Question about Technics Audio Players & Recorders
Overload signal the receiver, a sa-ex110 stereo receiver is showing an overload signal on the readout, there are no other equipment connected, only the speakers
  • 4,234 Answers
The overload is the same as protect mode. Remove the speaker wires and turn the unit back on. If the message remains, there is a problem internal to the unit in the final stage of the amp.
Please let me know the results of the test above.
Thanks,
Dan
Posted on Mar 02, 2009
Overload what do i press and hold to reset?
No!!
Fix the reason why the amp is overloading FIRST
If you hit your thumb with a hammer, you don't carry on hitting it while you put on a plaster. Always fix the cause of the problem before trying to restart the system.
Check your speaker wiring for shorts. These are bits of wire that bridge between the black and red speaker connections, or frayed bits of speaker cable where it is trapped or getting walked on.
Sep 06, 2014 | Technics SA-EX110 Receiver
Technics receiver shuts off after being on for five minutes.
Heat.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Sep 21, 2011 | Technics SA-EX110 Receiver
The overload is on
A precise make and model might yield more-specific answer.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 16, 2011 | Technics SA-EX110 Receiver
OVERLOAD
First of all the KEF is a powered sub which means that it wants a line level signal NOT a speaker level. Send the signal from a tape output or pre-amp output to the sub input. The overload is because the impedence load for the speaker output is too low and looks like a short to the amp. Continued attempts to connect the system as described will result in damage to the output section of the amp.
Please let me know if you need more info.
Dan
Feb 03, 2010 | Technics SA-DX750 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Nov 16, 2008 | Technics SA-EX110 Receiver
Technics SA-G9057 overload
Check the fan connections at the back. The connections (just two flimsy metal prongs) came apart (I believe), so I have had to re-enforce them with electrical tape so the connections stay together until I investigate a further replacement fan. For now the connections are extremely sensitive to motion/viberation/impact/etc... but it does work now.
Sep 23, 2008 | Technics SA-EX300 Receiver
279 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
