Question about Electrolux EIGD55H Dryer
Noisy electrolux dryer
Only 2 months old and it has started making a bad metalic scraping noise, similar to the noise it would make if the felt rings were worn out....but its new and the rings are in tact and normal looking. i have noted that the noise is coming from the front.
  • Electrolux Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
tyu634
Posted on Sep 30, 2010
When turned on dryer tumbler makes a metal on metal scraping sound?
Most dryers glide on felt. Either the felt has worn out (not very likely) or something has gotten between the drum and the felt. Could be anything from loose change to jewelry...anything that made it into the dryer from a pocket
Feb 13, 2016 | Dryers
Dryer making aweful noise
it has a felt bearing in the front of the dryer on the door the drum rides on and it is probably bad if it is a scraping and squeeling noise
Mar 20, 2014 | Frigidaire GLER642A Electric Dryer
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 | Dryers
DRYER MODEL DE7400P FRIGIDAIRE IS MAKE NOISE LIKE RUBBING METAL HOW DO I FIX?
Hi martyski39...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your dryer drum is mounted in the rear with a bearing, most likely the bearing is faulty and making the grinding noise, or maybe two conditions exist.
1...Bad drum bearing noisy
2...Bad drum bearing noisy, and with play in the bearing allowing the drum to rub the felt seal away at the door making metal to metal contact.Check your door for obvious rub signs...
I will include a parts house webpage link where you can look at you "exploded" view of your dryer and order parts also.
Please take time to rate me
http://www.partselect.com/MultiModels.aspx?ModelNum=de7400p&searchTerm=&RefineSearch=0
Aug 30, 2011 | Frigidaire Dryers
Hi, Thee dryer makes a loud noise during cycle. It starts low, but it seems after each rotation it get louder. Has anyone ever experienced this and are there any solutions. Thanks for any assistance.
Describe the noise. If its a rattling banging noise you could have a broken exhaust fan which is usually attached to the motor, a broken cylinder roller (if your dryer has them) or worn felts. Maybe a noisy pulley. If its more a high pitched squeek it could be your motor or the parts just mentioned. A metal scraping noise could be something like a bra wire caught by the cylinder but I don't see how that can get louder as the rotates. Make sure the belt isn't cracked all over. Worst case scenario is that your motor is on its way out...
Good luck
Aug 29, 2010 | Dryers
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Spacemaker dryer scraping metalic sound when on
i know you say ge dryer but i think thats a frigadire inside ge dosent make an over under.When dryer off take your hand and go around the in side of the tub where it meets the felt seal.some times somthimes somthing will get caught between the turning drum and the felt seal causing a noise.if not that you have some wear problems and will have to take apart to inspect
Dec 31, 2008 | GE Spacemaker Washer and Dryer Electric...
Dryer
That is an accurate description
the drum of all dryers is suspended from a combination of
felt pads at the drum ends
nylon glides under the drum
rubber tired thrust rollers.
the rubber tires wear, and the drum shifts, this pinches and wears the felts, then there is enough space to pinch the clothes in the gap
It is a simple enough fix, and well worthwhile, felts glides and rollers are cheap in comparison to new dryers.
Generically all dryers are pretty much the same, so when you go to the parts store, the felts rollers and glides may be labelled whirlpool or kenmore
they will fit exactly, there are very few that fit very many models.
To do the job
  • UNPLUG DRYER
  • If a top mounted lint screen, remove lint screen and 2 screws under lint screen from top of case
  • with a putty knife or other blunt blade release spring clips at front corners of lid, retaining lid to front panel
  • tilt lid up
  • remove 1screw each side 1/3 way down front
  • disconnect door switch wires
  • remove front panel and door
  • pull tensioner to end of its travel against tensioner spring, and unhook belt
    (Note:: position of belt around tensinoer and motor pulleys for reinstall)
  • pull drum out forwards
  • motor, pulleys, support rollers, felts, and glides can now be inspected
good roller
3d57115.jpg bad roller
7133e59.jpg rollers are in pairs, if one is worn replace both
Inspect felts and nylon glides where fitted, any wear - replace
to replace felts
requirements 2 or more pairs locking pliers(visegrips) hitemp silicone adhesive
  • pull old felt off
  • scrape off old adhesive
  • spread gllue on drum edge
  • secure felt on drum with visegrip
  • pull felt into place, clip with visegrip, pull again clip with visegrips, work around until felt is attached to drum and clipped in place
  • allow glue to set
nylon glides, if fitted replace easily, a central screw, or glue
reassemble in reverse order
Oct 09, 2008 | Frigidaire FSE748GF Dryer
Fridgedaire drying- It's screeching!
