Question about ASUS Computers & Internet
ASUS en7600GT flashing screen.
While installing the nVidia software drivers for the 7600gt the screen starts to flash on and off involentarily. The most i am able to do to stabalize the dispay is use a restore point that removes the drivers. Is there anyway to get the display drivers working in a stable condidion?
  • 1 more comment
  • Callan Maart
    Callan Maart Mar 02, 2009
    Case 2 is the one.. and i am using the latest driver. same problem
  • Callan Maart
    yes i have tried.. its been failing with both the "out the box" drivers and the latest ones.
  • Callan Maart
    Callan Maart Mar 03, 2009
    The point is not to get the card to work on another system. The point is to get working accelerated graphics for the existing system and if the ASUS en7600GT doesnt work then im throwing it out and just getting something better.
    Thx for trying to help though.
  • 21 Answers
I did not understand if the problem is in the exact moment of the driver installation or after. so i will post for both questions.
case 1: the display turn on/off when the driver is installed and you did not try it after the installation: in this case there is no need to worry because after installing the drivers it almost always happens that you get that effect. it happens because while installing the driver the installation is changing allot of the default display parameters and settings resulting in short flickers of the screen it should work perfectly normal after you restart your system.
case 2: in this case the display continues to flicker even after you restarted the computer after the driver installation in which case i would recommend installing the latest driver from the nvidia website [ http://www.nvidia.com/Download/index.aspx?lang=en-us ]out dated drivers may conflict with more modern day software or even some updates to the other software on the computer.
good luck.
Posted on Mar 02, 2009
  • 1 more comment
  • malky_david Mar 02, 2009
    well if this happens only after the driver installation and system restore "fixes" its safe to say that its the driver that isn't doing its job well. did you try installing a less up-to-date driver? it might just be the latest one causing all the trouble
  • malky_david Mar 03, 2009
    i see. at this point im not so sure what might be the problem. is there anyway you could connect the card on another system?
  • malky_david Mar 04, 2009
    i the point of connecting it on another system isn't to have it working there. its to see if the card is working at all so you'd know if the problem is the software or the hardware or just the graphics card. if it works on another system the problem isnt the card itself.
How can I get a geforce 7600 gt graphics card to work in a el1333g-01w emachine
1) Did you install the drivers off of the installation CD disk, FIRST?
THEN physically install the graphics card?
If not you get a Driver Conflict.
When a device is installed, (Such as a graphics card, for one example), Windows breaks it's neck to find matching Drivers.
If you install the graphics card first, THEN the drivers, Windows will have already looked for THE drivers, and not found them.
Windows will then go through it's THOUSANDS of generic one size fit's all drivers, and match drivers up to the GeForce 7600GT graphics card.
This = No
Windows: "Which drivers do I use? These or THESE?"
Driver conflict.
IF, this is what has transpired you need to;
A) Computer on a table, computer unplugged from power, computer case open. FOLLOW Anti-Static Precautions. Unplug the monitor from the 7600GT. Remove the GeForce 7600GT.
B) Leave the case open.
Press, and hold the Power On button in for a count of 10 seconds. Let go.
Do this procedure 2 more times.
(IF,
1) You press the Power On button in, and the Power On LED light comes on, then after a few seconds goes out,...
2) And the same scenario happens again for the Second time, you press, and hold the Power On button in,....
3) See if it lights up again for the Third time. If so, hold the Power On button in again, until it goes out.
You are draining residual power. Don't worry about the CMOS Battery at present )
This action resets BIOS Setup back to the factory default settings.
In otherwords back to the Nvidia GeForce 6100 integrated graphics on the motherboard.
It also clears CMOS Error Codes.
C) Plug the monitor into the VGA port, in the I/O area at the back of the computer.
Plug the computer into power.
WAIT 1 minute, turn the computer on.
Windows should load. After Windows is fully loaded, put the Installation CD Disk in the optical drive, and load ALL software.
(Drivers, Graphics User Interface, etc)
Let the computer run for a few minutes.
Now turn the computer off normally. Unplug from power. Observe Anti-Static Precautions, and reinstall that GeForce 7600GT.
Plug the monitor into the 7600GT. Plug the computer into power.
Should get in the taskbar at the bottom, "Found new hardware", and perhaps another one, "Found GeForce 7600GT device"
Immediately go to the Nvidia graphics user interface, and open it up.
Set the graphics card to it's optimum performance.
(Also make SURE the Screen Resolution is set to what the monitor uses.
Right-click on empty area of desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
Move the Screen resolution slider to the appropriate screen resolution.
Left-click on Apply.
Then left-click on OK.
