Question about GE DPSR610GGWT Dryer
I have a new GE 610 profile dryer. I get more lint inside the dryer frame and also on the door, than i get in the trap.When I remove the trap there is alot of lint inside that I cannot get to.
  • Anonymous Mar 18, 2009
    I have a ge dbvh520 dryer. Plenty of lint in the vents but none on the lint trap. Seems like the air is flowing around the trap.
  • 413 Answers
SOURCE: lint trapped inside dryer housing
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Posted on Jun 14, 2008
  • 251 Answers
SOURCE: Cleaning the dryer lint trap compartment.
use ur vaccum hose and vaccum it out
Posted on Nov 26, 2008
  • 686 Answers
SOURCE: GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Posted on Feb 27, 2009
SOURCE: Ge Adora Dryer, Worked great.
the dryer during its cycle squeaks and rumbles it sounds like some thing is not right.
Posted on Jan 03, 2010
  • 744 Answers
SOURCE: dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Posted on Jan 07, 2010
Lint trap doesn't sit right in dryer. It sticks up and clothes ge caught on edges., ripping clothes
Take the lint trap out, and look inside the slot where it goes. You will see a lot of built up lint which will have to be removed so you can slide the trap back down to the bottom.
May 05, 2017 | GE Dryers
How do I clean lint from inside GE Harmony Profile Dryer?
You have to remove the panel. The assume the lint filter works better then they usually do and do not make it easy to open up and clean inside. You may have to open it from the back side which does open up to allow repairs, etc.
Aug 12, 2014 | GE Profile Harmony DPGT750ECPL 7.3 Cu. Ft....
How do I take the cabinet off a GE gas dryer model # DHDSR46GE1WW to check inside?
The following website may be helpful:
This was extracted from the website:
Remove the two screws at the front above the drum opening (with the dryer door open). The top panel then lifts off. I removed the screw at each side that holds the front panel to the side panels, tilted the front panel forward, which disengages the front of the drum from the front drum glide bearing. I then lifted the front panel slightly, unhooking the bottom of the panel from the dryer base, and swung the front panel aside.
Oct 10, 2017 | Dryers
The lint trap on my GE dryer is moist.
Check the venting, if it is blocked or if the venting is bend it will not allow the moisture to leave the dryer and it will end up in the lint trap and on the door
Jul 26, 2012 | Maytag Neptune MDG5500AW Gas Dryer
GE Profile Prodigy DPR483GAOWW takes 2-3 cyles to dry. Have cleaned lint trap still no success
Our laundry room is in the center of the house and the dryer vent runs underneath the house and every 6 months or so we have to run a plumbing snake all the way through the vent pipe. Once it all the way through the house we then tie a rope to the end of it with a huge knot tied into it, we then snake the rope through the pipe and it pulls out all the lint that has collected inside, someone at each end of the rope (make sure it's long enough) and run it back and forth until no more lint is collected. I hope this might help you.
Mar 19, 2011 | GE Profile Prodigy DPSR513GA Dryer
Our GE Profile DPSB613ED2WW dryer has been losing drying efficiency for the past few months. It now takes three cycles to completely dry a load. The dryer is heating (although we assume not correctly) and...
How is the vent discharge air flow out the back of dryer? If not very strong check out lint trap cavity for blockage or obstuction causing lint to build up, blocking air flow from drum cavity. Once found a pocket comb that had got into lint trap housing and created a lint dam blocking air flow.
Feb 14, 2011 | GE Dryers
Cannot locate lint trap to fit my wsm2420 sazww washer dryer combo ge parts no will not fit
In the Kenmore equivalent, the lint trap is on the back wall of the interior of the dryer. If GE is the same then you'll see two vents at the back inside, one is the intake (where hot air enters), the other is the outtake, which contains a lint trap. You might have mistaken both for nonremovable vents. But one of them is removable. It should have finger holes or something to grab. Just pull it and it will pop out without difficulty. It's probably a two-piece unit (a grate on the dryer side and a screen on the exhaust side, with a space in between for collecting lint), which snaps or slips apart easily, then you can clear the lint, and then snap or slip it back together and just push it back in place in the dryer.
Jul 01, 2010 | GE Spacemaker Washer and Dryer Electric...
GE profile dpse810gg gas dryer - more lint coming out og dryer vent than caught in lint trap
ck the felt seals on the lint trap and see if its making good seal or if they are missing
Jan 26, 2010 | GE Dryers
Lint problem
You must GRARANTEE full and free ari flow outside of the building. Typically this type of complaint is related to restricted air flow outside of the machine...normally there is lots of lint, and it exits through the filter, but when flow is restricted, lint remains inside.
Sep 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
GE DPSR610GGWT Dryer Logo
174 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
