Question about Xerox Phaser 8400 Laser Printer
My HP LaserJet 3390 goes Offline and I Couldn't get it back Onlin
Two days ago my HP LaserJet 3390 Printer was working perfectly. An hour or two ago my printer just went offline and I couldn't get it back online despite several attempts trying to reboot my WindowsXP PC.
Every time I reboot my PC, nothing changes and also the Online option on the menu when I right click does not show.
What should I do to bring it back Online?
5 Suggested Answers
exil0r
  • 118 Answers
SOURCE: printer offline
Open system properties (my computer --> right click --> properties) go to hardware tab and click device manager. expand the usb controller and see if there are usb printing support, if exist go to control panel --> printer and faxes. right click in your printer icon and select use printer online.
if you don't find usb printing support in device manager the problem is with your usb connector. try to change it and make sure the printer power is pugged correctly.
Posted on Mar 12, 2009
SOURCE: Printer status offline
There is a firmware update for this problem. Check out this link:
http://www.hp.com/pond/firmware/hidden/P2015FWUpg20080312.html
Posted on Apr 07, 2009
SOURCE: After one print, it goes Offline
Turn off the SNMP option in the TCP/IP printer port Properties
Right-click the printer, select properties
Select port tab, highlight port, click Configure Port
UnCheck SNMP status Enabled.
This fix was given to me from Xerox Tech support.
Good luck
Posted on May 11, 2009
bravsman
  • 94 Answers
SOURCE: "printer is currently off-line. offline" use a mac
check the usb cable of printer try to reconnect it and make sure you use usb port in your printer properties
Posted on May 25, 2009
brett207
  • 231 Answers
SOURCE: the printer (hp laserjet p2015) appears offline
Press and hol the green 'go' button until the lights flash, (about 4-5 seconds) and release the button,
Wait for the config pages to print out, and then check your network configuration, i.p address, Subnet mask and gateway.
If no network page prints out, you might have a dead Network Interface in the printer.
Posted on May 11, 2010
Code 10. 1000 supply error hp laserjet 3390
Remove the toner and shake it a little. You can put the toner back in the printer. If this does not fix the issue, Turn off the printer, unplug the power cable from wall outlet. Wait for 1 hour and plug the power cable and power on the printer
Regards,
Sean
Apr 11, 2013 | HP LaserJet 3390 All-In-One Printer
Hp laserjet 3390 driver
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Sep 27, 2012 | HP LaserJet 3390 Printer
Hp p1102w offline
This worked perfectly, I hope it doesn't lose the connection again!
Phil D
www.TheBocX.com
Aug 25, 2012 | HP LaserJet 1100 Printer
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
When printing from an HP Laserjet 3390 all in one printer, getting a thick black line down one side of the paper.
if it is uniform, replace the cartridge
if it is not uniform, you have to replace the fuser asembly
Mar 16, 2010 | HP LaserJet 3390 All-In-One Printer
Laserjet 5000 printing problems
HP Laserjet 5000 Printer
01.Try to install the catridge properly once again after rebooting the Desktop / Laptop along with this Printer.
02. Check through CONTROL PANEL whether this particular HP laserjet 5000 printer is showing in the printer menu.
03. If is there, try to remove offline and make online.
04. If this HP Laserjet not available in the Printer menu, please insert the Printer driver cd and install this printer.
05. Try to ensure your desktop or laptop not affected with Virus. There might be a change, if the machine is virus affected, Printer offline problem will be shown.
Have a good day.
Jul 17, 2009 | HP LaserJet 5000n Printer
My Hp Laser Jet 3390 has a 10.1000 suppy error messege after replacing my toner
If you are technical, remove batery inside and wait for one hour. Put battery back and printer will be ok
Jul 11, 2009 | HP LaserJet M1522nf Multifunction Printer...
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
** Paper Pickup
Check the paper pickup tray & roller may be its not working. If possible contact the local vendor for printer servicing.
Mar 09, 2008 | HP LaserJet 3390 All-in-One Multifunction...
Xerox Phaser 8400 Laser Printer Logo
573 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
