Question about Panasonic Microwave Ovens
Panasonic Microwave Model NN-S454 glass tray does not rotate
The oven light comes on only after the cooking time is entered and ooking starts - the microwave cooks but the tray does not turn. The unit is 18 monthsold - light use.
  • Panasonic Master
  • 9,047 Answers
I would suspect that you have trouble with one of the door switches or its mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
See: http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
You can order other parts for this brand at Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Mar 06, 2009
Turntable for microwave model#nnt945sfx
The cooking tray and roller for the NNT945SFX are available from Panasonic on the microwave's product page under the accessories tab. See http://shop.panasonic.com/support-only/NN-T945SF.html .
The parts list from Partstore.com is fairly complete: https://www.partstore.com/Model/Matsushita/Panasonic/NNT945SFX.aspx . The cooking tray for the NNT945SFX is part number F06014M00AP. It is available here: https://www.partstore.com/Part/Matsushita/Panasonic/NNT945SFX/Matsushita/Panasonic/F06014M00AP/New.aspx . The roller that goes under the glass tray is part F290D9330AP. That is available here: https://www.partstore.com/Part/Matsushita/Panasonic/NNT945SFX/Matsushita/Panasonic/F290D9330AP/New.aspx . The motor to run the turntable is available as well.
I hope this helps. Other vendors will have the tray and roller as well.
Nov 30, 2016 | Panasonic Microwave Ovens
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
What is the dimension of the rotating plate I broke mine
Here is a link to the replacement glass cook tray for your Panasonic NN-S961 microwave:
http://microwaveglasstrays.com/shop/panasonic-microwave-glass-turntable-plate-tray-f06014m00ap-p-156.html
And here is another link to that part from Sears Parts Direct:
http://www.searspartsdirect.com/partsdirect/part-number/Panasonic-Parts/Microwave-Parts/F06014M00AP/0022/568/Model-NNS961/0789/0123245?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50019470&diagramPageId=00001&productTypeId=x&searchModelNumber=NNS961&subCompDesc=Cabinet%20parts&brandDesc=PANASONIC&modelDesc=MICROWAVE&blt=11
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
As you can see from the website, the tray has the following dimensions:
Glass tray measures approximately 16 1/2 inches in overall diameter.
Outside diameter of turntable track is 10 7/8 inches.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 06, 2011 | Panasonic NN-S961 Microwave Oven
Glass tray of my microwave oven Panasonic model NN-SD577M is not rotating.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 06, 2011 | Microwave Ovens
We own a Panasonic 1100 watt Inverter microwave. It has worked fine until recently - it has now started to "turn on" whenever the door is opened. Now, when you open the door the light...
HI:
You have a faulty door switch, the unit is not supposed to come on when the door is opened only the light.This unit may require servicing as the control board may also be at fault.
Dec 24, 2010 | Panasonic NN-S753 Microwave Oven
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Microwave oven NN-S573
The usual cause is the tray motor assembly, or the power supply that feeds it. These parts are available from the parts rep for Panasonic. Contact Panasonic for details.
There are serious safety issues when servicing microwave ovens. I suggest to have the oven professionaly serviced by an experienced service tech for these products.
Jerry G.
Apr 17, 2008 | Panasonic NN-S753 Microwave Oven
Microwave Ovens Logo
126 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