Also make sure in the box under Color quality, that it states
Highest (32 bit) Use the blue down arrow to the right of the box, if it isn't. Left-click on Highest (32 bit)
For additional questions post in a Comment.
Would appreciate it if you would reply back in a Comment, as to your findings.
Regards,
joecoolvette
{To add;
Sometimes a computer has to be shut all the way down, after all of the above, and wait 60 seconds.
Then turn the computer on.
Sometimes you have to do this twice. Then Windows and BIOS catch on }
Jan 21, 2012 | AOpen GeForce 7600 GT, (256 MB) PCI...
I re-installed the operationg system (Microsaoft Windows 7) for Asus N5S3. It asked me to install the intel card and the Nvidia card; after intalled them the Nvidia is read as a driver in the Device...
Certain video cards are only compatible with certain processors on motherboards. AMD CPUs work with Nvidia and Intel CPUs work with certain graphics cards also. Are you sure it's even compatible?
Dec 29, 2011 | ASUS Computers & Internet
En7600gt 256 vga driver
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or you might need to download one
http://download.cnet.com/asus-eax600-pro-secondary/3000-2108_4-73679.html
if this package is not the right http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need all software windows software mac software mobile and web apps http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 13, 2011 | ASUS EN7600GT/2DHT/256 (256 MB) PCI...
Windows 7 64 bit wont boot up unless I disable the nvidia. I tried updating the driver but this did not help.
How did you update driver? Did you use Nvidia? I can't find it at all through Asus. Do you get video through the Intel chipset with the Nvidia diabled? Anyway Nvidia has a download but I don't know what comes with it, and if you tried to download from Nvidia, you have to unistall the old software before installing new software for it to work right.Look in programs and features and see if you have any duplicate software. Do you by chance have an installation CD for your graphics? If so, I would do one of two things, if you have a CD, uninstall all Asus software, you will have the video graphics but, you may also have "Smart Doctor" and "OSD gamer". Again, if you have a CD uninstall all Asus software including graphics driver, gamer and Smart Doctor restart system, and re-install from CD. If you are going to try download from Nvidia, try uninstalling video graphics only, then download driver from Nvidia. If you have questions let me know.
Dave
Apr 25, 2011 | ASUS ET2400INT-B121E 23.6' Intel Core i5...
Asus eee 2G screen flashing
you just installed windows xp, have you installed the drivers properly? i suggest you need to reinstall the video driver.
Sep 17, 2009 | ASUS Eee 2G Surf Notebook
I want to download a suitable driver for my unknown graphics card
You need to know what graphics card is in it. I think it is either a ati or geforce. go to asus website. look for support and find the drivers for it click on this website . http://support.asus.com/download/download.aspx
Good luck
May 26, 2009 | ASUS EN7600GT/2DHT/256 (256 MB) PCI...
Prince of Persia - The Two Thrones - Doesn't Start I am running:- Core2Duo, Windows XP, SP2, NVidia Gforce 7600GT, Dual Monitor, dxdiag 9.0c When I run pop, it says checking disk, then goes to direct draw...
make sure u run demon tools before running the game,,,
ang also update the starforce protection software to make the game work in any os...
the link is
http://www.star-force.com/support/drivers
Apr 26, 2009 | Ubi Soft Entertainment Prince of Persia:...
Vertical lines at BIOS splash screen
Is your power supply rated to hand the board and the graphics card and all the other hardware?
Did the issue star with the video card?
try removing the extras like the CD drive and any other PCI devices and just putting the graphics card in and whats needed to boot the computer.
Also, reseat the graphiocs card.
also try installing just the drivers for the video card without any of the over clock software.
Try resetting your BIOS by disconnecting the power cabel and removing the BIOS battery and waiting a minute, put back in and restart/
Feb 03, 2009 | ASUS EN7600GT/2DHT/256 (256 MB) PCI...
Graphic Card Problems
This is a link to the newest drivers for your GPU.
http://www.nvidia.com/object/winxp64_178.24_whql.html
Try installing it and see if the problem occurs.
Dec 28, 2008 | ASUS EN7600GT silent/2Dht GeForce® 7600GT,...
Please help asus en7600gt 256mb and intel 925 dualcore
I am not familiar with the Smart Doctor software, but it seems to me that the software is having problems. If you don't show any symptoms such as random errors on your system or the system is shutting down, I would especially say that the software is wrong.
I would go through the system bios, which is accessed by hitting delete when you start the computer (you can continuously tap the delete key if you are unsure of when to precisely hit it) In there, you can look at the system health status and determine exactly what you motherboard is reading the temperature at, then compare that to what t the software is telling you.
Oct 14, 2008 | ASUS EN7600GT/2DHT/256 (256 MB) PCI...
Computers & Internet Logo
144 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
