Question about Philips GoGear Flash MP3 Player
The device when turned on sticks in one mode,when centre button pushed it simply exits altogether
  • 8,596 Answers
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
I AM LOCKED OUT OF MY KINDLE FIRE IT KEEPS ASKING ME FOR A PASSWORD AND I NEVER SET ONE.
If you can't remember the password for your Kindle, you can reset your password to regain access.
To reset your Kindle if you don't have the password:
Kindle Touch
1. Press and release the power button to turn on the device or exit sleep mode.
2. Enter "111222777" into the passcode field and select OK.
Kindle
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field and use the controller to select the enter key.
Kindle Keyboard
1. Slide and release the power switch to turn on the device or exit sleep mode.
2. Enter "resetmykindle" in the password field and press the enter key on the key pad.
3. Wait several minutes while your Kindle restarts.
Kindle FIRE
2. In the password field, attempt to enter a password 4 times.
3. When password is incorrectly entered 4 times, you will be prompted to reset Kindle Fire.
4. Select "Ok reset".
Feb 16, 2016 | Cell Phones
How do I turn off "safe mode" on a Samsung Galaxy S4?
To turn off
Powering down , then back on should do the trick. Be sure to completely down. Do not select "restart". If you still have problems, remove back cover and pull battery from device. Leave the battery out for about 60 seconds, then place the battery back in, assemble the rear cover and start the phone again.
Some galaxy s4 models may require you to press and hold the volume down button during start-up in the same manner as enabling it to exit safe mode.
http://www.technipages.com/samsung-galaxy-s4-turn-safe-mode
Nov 17, 2015 | Samsung GALAXY S4
Reset button,location
There is no external reset button to this TV. You have to enter the Service Mode option to make it a factory reset. you should have its original remote control to do this. No universal remote control can be used for this purpose.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 26, 2014 | LG 26LG30 26 in. LCD TV
How do you get the menu/factory display off TV screen to get tv to work?
To exit the factory mode, you should have its remote control. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Without its remote control, no other way. Contact the authorized service center.
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
How to exit safe mode on kindle fire
Shut down the device. Make sure the volume buttons are not sticking. If they are sticking when you turn it on it will go into safe mode. You may have to use your fingernail or a small sharp object.
Feb 15, 2014 | Computers & Internet
Uniden uh038sx 2
Your radio is either stuck in VOX mode, or has a bad PTT button. Sometimes when using an audio device a radio will stick in Tx if the device is plugged in while the radio is turned on. When using any remote mic, earpiece, headset, or audio device be certain the radio is turned off when plugging or unplugging the device.
If no audio device is being used, the next possibility is a sticky or bad PTT button. This can sometimes be just the external button sticking, or it can be the internal button has simply worn out from repeated use.
One final thought, if your radio has programmable VOX, check to see if your programming is correct. VOX features when turned on make the radio Tx when it hears any sound, a voice or ambient noise can cause the radio to transmit.
Best regards.
Sep 28, 2013 | Uniden Hand Held Scanner - BC-246T 2-Way...
I have set up the hibernation settings for when you close the lid but now it wiont come out of it when the lid is opened
Hit the space bar or enter key to wake it up. Maybe you have to pres the Power Button to wake it up.
Read the manual to see how to wake it up.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals on the site and search them on hibernation.
Below is what your manual says to get out of hibernation you have to press the Power Button (very last paragraph at bottom).
Hibernate Mode Hibernate mode conserves power by copying system data to a reserved area on the hard drive and then completely turning off the computer. When the computer exits hibernate mode, it returns to the same operating state it was in before entering hibernate mode.
notice.gif NOTICE: You cannot remove devices or undock your computer while your computer is in hibernate mode. Your computer enters hibernate mode if the battery charge level becomes critically low.
To manually enter hibernate mode:
  • Press <Fn><F1>.
or
  • Click the Start button, click Turn off computer, press and hold <Shift>, and then click Hibernate.
or
  • Depending on how you set the power management options on the Advanced tab in the Power Options Properties window, use one of the following methods to enter hibernate mode:
    • Press the power button.
    • Close the display.
    • Press <Fn><Esc>.
note.gif NOTE: Some PC Cards may not operate correctly after the computer exits hibernate mode. Remove and reinsert the card, or simply restart (reboot) your computer. To exit hibernate mode, press the power button. The computer may take a short time to exit hibernate mode. You cannot make the computer exit hibernate mode by pressing a key or touching the touch pad or track stick. For more information on hibernate mode, see the documentation that came with your operating system.
May 14, 2012 | Dell Latitude D610 Notebook
My skycaddie froze in transferring while connected to skycaddie sync. i cant get it to turn off or exit.
perform a soft reset. hold power and joystick for 8 seconds. it will turn off. now turn on. if boots up correctly, then ok. if not, then perform hard reset. push the information button (i) and flag button at same time. while both buttons are pressed turn on power. you should be in recovery mode. if so, re-sync.
Aug 15, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
System Error code 09 038 46 24363
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Connecting Bluetooth to Kenwood KDC X590
you need a kenwood kca-bt200 which is a bluetooth plugin for your head unit. when you have installed this here is a check to see if its recognised.
1 Select the STANDBY
Press the [SRC] button.
Select the "STANDBY" display.   2 Enter Menu mode
D-1:Press the [MENU] button for at least 1 second.
D-2:Press the [MENU] button.
D-3:Press the [FNC] button.Turn the Control knob to select "MENU", and then press the Control knob.
"MENU" is displayed.   3 Select Bluetooth device selection mode
Push the Control knob towards up or down.
Select the "Phone Selection"/"PHONE SEL"/"PHN-SEL" display.   4 Enter the selected Bluetooth device selection mode
Press the Control knob for at least 1 second.   5 Select the KCA-BT200 Firmware
Select the "BT200 FW ***" display.   6 Exit the Bluetooth device selection mode
D-1/D-2:Press the [MENU] button.
after this you should be able to pair from the headunits menu
Nov 27, 2008 | Car Audio & Video
Philips GoGear Flash MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
