Getting static sounds connecting laptop to tv
I connected my laptop to my tv, and I just bought an audio cable for it, but as soon as I connect it I am getting static sounds? How can I fix this problem?
  • 404 Answers
The connector one of the ends especialy the computer end is shorting with the case. you'll have to inspect the case.
Posted on Mar 02, 2009
My sansui tv has an interuppted sound. How do I fix it
It's all electronics so unless you call the sansui customer care not much can be done. If you have a audio system then connect the audio out from TV to of your sound system. That way you can still hear the TV audio. I hope the audio out of TV still operational!!
Mar 02, 2015 | Sansui Televison & Video
Can I connect my laptop to my TV?
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally. Also we have "Component Video" marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit
on Feb 09, 2010 | Televison & Video
Connect a Cable Box to a Receiver:
1 Gather all your tools, parts and cables together before you start the connection process. Chances are you will need to connect several items at the same time, including your TV, audio system and TV cable receiver. Your cable box manual is likely to include a diagram of how to make the appropriate connections, so it's important that you read it before attempting any links.
2 Connect the output of the cable box to the input of the receiver. If you are connecting an audio system as well, make sure the audio output cables go directly into the receiver and, from there, to the cable box. Avoid direct connections; instead, go through the receiver for all secondary connections.
3 Select the correct jacks for sound and video. A newer model of receiver should offer several options, including analog TV out and DTV out. It should also offer an S-video and a service port. Depending on the type of cable box you use, one or more of the same jacks will be available there, too. When connecting both systems, make sure cables go between similar outputs.
4 Use an S-video connection cable to link your TV with your cable box. S-video connection cables allow you to preserve good quality in both image and audio. Most cable boxes come with S-video connection cables, but you can get them at any electronics store. Once you have them, simply connect both ends to the right output. It'll be easy to identify, because it's usually the only round one available.
5 Plug the TV, cable box and receiver into an electrical outlet to make sure everything is working properly. If you are getting static or interference, you may need to tighten the connections or change the cables.
Sep 03, 2011 | Sony KV-35V65 TV
I just bought a samsung home theater in a box system, model Ht-D5500. And i also have a hd cable box. i was wondering how can i connect my cable box up so that i get audio from the speakers instead of the...
There are two ways of connecting to get cable TV audio from your Home Theater System.
1) If your HD cable box has a digital audio out ( either optical or coaxial ) you can connect this to the Samsung Home Theater Systems digital input. While watching a TV channel scroll through the Samsungs input ( source ) selector till you hear the sound. Remember to mute the TV sound while you are doing this.Most probably it will be the CBL/SAT input or Video AUX.
2) If your HD box does not have digital audio out you can connect the Red & White audio out of the same to your Samsungs Aux or TV or Video audio inputs . Ignore the yellow socket and connect only the Red and White audio inputs.For getting Video through the TV connect the HD box to TV via HDMI cable or connect the Yellow video out to the TV's Yellow video in. I am sure it is already connected .
Mar 21, 2011 | Audio Players & Recorders
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Laptop to TV connection but no audio
what kinda connection did you made?? what kinda cord did you usually works that can get image on TV setting the image card driver ...but the sound bust be connected separately ...if your TV has a input plug for sound...just take a proper cable ...and get signal from the green out of the computer and plug it into the input of the tv ...this way you will have sound comming from the TV speakers and access on the volume with its remote control ...but no matter what kinda plug u used for the connection with the tv will not get eny thing more than image..
so...if your TV doesnt support sound plug in just attach some speachers ...
Jun 14, 2009 | Acer Computers & Internet
I have a Toshiba laptop L305D-S5895 and a Toshiba Hi Def LCD 37AV502U tv. I got an audio cable, that I have in the headphone spot & the original cable needed to connect the pc to the tv. I am getting all...
Which cables have you attached to your TV (the video and audio)?
Does the TV has left & right audio inputs (RCA connectors)?
When you attach a headphone to the laptop, the speakers on the laptop switch off and the sounds divert to the headphones. Try and connect a cable (stereo) from the headphone outlet on the laptop to the audio stereo inputs on the TV.
Mar 28, 2009 | Toshiba Satellite L305D-S5895 Notebook
VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
Mar 16, 2009 | HP Pavilion dv2000t Notebook
Sound Problems with HD TV
get the digital audio optical cable and connect the to the tv- got it working tonight
Oct 07, 2007 | Samsung HT-Q100 System
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
