What to restore factory settings on windows 98
Want to restore factory settings in windows 98
    Master:
  • 404 Answers
Use windows 98 installation cds. hard to find now if you don't have them.
Posted on Mar 03, 2009
How to restore lenovo all in one to factory settings windows 7
I Can't Help you There Because Unfourtunetly To Be Honist
With You Windows 7 Is A Junk OS! Just About The Only Option You Can Have That It If You Happen To Have It At All
Is To Install A Copy Of The Best OS Wich Is Windows 98 But Only If You Still Happen To Have A Copy Of Windows 98!
Aug 28, 2014 | Lenovo C300 20" All in One PC 30121JU...
Restoring computer back to factory settings
no. restoring back to factory settings means it will be back to when you first got it. windows will be installed along with whatever software and programs the manufacturer put on.
Nov 13, 2012 | Dell Latitude D505 Notebook
Hello how do i restore my acer aspire 5332 laptop to factory settings
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at
http://www.vtechsquad.com/acer-support/
Jun 09, 2011 | Computers & Internet
Was in the middle of restoring the computer to factory settings, it was at 98% and it died now it says the windows failed to start
Hi there!
If the restoration to the factory settings did not finish then Windows was not reinstalled properly in your computer. I suggest that you reset again the computer to factory settings. If the restoration died again at any point before completion, I suggest to do a manual re-installation of Windows.
Hope this helps.
May 20, 2011 | Computers & Internet
I have a packard bell imedia mc 1538 and need to resore to factory settings, have tried using F10 key with no result just goes to start up. The master cd just does a system restore and not the factory...
If the file that holds the factory settings is gone then there is no way to restore the factory settings back. You can however reinstall windows if you got a hold of a windows disc in the version you want. You can use the windows key on the computer somewhere to activate the windows. I would suggest doing a system restore the the last restore point and removing any unwanted things from there.
May 11, 2011 | Computers & Internet
Can i restore my compaq presario cq60 notebook to factory setting without cd ? its vista
hi.
there are two ways to completely restore settings of a computer:
1- enter Bios of your notebook (by pressing "delete" repeatedly") and select restore to manufacturer's settings.(or load from manufacture settings). THIS CAN RESTORE SETTINGS OF YOUR HARDWARE.
2- for restoring settings of Windows:
restart your notebook and before windows starts up (showing "windows starting") press F8 repeatedly.
then choose "load from last good configuration".
Jan 30, 2011 | Compaq Presario Notebook
How do I restore my Gateway Windows 98 to factory settings without a disk?
check control panel system restore for that option,,also when u reboot computer theres a option for that also
Nov 03, 2010 | Computers & Internet
Ibm restore to factory setting
You have not explained what is wrong with your computer.
Is the laptop working, does it boot up into Windows?
What are you trying to restore?
Are you trying to get into a previous Restore Point?
The Access button takes you into the BIOS, you can change the BIOS settings back to the Default settings (ie the factory default settings).
It is difficult to offer a solution without knowing the exact nature of the problem.
Nov 23, 2008 | IBM ThinkPad R50e Notebook
Tecra 720cdt
if you have the cd that came with it all you have to do is insert the recovery disc and press letter c upon the start up and choose option number 1 all the way and it will load the factory default software or you can press 0 upon startup aswell if you have the hidden partition on your computer since its a tecra
Sep 17, 2008 | Toshiba Computers & Internet
The quick restore dosen`t work
What operating system you are using before installing windows xp. If it is windows 98, Your restore cd will restore windows 98. if you want to restore to factory settings pls boot from the restore cd and format the harddisk. Becareful, this will erase your entire data on the harddisk which cannot be recover. If you are using licenced (not pirated) windows xp boot from it and reinstall windows xp so that you can run the os smoothly. But in either case becarefull when you are formating, it will destroy entire data and you may endup in soup. feel free to revert back for further quiries
Sep 29, 2006 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
