Question about Sony STR-DB940 Receiver
Sony STR-DB940 Receiver Speaker Impedance Question
I know the manual talks about 4 and 8 ohm speaker loads, but my question is how low the load impedance can safely go. Basically, I want to wire the center channel output to a pair of speakers hanging off my Pioneer PDP-5020FD plasma TV. I figured I would wire them in parallel. I measured the ohms of each speaker; one is 6.8 and one is 7, so in parallel it would be around 3.4. Is that a safe load? It's not much below 4 ohms, and I know many amps can handle down to 2 ohms, but I don't know if my receiver will. Please help. Thanks!
  • jsdittmer Mar 03, 2009
    Thanks Gene. I might not have described my situation well enough for you. The speakers are detachable from the plasma, so they are not hooked up to it at all now. I want to attach the center channel of my Sony STR-DB940 receiver amp to this speaker bar. The bar has two speakers. I would like to use both if possible. Right now I have the center channel of my receiver hooked to only one speaker.
    My question was that if I hooked up both speakers in parallel to the receiver, the load would be cut in half to around 3.4 ohms, and if in series it would be 13.8 ohms, would either work? It is the Sony STR-DB940 receiver amp that I want to hook to the speakers. I would do either based on a professional recommendation (or neither if the receiver won't handle it). The receiver specs only state 4 and 8 ohm scenarios, but it's a beefy receiver, so I was wondering if it will actually handle 3.4 ohms (since many can handle as low as 2 ohms). Maybe this is a question only for Sony, but I figured someone on here might know. It would be on everyday, but normally at pretty mild levels. I just didn't want to risk anything without professional advise.
    Thanks
    Jeff
  • Anonymous Mar 26, 2014
    i no the cumin speaker wires are 4ohm but is the rj output 8 ohm
  • 3 Answers
Whats the rating on the Plasma? How many watts at 4 ohms? If the plasma is rated 100 w at 8 ohm... hanging a 3.4 ohm load would put a lot of strain on the plasma's output amp. At 3.4 ohm the amp would be trying to delive close to 200 watts at full power. But it depends on how hot you normally run the volumn. Remember an amplifier output is AC volts. 1 ohm of resistance is close to a dead short. The amplifier would have to work its *** off to supply that type of power and would probably burn the output op-amps. If the outputs burn & it pumps any DC current through the speaker wire..the speakers would be toast...if not catch on fire. Try to keep the speaker load at or very cloe to the plasma's output load rating. Also if the plasma doesn't state it will handle loads down to 2 ohms...It probably won't.
Gene
Posted on Mar 03, 2009
  • 3 Answers
Since the Sony receiver has preamp outputs for all channels, you could use the center channel preamp output to drive the existing amplifier in the television set. This will avoid concerns over speaker impedance and make the cabling simpler as well. By the way, if you measured the speaker "impedance" with a DC ohmmeter, you haven't actually measured impedance. DC resistance is a scalar quantity measured with an ohmmeter, but impedance is a vector quantity consisting of resistance and reactance.
Posted on Jan 11, 2010
Connect speakers
All power amplifiers are designed to operate with a maximum current. This is limited by a minimum speaker impedance load. Your amplifier manual will specify the minimum load on output channels. High quality amplifiers can drive speakers with a combined impedance of 2 ohms or less. To calculate your parallel load, as you have requested, use the following formula. 1/Total load = 1/mgongo speaker impedance + 1/HW-E5500 speaker impedance.
Example. If your mgongo speakers have a nominal impedance of 8 ohms and the HW-E550 speakers have a nominal impedance of 8 ohms, then the formula is 1/Answer=1/8 + 1/8
1/Answer = 2/8
1/Answer = 1/4
Answer = 4.
If your amplifier can drive a 4 ohm speaker load without clipping then you are OK.
Dec 09, 2013 | Audio Players & Recorders
Speaker Imedance Matching - Sony STR DE 997 receiver with 120Watts - 8 ohms output with Benz 6 ohms..Tower Speakers
hi pawanh75,
thanks in advance for a very informative setup that you have.
Here are some of possible mods , only if you like and can DIY
( or have someone to help you )
• Using a 6 ohms impedance for an 8 ohm impedance amp clearly
denotes that it heats up the output stages.
(please forgive my very technical words)
• One way to lessen the heat is to install a blower .
Use a 220V blower on top of the receiver.
( air should be in going up direction ).
• Before I proceed further please indicate if having the speaker
connected and having a zero volume , and just letting the receiver
in an "On" state deliverately produce heat on the receiver, or just
when the volume is at medium to high level.
If it s running hot at zero level with speaker , please post.
If it is running hot even without speaker, post also
• It may also helps , if you have a powered subwoofer ( for the low's),
and set settings on your receiver to "small"
Let me know what you find to help you further.
Sep 11, 2012 | Sony STR-DE997 7.1 Channels Receiver
Sony str de 475 ?? is appear 'protect' on screenboard and can not listen anything
The message appears usually when the wiring is wrong (short circuit) or the speakers are defective or their impedance is too small for the amplifier's output (for instance 4 ohms speaker connected to an 16 ohms output). First, check your connections.
May 15, 2011 | Sony STR-DE475 Receiver
Hi I purchased a sony av amplifier model STR-DB930 on e-bay a few months ago and I am using 3 ohm speakers from my old surround sound system. The output selector on the back of the unit is set to 4 ohms....
The lower number in Impedance specs is not a suggestion. It's a limit. 3 is not between 4 and 8.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DB930-Receivers-manual/id/387bh934/t/2/
If you don't want to buy new speakers, settle for safer low volume levels.
