Question about Lexmark Wheelwriter 2000 Typewriter
Wheelwriter 2000 appears to have no power to it
Is there a reset button? Our Wheelwriter 2000 just quit working. We've checked connections, etc. If there is no reset button, any suggestions?
  • Lexmark Master
  • 3,594 Answers
If you know how to remove the case check under the PC board for paper clips and staples.
DickyO
Posted on Apr 06, 2009
Kenwood TS-2000 Power up fails
You will likely have to do a reset on the radio. The method to do this is hard to find in the manual. I have inserted it below. It usually works for me. Doing a full reset will reset EVERYTHING. It is essentially a last ditch attempt to get the radio going again. I hope this helps
PARTIAL RESET
Perform a Partial Reset if a key or control does not
function according to the instructions in this manual.
The following data is NOT erased by performing a
Partial Reset.
• Memory channel data
• Menu settings
• Antenna tuner preset data
• ANT 1/ANT 2 data.
Reset the transceiver by pressing [A/B]+ POWER
ON.
• "HELLO" appears on the display.
FULL RESET
Perform a Full Reset if you want to erase all the data
in all the memory channels. In addition, this function
resets all the settings that you customized, to the
factory defaults (i.e.- menu settings, antenna tuner
preset data, etc.).
Reset the transceiver by pressing [A=B]+ POWER
ON.
A confirmation message appears when performing
the Full Reset. Press the [A=B] key to proceed.
Otherwise, press any other key to cancel the Full
Reset and return to normal operation.
When you perform the full reset:
• All frequencies, modes, memory data and AT
preset data are set to the factory default values
(refer to "INITIAL SETTINGS", above).
Nov 24, 2016 | Kenwood TS-2000
DVD has been working fine but recently moved it to decorate. Now all is I get is 'Hello' when it starts up and none of the functions work. It won't even open or close manually?
see this causes and fix it God bless you
  1. Bad connections to one or more buttons or sets of buttons.
  2. Microcontroller failed to reset properly.
  3. Missing/bad voltages from power supply.
  4. Defective microcontroller or other logic
Sep 23, 2012 | Televison & Video
My apple ipod touch wont turn on
I've seen this before. You need to reset it.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
I hope this works!
May 10, 2011 | Vacuums
I have an IBM Wheelwriter Typewriter II. A week ago the typewriter worked fine before a move from Texas to the St. Louis. When I reconnected the machine and turned it on nothing seems to happen. No...
Sounds like a power supply or a connector came loose in transit. If you know how to remove the case look for staples, paper clips etc. on or around the power supply and PC board.
DickyO
Apr 25, 2011 | Lexmark Wheelwriter 15 Series II...
My iphone 3gs shut off and won't turn on... tried rebooting it but saw nothing. How long should I hold the "Home" button and the "Power" button?? If this doesn't work, what should I do??Please help...
If something isn't working right, restarting, force quitting an application, or resetting
iPhone will likely solve the problem.
Restart iPhone: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPhone. To turn iPhone back on, press and
hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPhone or if the problem continues, you may need to reset. A reset
should be done only if turning iPhone off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPhone
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPhone: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
Oct 06, 2010 | Apple iPhone 3G
IPhone will not turn on i have tried charging via USB on a MacBook but no luck and have tried charging via AC adapter still no luck
Here are the steps to reset the iPhone. You probably performed the first reset, try the other resets.:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Take care
Mar 25, 2010 | Apple iPhone Smartphone
My IBM Selectric System 2000 Wheelwriter 6747/6747-2 has quit typing. The keys respond and the carriage moves but no type appears.
The plastic cap on the print solenoid is probably broken. We sell them with installation instructions for 20.00 including shipping. DickyO Cleveland Business Machines 216-241-0027
Jun 04, 2009 | IBM Wheelwriter 30 Typewriter
My HP deskjet F380 is showing E
Try this :-
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
Lexmark Wheelwriter 2000 Typewriter Logo
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
