Question about Hitachi 65S500 65" HDTV-Ready Rear Projection Television
Cant adjust the blue its all over screen its a hitachi 65s500
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
cant
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your concant adjust the blue its all over screen its a - 2c07611.pngips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
Hitachi 65s500 dim
try this
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Hitachi+65s500+lamp&rh=i%3Aaps%2Ck%3AHitachi+65s500+lamp
Dec 02, 2013 | Hitachi UltraVision CineForm 55VG825 55"...
I am trying to hook my ps3 up to my Hitachi 65 s500. I have the hdmi cable to hook up to imput 1 but when I do that The screen is showing fuzzy color but no picture. What am I doing wrong.
Make sure you're hooking it up to the HDMI port or the Composite port correctly. There is a red green and blue for composite that usually wont work in a port marked "Input 1" You would need to put it in "component/composite 1" correctly. I've come across this not working in 1080, but fine in 720p.
Jun 07, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
We just bought a Hitachi 65S500 tv secondhand. When trying to correct the convergence, the magic focus green color does not align the letters correctly in the horizontal position. When we try to correct...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
Where to buy hitachi projection screen
First, I can tell you most of the Hitachi sets sell both inner and outer screens as a unit--most of the time it is the only way they are available.
Get me the exact model number and I will try to get you part number, cost, and place where it can be ordered if it is available.
If this is helpful rate this solution as I do this here for free.
Regards, SD TECH
Dec 17, 2009 | Hitachi 65S500 65" HDTV-Ready Rear...
I have an ultravision hdtv, model #65s500 64
You can Google the model number----I just did and found possible free download for owner manual:
retrevo.com/support/Hitachi-65S500-TVs-manual/id/.../t/2
REGARDS, SD TECH
Sep 30, 2009 | Televison & Video
I would like to know if I can use the DVI-HDTV input terminal to plug in my computer and use my Hitachi 65S500 as my monitor with a wireless keyboard and mouse.
Yes. You need to have a DVI connector on your PC for direct DVI-DVI connection or you can buy a DVI-VGA cables for around $25 bucks. Then, after connected, go into your display properties and adjust your settings. Hope that helped.
Dec 22, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
PROTECTIVE SCREEN
I need to buy protective and projection screens for my 65" hitachi hdtv due to tare in both sreens done by maintenance people.
Mar 26, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Playstation zapped tv
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Hitachi 65S500 65" HDTV-Ready Rear Projection Television Logo
79 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