You're going to kill that receiver driving a 3-ohm load. HTS-style speakers aren't reliably re-deployable to other electronics. Perhaps, if you have 4 speakers and they're similar you could wire them in SERIES and present a 6-ohm load to each channel.
Re-engineering the speakers themselves is, well, don't do it. It isn't rocket science but it also isn
Feb 28, 2011 | Sony STR-DB930 Receiver
I have a str-de750 and a str-de597 both after less than 2 years of use flashed "protected" and are rendered useless to me.I will not purchase a 3rd one unless this can be resolved.FYI since the...
Hi, It may not be a wiring problem, or a heat issue, but it should be related to what is at the other ends of the speaker wire. I, of course, don't really know what is happening with your receivers. I guessing.
My only rational guess besides the receivers having been defective is this.
So here the theory part:
An amplifier is designed to operate with a certain amount of 'LOAD" on it's speaker outputs.
It will say something, in the manual and perhaps on the back of the unit itself at the speaker terminals
"4-8 Ohms (a measure of resistance, the load itself) 4-16 Ohms, etc.
So what happens when you wire in parallel Two 8 ohm speaker systems together. You get 4 ohms.
Not a problem.
What happens if you wire four 8 ohm speakers together, you get a load of 2 Ohms. This level of resistance if very low for a receiver and it will go into a protection mode. If you were able to run it without protection, the output transistors would cook internally. The Receiver itself wouldn't necessarily get hot. But that would happen.
If you put four 4 ohm speakers together. The amplifier would see 1 ohm resistance. That is almost a short circuit.
So if you happen to be running multiple speakers together. Check this point out.
Hope this helps,
Best,
Mark
Jan 19, 2011 | Sony STR-DE597 Receiver
Power out rms- 4 o 8 homs?
I can see why you're asking for help on this. It almost seem this unit has been 'disappeared' as far as online information is concerned. Even Sony has nothing on it.
I founs some articles and For Sale posts:
http://toronto.kijiji.ca/c-buy-and-sell-electronics-Sony-STR-4800SD-Stereo-Receiver-135-OBO-W0QQAdIdZ243602516
"Sony's STR-4800SD receiver was extensively, and positively, reviewed in Stereo magazine's Fall '77 issue. In their introduction, they found the 4800SD bettered its published f.m. sensitivity specs "by a wide margin...it has exceptionally smooth frequency response, very low distortion(especially in the midband), and excellent quieting. No exotic claims are made for the power amp section, either (35 watts/channel,15.4 dBw at 0.2% THD). But our tests indicate much more capability than that, and a distortion of only one-tenth that spec."
The power consumption figure shown in a photo below says "145W", which would be consistent with a 35 watt amplifier.
http://www.oaktreevintage.com/web_photos/Stereo_Receivers/Sony_STR-4800SD_Stereo_Reciever_collage.jpg
Jan 02, 2011 | Sony str-4800sd stereo receiver with...
Halo this receiver gets very hot when i use 4
Check the impedance on the rear of the speakers and then check the back of the receiver...the receiver will say on the back what the minimum impedance for each speaker should be...if the receiver says min of 8 ohms per speaker and you are running 4 ohm speakers, then the impedance is mismatched and this will eventually burn up the amplifier in the receiver
Dec 19, 2010 | Sony STR-DE835 Receiver
"Low Imp"
Low Impedance is not a suggestion, it is a WARNING. Your receiver is telling you it senses TOO LOW a load and it's trying to protect itself from damage.
Speakers A& B are running in parallel, so their combined impedance, X, is found by using the formula: 1/X = 1/A + 1/B.
In other words, two 8-ohm speakers in parallel would yield a 4-ohm load.
If your speakers are identical, try running them in series on one speaker output pair. That would keep the impedance safely high.
Feb 15, 2010 | Technics SA-AX540 Receiver
''protect'' flashed continuously -worked sporadically- seems dead
That model of receiver goes into protect mode when there is really
low
resistance or a short on your speakers/wires. It does it to protect the
final drivers in your amp. Does it do the same thing with all of your
speakers disconnected? If it doesn't then you might have a problem with
one of your speakers or wires. Check your wires for shorts in them
first. That may be the only problem. That model is designed for 8 ohm
speakers, but you can go down two 6 ohms safely. I have a STR -D865 that
has been running 6 ohm speakers safely for almost 3 years now. A way to
check your speakers out is to take an ohm-meter across the terminals on
them(with the receiver unhooked). They should read anywhere between 8
and 4 ohms. Check with the manual on your speakers to see if they
correspond. If the resistance is really low, you may have a short in
that speaker. it is also possible that if they are 4 ohm speakers, you
could have damaged the drivers in your receiver. I know the model above
mine, (the 965) has a 4-8 ohm speaker selection switch on the back. The
lower models were not designed to run 4 ohm speakers. Hopefully this has
been of some help.
Brad / Luisa_K - usenet poster
Apr 03, 2009 | Sony STR-D565 Receiver
Front speaker channel cut off
I lean toward an overhating condition since the unit does not go into protection mode right away, and then returns.
My thoughts are as follows...
1) The receiver needs better ventilation
2) The speakers are below the rated minimum nominal impedance, causing the amplifier to strain and overheat
3) There is a problem within the amplifier that is causing this problem - this is not user repairable.
I'd try another pair of speakers which are rated at 8 ohm nominal impedance and give it a trial. At the same time, monitor the heat output from the unit (note that modern amplifier sections do run hot). If the unit runs extremely hot at a low volume and still shuts down on 8 ohm speakers, it's time for service or replacement depending on value.
Oct 30, 2006 | Sony STR-DB940 Receiver
Sony STR-DB940 Receiver Logo
573 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
