Question about IBM ThinkPad A22m Notebook
Laptop Screen Appeared Split Into Four Windows
At start up, instant of appear in one normal screen, four screen appears as if you have change the displace of your desktop.
    Master:
  • 404 Answers
That usualy happens when the screen has been replaced and it is not compatible with the laptop (is the screen blured too?)
can you see the same on an external screen?
Posted on Mar 02, 2009
Hi! I bought a new asus eb1505 4GB RAM 500G disc. I switched it on, it asked me for some settings (language, EULA etc.), I set an username and a password. Than it said it should restart. Ok. After...
What I would do is to on post pressing your PC's power on begin to click over and over till you see a screen the F8 key. Go into Safe Mode or you may be able to Start Windows Normally. If this does not work then you must either do a Recovery or Run Windows disk.
Aug 30, 2013 | ASUS EeeBox PC EB1505-B011M Intel Celeron...
I have Acer 4710 laptop. 1. The screen becomes white during start up or when computer is left without usage for some time. 2. Also, sometimes, split screen come suring startup itself and booting...
It maybe one of three things:
1) Bad windows installation. IF you ONLY see this problem during the time you work with windows and NEVER during bios boot up process it could be your Windows installation but I doubt it. It is most likely a hardware problem:
2 a) The hinges of your laptop are becoming bad and there is a short in the wires that carry the video signal up to the screen
2 b) the video card of your laptop is failing.
Jul 05, 2011 | Computers & Internet
Not able to start windows normally the page keeps on toggling and a black screen appears n goes :(
On boot-up press the F8 button which would bring up a screen. Select Safe Mode and then press ENTER... on the next screen select the Operating system and press ENTER. The screen will scroll rapid fast upwards and stop at a point for a few seconds. Then the screen with windows will appear with SAFE MODE written on the four corners. It will also ask you whether you want to run windows in safe mode. Choose YES. Now click start --all programmes-assessories-system tools- restore point. From there choose a restore point where the system was working properly and continue with the prompts. The system will restore your sytem after it automatically restarts. Hope it solves,. Else load a fresh OS.
justice_thounaojam@yahoo.com
Dec 30, 2010 | Computers & Internet
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
When I press the power button to turn the computer on, nothing is displayed on the LCD screen. Power light, Hard Drive light, and Battery Light all appear normally. I hear the fan blowing internally and...
Check the resolution of the screen by right clicking on an empty part of the screen and choosing properties. Go to settings and make the resolution 1078 x 768 and hit apply and ok. There are instances when the resolution will change from a software update etc. that is not supported by the monitor or graphics card.
Sep 03, 2009 | Dell Inspiron 1525 Laptop
Hang up
Possibly due to corrupted graphics driver, or resolution changed to one unsupported by your laptop. Try restarting in safe mode by tapping F8 key on boot and select "safe mode" press enter then enter again. If it gets to windows in safe mode log on as an administrator and go to "display" in control panel, select adapter and change the driver by rolling back to a previous version or simply uninstall, which is what i did! Then restart the computer, it should now boot to windows but the resolution will be naff, get on the internet find the latest driver from your laptop manufacturer download this to the desktop and install from there. Worked for me, hope it does the same for you.
Jul 05, 2009 | HP Compaq for Presario V3000 Motherboard
Thin Vertical lines on the screen
Ebay - new screens $110-$135. Google for step-by-step replacement instructions.
Dec 30, 2008 | Toshiba Satellite P30 P35 Series Notebook
Troubleshooting IBM ThinkPad A31 monitor problem
The system is having problems with the graphics drivers, heres how to tell!!! when you first turn the machine on display is clear until it gets to windows. To resolve the problem is quite easy, just reboot into safe mode and un-install the graphics drivers, then reboot. When the system restarts is should re-install the graphics drivers automaticaly for you, job done :)
keep me informed please
regards
Nov 24, 2008 | Computers & Internet
IBM Thinkpad 2652 has horizontal and vertical gridlines on screen
Try to remove your Memory modules and clean the contacts with a pencil eraser. Makes sure to clean both sides of the memory contacts.
Nov 21, 2008 | IBM ThinkPad A31 Notebook
Unlock code
unlock code is
0000 (four zero s)
OR
000000 (six zero s)
Sep 28, 2008 | Motorola Mobility ROKR E6 Smartphone
IBM ThinkPad A22m Notebook Logo
1,151 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
