Looking for ecs NFORCE6M-A (V2.0) manual specifically a diagram of where to plug in the various case panel switches/leds
    President:
  • 415 Answers
Follow the link to download the manual.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=818&CategoryID=1&DetailName=Manual&MenuID=46&LanID=0
Let me know if this helps, the manual is 20.2 MB
Mark
Posted on Mar 02, 2009
Power supply diagram for ht 2000 motherboard
http://www.ebay.com/itm/ECS-HT2000-AMD-AM2-Socket-mATX-DDR2-800-Motherboad-w-NVidia-Graphics-/251260314586?pt=Motherboards&hash=item3a804823da
1) Uses one 24-pin ATX main power cable.
Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector.
(Right side of motherboard)
General example. Note that color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Uses one 4-pin ATX +12 Volt power cable,
Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.
General example. Note color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
THAT, would be considered a Power Supply diagram of the motherboard.
They are the only two power cables that plug into the motherboard.
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.
Regards,
joecoolvette
Apr 15, 2013 | ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2...
GT1T-M7 CONFIGURATION DIAGRAM NEEDED
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=897&CategoryID=1&MenuID=16
It is my belief sir that you are referring to the ECS G31T-M7 (Version 1.0) motherboard. If I am incorrect please post back in a Comment.
Scroll down, and click on the Download tab.
(Features / Specification / Download / Support / FAQ / etc)
Now click on Manual.
(Driver / BIOS / Manual)
Scroll down, and click on the NAME of the country nearest yours.
There is the Motherboard User Manual in PDF file form.
For example;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, with Processor to the Top, and Ram Memory slots to the Right; the Front Panel header is located at the Bottom/Right corner, to the left of the motherboard mounting hole.
F_PANEL
The Front Panel header pinout is on Page 29, of the PDF file.
There are 4 pins across the Top row, and 5 pins across the Bottom row.
The pins on Top are numbered EVEN.
The pins on Bottom are numbered ODD.
Starting on the LEFT side coming across to the Right side, Top row:
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side coming across to the Right side, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
This is probably a 5 Volt + point, reserved for factory testing.
D) Pins 2 and 4 are for the Power On LED.
(Light. It is a Light Emitting Diode)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Jumper settings are shown, Front Panel port header's pinouts are shown, etc.
Do you have a specific question? Please post back in a Comment.
Regards,
joecoolvette
Dec 09, 2012 | Computers & Internet
Need circuit diagram for HP m8100 GC673AA
HP Support > Pavilion Media Center M8100n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3440614&lc=en&cc=us&dlc=en&lang=en&cc=us
Product information > Product specifications > Motherboard Specifications, MCP61PM-HM (Nettle2 {HP name} ),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077676&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3440614
The area of contact pins on the motherboard, that the Main wires connect to, is the Front Panel header.
(Power On switch, Power On LED, HarDDrive activity LED, etc)
The Front Panel header is Black, rectangular in shape, and is situated in a vertical position; located in the Bottom Right corner of the motherboard. (Next to the mounting hole)
It is a standard 9-pin HP Front Panel header,
http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the 9-pin Front Panel header photo, and pinout.
The 4-pin side is the EVEN side. Pins 2, 4, 6, and 8. There is NO Pin 10.
The 5-pin side is the ODD side. Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode, so it is redundant to call it a light)
IF the HDD LED is dim when the harddrive is active, (IN use), switch the wires around.
C) Pin 9 is N/C. Not Connected. Reserved for factory use, and it is +5 Volts.
Scroll the HP Support Motherboard Specification page down. Click on the + sign next to Motherboard Layout.
Left to Right on bottom edge of motherboard, Internal Connectors;
AUDIO_1 is for the audio ports on the Front Panel.
ATX_IN is where the small audio cable from the optical drive plugs in.
(CD/DVD drive)
IF TWO optical drives are used; the Main, or Primary optical drive, is connected with the small audio cable. NOT the secondary optical drive.
HD_AUDIO also connects to audio ports in the Front Panel.
May be mistaken, but don't believe SPDIF_OUT header is used.
1394A1 header is for the Firewire ports in the Front Panel (1394a)
USB 2 and USB 4 headers are for the Front Panel USB ports.
USB 1 and USB 3 should be for a Card Reader.
Need where the power cables go, and what they look like? Just post back in a Comment.
(Be SURE to FOLLOW Anti-Static Precautions)
Regards,
joecoolvette
[ Didn't think you actually wanted an actual circuit diagram. That is copyrighted by HP, and Elitegroup Computer Systems. (ECS)
Dec 03, 2012 | Computers & Internet
Where do i plug in pwr led, H.D.D led and pwr switch?
Front Panel Connections of DFI AM35-EC Motherboard
DFI AM35-EC Manual (Refer Page 14)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | DFI AM35-EC Motherboard
FITTING MOTHERBOARD
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
Changing my case
If you want to download the Manual for your Motherboard, I've included the link below. Otherwise I will provide a rough diagram of the Panel header for connecting your case to the Motherboard.
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=422&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
[2][4][6][8][10]
[1][3][5][7][ 9 ]
HDD Led
+ = 1
- = 3
Power/ PWR LED
+ = 2
- = 4
Power switch
Pins 6 & 8
Reset
Pins 5 & 7
RSVD (Reserved)
pin 9
NC (No Connection)
Pin 10
Hope this helps you
Dave
Nov 14, 2008 | EliteGroup K7VMA Motherboard
Where are the EliteGroup nForce3-A power & reset plug-ins located at?
Goto page 10 in your user manual. There look for. Connect the case switches and indicator LEDs to the SW1. (Location).
There is mother board layout decription for how to connect the case, 2-pin wires case connectors ( Page 12 shows pin numbers & which is plus + & negative - pins.). You'll nee the manual to help you. Download it from ECS at: http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=579&DetailName=Manual&MenuID=48&LanID=0
Mike
Aug 12, 2008 | EliteGroup nForce3-A Motherboard
HP MCP61PM-HM motherboard diagram
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
daa3370.jpg This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 22, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
1,462 people viewed this question
David Payne
David Payne
