Question about GE JVM1850 1000 Watts Microwave Oven
How to remove stirrer cover. GE Spacemaker #HDM1853GL01.
Started arcing yesterday and I can't for the life of me figure out how to remove the stirrer cover located in the ceiling. Since it's plastic, I'm afraid I'm going to break it. There appears to be a button of sorts, but it will not depress. The owner's manual does not address how to remove the cover. Any suggestions?
  • William Miller
    William Miller May 11, 2010
    The button-like part in the front edge of the stirrer cover is a plastic rivet.
    You can use the tip of a thin blade to lift it down (out) so that the stirrer cover can be removed.
    I'm surprised the manual does not cover it!
    What is your full model number?
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
SOURCE: Removal
There are 3 mounting screws that anchor the microwave to the cabinet above it and a bracket on the wall behind it. Once you remove the mounting screws from the top, pull the oven straight out from the front and it will slide off the wall bracket.
Posted on Sep 20, 2008
vitg55
  • 78 Answers
SOURCE: GE Spacemaker appears to be sparking inside/top
1.Needs to remove that disk and clean the grease under it.
2. With sand paper clean dark burn spots.
3. Apply touch paint on open metal spots.
4.Put everything back.
Posted on Dec 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker microwave JVM1851WF001 stirrer motor replacement
Very good.
Posted on Jan 19, 2009
  • 140 Answers
SOURCE: microwave smells of electrical fire
The magnetron inside the microwave is starting to short out to ground. This happens after use there are small minute cracks on the body of the magnetron and those small cracks are big enough for 15,000 volts and up to 30,000 volts to leak through and arc to ground. It is not a small short but a big one. Replace the magnetron before it burns holes inside your microwave. Replacing the magnetron if you can find it locally or through the internet is pretty straightforward. Unplug the microwave and take the cover off about 6 screws. On the same side as the control panel and right behind it you will find the microwave on top. It is held in place with only three to four big screws. It will have about 4 wires with terminals on them that plug into a couple of places one being the large capacitor that stores all the voltage and discharges it through the magnetron. Take the terminals off and I always recommend with some needle nose pliers with insulated handles. There is nothing to unsolder and to solder. Its like replacing the battery in your car or the electronic module. Take care and good luck.
Posted on Jan 22, 2009
I have a new JVM1750 just installed yesterday. There was some arcing, in what looked like underneath, a white circular disc in the ceiling of the internal cavity. Have checked for foil - none inside the...
That is your stirrer cover.
Any arcing there is usually due to grease or food particles, so on a new oven that would be as mystery.
But any time you get arcing under it, it has to be removed and cleaned.
Oct 12, 2011 | GE Spacemaker JVM1750 Microwave Oven
I have a GE Spacemaker microwave JVM1430BD002 There's a circular panel inside on the upper surface that's all greasy around the edges. It has arrows with 'open' close' on it but I can't get it to move. I'm...
That's the stirrer cover. It does need to removed and cleaned, and the stirrer parts above it, too. so that the grease will not eventually cause arcing and damage.
Your owner's manual should cover that. If you've misplaced yours, you can download GE owner's manuals and installation instructions here.
May 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The inside fan cover started peeling and broke, i can't use the oven and need help!
its the fan inside the oven cavity on top, its part # AP3671492 and is a G.E. part# called the Cover,Stirrer Fan still manufactured
Sep 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Lubricant leak from round disk on the inside top of the microwave (piece has open and close written on it).
That would be the stirrer cover, and the leak is probably grease that has gotten into the area above the cover.
The cover, stirrer and exposed area under the cover needs to be cleaned thoroughly to prevent arcing and to allow for proper stirrer of the weaves for even cooking.
You can find handy exploded views and order any needed parts by model number here.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Wont heat food
It could be that the "grinding" noise was actually "arcing" taking place inside the cavity or uder the cover. The magnatron is possibly damaged or the h.v. diode. Should be repaired by qualified repairman
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver 1800 XL - rattling sound
Hi jnflanders,
You've probably solved this by now, but I'll answer just in case. That part is called the stirrer motor. You can replace it yourself, as long as you have an offset phillip's head screwdriver handy.
Before you order the replacement part, figure out if your stirrer is driven by a d-shaped or a square shaft. You can tell by taking off the round plate on the inside top wall of the microwave. GE makes stirrer motors for both d-shaped and square shafts, so you'll have to get the right one. Here's the d-shaped motor that fixed this problem with my microwave: http://www.appliancepartspros.com/part_details.aspx?part_id=2024961.
Apr 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cause of burnt magnetron
GE microwaves have poor magntrons . with that said . something was wrong with the replacement stirrer . the first spark did damage to the magntron ......too bad you dont have the orig stirrer to put back in just to see what happens ..... i think your stuck,we can think anything we want but we cant prove anything and it would cost more trhan a microwave to fight it in court ...... get a new one , but not a GE
Jan 23, 2009 | Microwave Ovens
Suddenly food doesn't heat
I have the same problem and have figured out the following:
Most likely it is the magnetron - common problem for GE's. Replacement part list price is around $180 but you can find on ebay for about $80. Replacement is "doable" but tricky because the oven needs to be removed to replace the part. The GE replacement kit part # for magnetron and stirrer is WB27X10489. Expect a service tec to charge at least $200-$225 to make the repair so complete replacement of microwave might make more sennse...unfortunately.
Aug 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
490 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
