Question about Panasonic SC-HT900 System
Change speakers on Panasonic SC-HT995W
This system works well but speakers are ugly & take up too much space. could i change to a smaller speaker set either panasonic or another brand like bose?
  • kellykate Mar 04, 2009
    thanks for the advice much appreciated, will do!
    Novelist:
  • 91 Answers
Absolutely ,but remember that theese home theater combo,s are sonically matched so you should find speakers that are rated to the same power handling and frequency response of the one,s you are replacing, if the frequency response is close to what you had that will work fine , if you were to use speakers that were rated for higher output your amplifier will not be able to push the sound of the higher rated speakers and you would not be getting the optimal listening experience , thanks and i hope i helped you ,sincerely Glenn
Posted on Mar 03, 2009
How to set speaker delay on Panasonic Home Theatre SC-PT960
You need to go into the Video menu of the device and select 'Speaker Settings'. See the manual available from Panasonic.
Feb 17, 2013 | Panasonic SC-PT960 Theater System with...
I have a panasonic home theatre system, can I use aftermarket speakers?
It can be done but be sure the smaller speakers have the same impedance as the Panasonic ones
Jan 20, 2013 | Audio Players & Recorders
Error F61 How to reset SC-HT995W system?
I'm sorry to say, but an F61 error can not be cleared by a reset. Please see the link below for an explanation of protect mode (F61 is Panasonic's version of protect). Usually the output amp pac will need to be replaced. This will cost between $75 and $100 for the part. Feel free to post any additional questions here.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Oct 19, 2010 | Panasonic SC-HT995W System
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
I got a panasonic sc-bt100 from sears used but i cant connect the rear speakers i think im missing a part do you need to put something on the dvd player so the rear speakers could work?
There should be a "module" that you slip into a slot on the back of the main SC-BT100 unit...this is the transmitter that sends the signal to the rear speaker unit. The rear speakers, while "wireless" to the main unit, are wired to the separate unit that should have come with your set-up.
Oct 02, 2009 | Panasonic SC-BT100 Theater System
Panasonic SC-HT995W Home theatrer System
It's probably a ventilation fan that's making the noise. Locate it and see if you can clean out any dust or dirt in it.
Apr 30, 2017 | Panasonic SC-HT995W System
Suround speakers and center speaker is not working
Well you can change the setting to hear from different speakers. Play with it you will hear the front on one setting then all 5 on another
Nov 29, 2007 | Panasonic SC-HT680 System
Display shows "L" and "R" highlighted in Red
maybe the sound setting is in mono mode versus stereo surround,this only occuring on older model surround systems.   if that doesnt do it , try unhooking  and then hooking the speakers back up  or ; maybe they are even...................switched      hope i could help            i  man   fixxxxxxxxxxx
Aug 27, 2007 | Panasonic SC-HT730 System
Panasonic SC-HT900 System Logo
119 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
