Question about Technics SL-BD22 Turntable
How to put a drive belt on Technics SL-BD22 Turntable ?
I received a Technics SLBD22 turntable in the mail and when I opened the box, the rubber drive belt was not attached. I cannot see how it is threaded or installed and it does not have a manual. Can you please explain how it is installed. Can't tell by just looking at it I am afraid. Thank you so much in advance for your attention to my question. Bill Bender, Strongsville, Ohio
Posted on Mar 10, 2009
Great help!!
Posted on May 26, 2009
What size belt on the SL-Bd22
Just purchased a belt for my SL-BD22 from Vintage Audo (Audio?). The belt size is 23.6 X .180 X .025 inches. Their part number for this belt is:B00926DJ74. Hope this helps.
Oct 21, 2012 | Technics SL-BD22 Turntable
How do i install a belt on technics turntable sl-bd22
If you remove the rubber pad, you should be able to grasp the metal table. A gentle tap onto the center spindle while pulling up on the table should release the table. Place the new belt onto the underside of the table. Replace the table onto the spindle. Then feed the belt over the motor hub.
Dan
Apr 20, 2011 | Technics SL-BD22 Turntable
Tecnics turntable Model SL-L26
Terry, Remove the rubber mat from top of platter. This will expose two slots in the aluminum platter. Lift aluminum platter straight up and off. On the underneath side of platter is a surface that the belt will fit on, place the belt there(approximately half the diameter of the platter) With the belt mounted on platter, reinstall platter to turntable. Slowly rotate platter until you can see the drive motor pulley, stop. Carefully reach down and pull belt over drive motor pulley (make sure not to twist belt) Rotate platter to ensure smooth operation and belt tracking. VOLA! Reinstall rubber mat and vynil on!!
Jun 11, 2009 | Technics SL-BD22 Turntable
High pitched singing
It could be the wrong drive belt if the turntable is of the old fashioned type and does'nt have the direct drive. If the 33/45 switch isn't working properly then its a possibility its the drive belt tension on the turntable.
Apr 11, 2009 | Technics SL-BD22 Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
How to replace drive belt for model.# SL-BD22 ?
Nope, very simple...
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Feb 28, 2009 | Technics SL-BD22 Turntable
Drive belt has come off.
Ok.Thats a difficult part to explain on a pick up.So listen up and give attention.Take off the plate of your driver and adjust the belt from the down side of your plate where there is a circle.put it in there and grab the belt to one side and adjust it to the "turner"then put your vinyl and play it.
Aug 15, 2007 | Technics SL-BD22 Turntable
Drive Belt - Technics SLBD22 turntable
Try http://www.vintage-electronics.net/ttbelt.html
Jun 16, 2007 | Technics SL-BD22 Turntable
Technics SL-BD22 Turntable Logo
486 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
