Question about Kyocera Mita FS 1000+N Laser Printer
I have hp 1018 but i can not print any think -the
I have hp 1018 but i can not print any think -the orange light is turn on .note when i open the cartridge cover the orange light is not turn one . thanks
    Genius:
  • 2,120 Answers
Out of toner.
Posted on Mar 04, 2009
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
Black line going down side of paper from HP laserjet 1018
Roller Drum Problem in the cartridge.
If you are printing bulky document it may damage the roller drum causing dark line starting for both left and right paper. It will get bigger once it span of time.
Or if you are refilling the toner of the catridge, the waste compartment is full and requires to remove the waste tones inside the cartridge.
Or the worst thing is the the FUSER FILM ROLLER (orange plastic roller inside the printer is torn or burn because of heat or bulky printing.
Dec 08, 2010 | HP Hewlett Packard LaserJet 1018 Printer
Hp laserjet 1018 - how do I find out how many pages have been printed in the printer's lifetime?
Hold the 2 buttons on the operation panel down for a few seconds until the light begin to flash. Then release them. This will print a configuration page which will contail a line with the total pages printed information.
Jan 10, 2010 | HP LaserJet 1018 Printer
Getting error message 1018 with the print spool for my HP 1018 printer. HP support will not correct the problem since the print spool is a Microsoft problem.
please check the below........
1. goto start....>run...>type sevices.msc...>enter....>goto print spooler...>double click over there....>select automaticaly....>click start....>ok
Restart the Print Spooler service. To do this, follow these steps:
o Click Start, click Run, type net stop spooler in the Open box, and then click OK.
o Click Start, click Run, type net start spooler in the Open box, and then click OK.
if its not working please post your full error massage u are getting .or you can send your details to me at anantakumarjena0@gmail.com
Oct 26, 2009 | HP LaserJet 1018 Printer
HP LaserJet 1018: paper will feed, but no content can be printed
just try to print the self test of the hp 1018 printer.self pest is printed directly from the printer not by giving command from the printer. press any one of the button on the printer and hold it till the light blinks.leave the button when light starts blinking .place the paper in the tray.as soon as you leave the button .a self page will be printed..that is self test.if the self test comes out proper that means its your driver software problem.but if self test also has problem then its the clear problem of dust collected on the printer reading lens due to not using it for 2 years.so the printer needs servicing. get it serviced at local printer repair shop .
May 06, 2009 | HP LaserJet 1018 Printer
My HP laserjet 1018 doesn't work
first of all remove the power cable and rmove the usb connection or  parallal connection from the pc. Then conneted the power and usb cable. you need to open the case to remove the printer cartise. and add the cartise. Start your pc. give print command.
Jan 23, 2009 | HP Hewlett Packard LaserJet 1018 Printer
HP Laserjet 1018 won't delete a printing job
to delete the print job.
shut off the printer, disconnect the printer cable to the computer.
go to strat>>printer and faxes.
open the pirnter queue. stop the print job then delete. you may have to restrat the computer.
once the job is deleted, connect the printer cable back to the computer and turn on the printer.
Jan 09, 2009 | HP LaserJet 1018 Printer
Green light is on but doesnt make the normal sounds
The printer needs a good cleaning you need to get it serviced from a professional.
Nov 23, 2008 | HP LaserJet 1018 Printer
How do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
Jun 09, 2008 | HP LaserJet 1018 Printer
Kyocera Mita FS 1000+N Laser Printer Logo
130 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
