SOURCE: Nikon Coolpix S5 lens cover won't open
Hi Debscan, My 1.4 year old S5 developed the same problem and after checking out various websites I get the impression that it is a common one to these cameras. I found that if I put the camera on a level table and then turn it on (and off) 3 times the lens cover would open further with each try. On the third turn-on the lens cover would drop fully with a definite "Click" and the camera would work. The next time I shut it off, the lens would not close properly, but the same "Third times the charm" routine would always work. This may only delay the inevidable final crash of the camera, but it might get you a few more pictures out of it.
SOURCE: Lens Cover Error- Nikon CoolPix S6.
I have a similar problem but it only appears when the battery is discharged. Goes away when I charge the camera fully. I'm wondering if the battery needs to be replaced.
SOURCE: lens is stuck open says
when the camera is turned on it displays "lens error". I can't take a picture and i can't access my pictures on the camera.
SOURCE: My Nikon Coolpix S5 has
Hi ,
The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc" uploaded on site http://www.esnips.com/web/papputatiyasStuff
It will be helpfull for you.
You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging
Mukesh
SOURCE: coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc" uploaded on site http://www.esnips.com/web/papputatiyasStuff It will be helpfull for you. Its is a step by step solution with images.
Regards
Mukesh