There are several things that will make a dryer noisy. Here's a list of a few items that I know of. Some may or may not apply to your dryer: FIRST OF ALL, BEFORE SERVICING THE INSIDE OF ANY DRYER UNPLUG THE UNIT OR TURN THE CIRCUIT BREAKER OFF. 1. Drum rollers worn out. Most dryers have some sort of drum roller that supports the dryer drum. There are two mounted under the drum in the rear of the dryer. Some models will have an additional set of drum rollers under the front of the drum as well. You may also here the drum thumping too. Lubricating them with a good quality turbine oil at the point of the spin shaft will get rid of any squeaks or squeals. DO NOT oil the roller wheel as it will slip on the drum. 2. Dryer drum seal. This is a felt gasket or seal that is glued to the rear ring of the drum. When they get old they become brittle and pieces start to break off leaving bare metal scraping against bare metal. They also can become folded and part of it will be seen poking through the back of the drum inside. This seal should ride evenly around the outside perimeter of the drum and should not be seen inside the drum. 3. Dryer drum support glides. Some dryer models have teflon plastic support glides mounting around the ring of the front of the tub, or will have teflon supports mounted under the front of the drum. In either case, if the plastic gets too worn down, the dryer will start to make a scraping noise. 4. Idler pulley. This is a little pulley that provides tension on the dryer drive belt. It is located near the drive motor and can start to make noise. Usually a little bit of lubrication at the point of the spin shaft will get rid of the problem. 5. Dryer drive motor. Sometimes when the drive motor gets a nice collection of dust build up around it, the motor will make noise as the impeller rubs against dust or any other debris caught. A stiff cleaning brush and a vacuum cleaner will help get rid of dust accumulation around the motor. Now, there is a possibility that the bearings in the motor could be going bad too. You would need to remove the drive belt and check to make sure the motor free spins with no power applied. Give the motor shaft a spin. It should glide free with no noise. 6. Dryer drive belt. When the belt gets old it will develop a "glaze" on it and start to slip around the drum. This can causing a squealing noise, especially under heavier loads. This is usually a prelude to the belt breaking. Start with the easy and simple options first. Try lubricating any drum rollers or pulley rollers. DO NOT get oil on the drive belt. Lubricate the rollers at the point of the spin shaft only. Inspect the front and rear of the drum. The seal will be in the rear. Make sure that it is intact and good condition, and make sure it has not folded inside the drum. Also, check for glide supports around the front of the drum and make sure there are not areas that are worn down. Another thing that COULD cause noise, but may not be associated to the problem you are having, are foreign objects getting lodged between the dryer drum and casing. Screws, paper clips, nails, etc., have been known to get caught in these areas and will make some awful noise. If you try everything and the unit still makes noise the drive motor bearings could be going bad. This is usually not likely and the motor can be very expensive to replace. Last of all, some heat on the top and rear of the dryer are normal. However, if it is excessive (you can't place your hand on it and hold it there), you probably need to give the inside casing a good cleaning. This could be a sign that your dryer ducting has become clogged and the unit is actually overheating trying to fight for air. Ask yourself, "Are my clothes taking a longer time to dry?" If the answer is "yes" then you need to clean the unit out and check the entire length of the ducting to ensure it is blowing air out of the vent. Remember also, the shorter and straighter the ducting run, the better. Any sharp bends or kinks (behind the dryer) will cause lint to back up. I hope you find this advice helpful. Good luck and let me know if I can help further.
Jul 01, 2007 | Frigidaire FDE336RE Dryer
Electrolux EIGD55H Dryer Logo
963 people viewed this question
Top Electrolux Dryers Experts
Electrolux
Electrolux
paul
paul
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
