Question about Philips Magnavox 27MS343S 27" TV
I need the code for ptv915 - Philips Magnavox 27MS343S 27" TV
    Problem Solver:
  • 18 Answers
Service & Alignment mode enter: 062596+Index or Status
Digital Convergence mode enter:062597+Index or Status
HBSkirmit
Posted on Mar 10, 2009
How do i tell if my ptv915 model number 60p8341a needs something new to fix the quality of the picture it is blurry and snowy and color is off
Sounds more like input quality, check all cables and receivers such as sat, community network, antenna etc. Is it the same when playing DVD etc?
May 22, 2014 | Televison & Video
Why isnt my sound working on my ptv915 but works with head phones
Look in the Audio portion of your menu and make sure Speakers are ON.
Nov 24, 2010 | Philips Televison & Video
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
Ptv915 won t turn on; led blinks 3 times, then continues blinking 2 times over & over. Tv shut off with ''snap''.
HI, your power supply circuit board is damaged and, you will need to replace this damaged component asap if possible. this will restore your units operational value.
Jun 05, 2009 | Philips Televison & Video
Philips Projection Screen TV Model PTV915 Horizontal Alignment
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment.  I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
Nov 25, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50p8341 chassis PTV915
Well the manual seems ok ,but you need check the board as there burn out in it which causing this problem check the IC S and the tracks on the board ,even bad connectors can cause this problem...
Good luck...
Sep 09, 2008 | Philips 50P8341 50" Rear Projection...
Ptv915
replace 1uf 100v capacitor.located neer flyback transformer circuit.
Dec 18, 2007 | Philips Magnavox 27MS343S 27" TV
Philips model ptv915 model # 60P8341a
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
141 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
