Question about Refrigerators
Freazer works fridge warm
Amana fridge freazer model BR 18VW: freazer works but is starting to ice around the door and top. The fridge is not cooling. It seems that the fan may be faulty as the sound goes off for long periods. Then comes on for a while and the fridge starts cooling then it warms up again when I presume the fan goes off. Do we need a new fan and is this fixable? What part(s)do we need. Will it help to manually defrost? Could the defrost or thermostat functions be at fault? Thanks Jen
  • jendesilva Mar 07, 2009
    Thanks that is helpful. Jen
  • 400 Answers
Hi Jen, I would suspect the thermostat. The fact that the fan is still coming on and off is because it is more than likely getting frozen or clogged with ice making it stop and in turn cooling stops. Yep I would start with changing the thermostat.
Posted on Mar 05, 2009
Need schematic Amana frig SQD25VW-P1314202WW
Hello Ron Carlson
Page 6 of 6...
Pretty straight forward refrigerator!
Although I agree with the first answer you got from Todd Marr...a lot of available volunteers here have been around a lot of blocks...
Can call out the Whirlpool & Frigidaire units you share parts with... and how to very cheaply you can
test various parts to bring you to your very quick victory...
I'm just saying, ice-maker, defrost issues, warm refrigerator side... Fast frost build-up... puddles?
If you'll pardon the pun ...
FROST FREE REFIGERATOR/FREEZERS are pretty cool...!
Amana SCD25TBW Technical Information Wiring Diagram
Apr 06, 2016 | Amana Refrigerators
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Refrigerator is warm, but freezer is cold and still making ice. This is a 3 year old Amanna Bottom Freezer model. There is frost in the top of the freezer drawer when I putt it out.
you will need to defrost it. the freezer is what keeps your fridge cool. the vent where the cool air goes up to your fridge is sealed or frozen.
unplug the fridge and open the doors and let it defrost.
plug it back in after a few hours and it should be working again.
Mar 20, 2011 | Amana ABB2223DEQ Bottom Freezer...
Amana Model #TX20NBW FREEZES food in the fridge AND leaks water
Sounds as if the thermostat setting is too high.
Not a good idea to pour warm water into the fridge while its going, but then again.Most drain tubes exit over the compressor into a container sitting atop it. But I've since learned there are now fridges that don't have compressors now? You should also check the door seals, you can do this with a sheet/piece of newspaper
inserted between the door and fridge, go around both doors, you'll soon know if the seals need replacing.
Oct 03, 2009 | Amana ATB2135HR Top Freezer Refrigerator
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
