Question about Dell 926 All-In-One InkJet Printer
My printer wan print
When i push file than print a message comes on the computer montior and say that pinter is not communationing with computer i went ot dell.com and asked questions and got no answer what is wrong with my printer?
  • 523 Answers
Nothing wrong with the printer, the problem with the driver, try to renistall the driver again, and check if the cable is plugged good (if its usb plug out and then you will hear the sound on the pc) or if its network cable you will see the network card linking green or yellow. if there is no problem with cable will be the driver.
Posted on Mar 02, 2009
PIXMA MP780 All-In-One InkJet Printer: Getting Printer Error 6A00 light on pinter flashin...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 07, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Printer will not print from email
if you wan to print an email . go to the actually web page ...and try from there ...do not try to print from outlook cause it has an encoding that might not be read by the printer ...specially for attachments ...
if you wan t to print an attach ment ..save it in the computer first ...
if you want the whole page ...print it from the website of the email service ...and use file(left -top) and print ...for yahoo for example you can print from the page directly by using the print job on the right corner of your email ...Im sure that for about any email service there is a thing like this ...
in sort ...usually is best to save any file that ya want to print into the computer before..
Dec 21, 2009 | HP Photosmart C6280 Printer
Error message A600 on iP6700D pinter --- removed all cartridges as suggested - no change - turned off and attempted a hard reset - no success - will not print at all -
6A00 says the purge unit is jammed on the right side where the printhead parks.Sometimes you can just push back the squeegee assembly to free it and clean with a wet Q-tip. Other times you can only have the purge unit replaced.
Nov 16, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Were is situated the ink absorber? I want to clean it!
goto start setting printer & faxes select your printe right click on it go to property other wise same place select your pinter file printing prefrencess
Oct 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Hp printer won't copy
the ink inside of the cartridges is gelled.
Feb 06, 2009 | HP Office Equipment & Supplies
Can you tell my printer cartiges was finish i refil new cartige and put in the printer but printer does not work only for printing from computer but fax is working photocopy is work and sccaner is also...
Please follow these tips
1. turn off your printer for one menu t and then turn it one.
2. You should charge your ink the option may be in your Pinter software or there should a button in your
Pinter to charge your ink.Press
OK to begin charging the ink.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}you need to disable the ink level monitors afterre-filling the cartridges. go to properties, maintenance, view printer status,option and click enable status monitor once
Nov 22, 2008 | Lexmark Office Equipment & Supplies
Printer instalation
Good day.
Usually that happened once the printer was not set to default setting after it was installed.
To set to default, click start, choose printers and faxes, select the lexmak pinter, click file select default printer.
To test your printer if it print.
1. right click the printer icon
2. select properties
3. click print test page
Thanks.
Nov 01, 2008 | Lexmark X6570 InkJet Printer
Printer wont communate with computer
check the cable, port, the driver status
Oct 17, 2008 | Computers & Internet
My printer
Start by disconnecting the printer from the computer and turning it off. Wait a few minutes before reconnecting it. While waiting, open your pinter settings and insure you have nothing waiting to be printed from you computer. Once this is verified, restart your computer, then reconnect the printer. Most likely the print que is simply "stuck" on the one file.
Jul 14, 2008 | Lexmark X2500 All-In-One Printer
Dell 926 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
