SOURCE: seat belt 95 volvo 850
remove the door pillar trim and un bolt it.slide seat forewards and remove the door surround rubbers then take off the door pillar trim
SOURCE: Volvo 850 oil pressure sending unit
It's on the engine, right next to the starter, it has one wire going to it. You don't need to drain the oil. If the light is coming on, you may have bad seals in the oil pan, a fairly common problem, but replacing the switch is a good fisrt step.
SOURCE: Volvo 850 GLT's brakes??
if the pulsating in the steering occurs while braking this is an indications that the rotors are out of round and need to be turned or replaced. if they are causing a pulsating while driving without braking it could be the calipers sticking.
your back brakes will be cooler than the front brakes as the majority of braking is done ith the front brakes even on four wheel disc brakes. hope this helps.
SOURCE: 1995 Volvo 850 Overheating
water pump impeller is loose on the drive shaft its plastic and they come away from the splines ,cheap crapo idea but ??
SOURCE: My 95 VOlvo 850 Tubo keeps stalling on me!
It's the solinoid. It's placed alongside the distributor. A coil about 1" around, and 2" long loosen, disconect the cable and lead coming out of it, repalce, and it will run fine then.
