitor Size7 Inch
    Touch PanelWith Touch Panel
    Motorized MonitorMotorized Monitor
    Text DisplayCD Text, ID3Tag
    Speaker Output
    Power Per Channel80 Watts x 4 Channels
    Connectors
    Pre-Amp Outputs4 Channels
    Input Connectors Audio Aux x 1, Camera x 1, USB x 1
    Output Connectors RCA (2 Audio Channels) x 2
    Player Dimensions
    Depth6.9 in
    Height3.9 in
    Width7.5 in
    Weight8.8 lb
    Mounting Standard DIN
I have a 800 watt ma audio i was loosening speaker clamps when one my kids turned tunes on and i touched amp with wrench causing a spark immediately shut car down but got a burnt smell. Protect light...
Afraid you may have blown an amplifier. If you have a AC voltmeter, audio generator and schematic, you can feed audio signal into unit and track the signal on both channels during amplification stages.and locate the spot where the amplification stops or one channel deviates from the other. And there is your culprit.
Sep 05, 2017 | MA Audio Car Audio & Video
What do i hook plug from marshall dfx foot pedal to amp and guitar
If you're asking if the foot pedal goes between the guitar and the amp or straight in to the amp then it's the latter.
Dec 14, 2013 | Marshall Amplification Music
Can i connect 2 (2x12) cabs rated @ 4ohms each to my avt50 head?
No, the ATV50 head is rated for 4 ohms total. Using both 4 ohm cabinets at once will fry your amp. Your only option would be to rewire your cabs internally to 16 ohms each by connecting the speakers in parallel, but that would cut your amp's power in half.
Feb 12, 2013 | Marshall Amplification Music
Do I have to do anything special to charge my battery on my 1989 ford aerostar van? Still positive terminal to positive clamp and negative to negative? How do you recharge battery with Dual Range Battery...
The cap can be purchased at the auto parts store
Your best to use the auto range on the charger
After you hook it up, switch to the range with the
lowest amp reading & leave it on for 6 hours
Has to be on 12 volts, if that is an option
Jun 29, 2011 | 1989 Ford Aerostar Cargo
I have a Pioneer DEH-p4800mp and I connected to amplifier when i stop the cd player does not stop the amplificator
Question? have you also connected the Remote cable from the CD player to the Amp? or have you only got 12v & gnd hooked into the amp? if so then the amp will be on all the time. the remote goes from the CD player to the amp, usually a blue cable from the back of the head unit.
Jan 12, 2010 | Pioneer DEH-P4800MP CD Player
2 RCA's coming from amp into radio's single subwoofer output RCA?
You can either hook up the left channel only or buy a splitter that separates one input into two outputs.
Oct 03, 2009 | Pioneer DEH-P690UB CD Player
Amp goes into protection
make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
Not sure whats wrong with my LANZAR MXA242 AMPLIFER. Please help!
did you check the fuses on the side of the amp? put voltage meter on b+ should read 13v, take it to service center to have checked out, may have some prblems inside
May 03, 2009 | Lanzar MXA242 Car Audio Amplifier
Problems Overload Protection Being Invoked - Parasound HCA-2003
You may want to get an Ohm meter and check between the outputs of the amp yourself. 0 ohms means a short somewhere.
You should also check to se when you're hooking the speaker wires in that they're not frayed and touching hot to ground or hot to the amp casing. hope that helps!
Nov 18, 2008 | Audio Players & Recorders
Car amplifers,,,,kicker amp's RCA jacks!
You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
-Andrew Hawkins
Mar 28, 2008 | Audio Players & Recorders
XO Vision XOD1742BT Car DVD Player Logo
204 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
