Question about HP DesignJet 750c plus InkJet Printer
Error code 070010 001BFFF
Cartridge tray is not moving smooth and quits after it starts.  Also we are getting an error message to turn of the power and check cartridge path but there isn't any obstructions. If you know of a service center near Kokomo, Indiana please advise.
  • 67 Answers
Most likely the belt has given up and chunks are stuck in the motor pulley.
Posted on Mar 06, 2009
    Sniper:
  • 121 Answers
I don't know of a service center but try this while your looking. A little bit of light oil on the shaft (drops or wipe DO NOT SPRAY oil in the machine) the carrier rides on should make the unit work. The shaft becomes dirty and dry over time and the carrier can bind.
Hope this helps
Posted on Mar 03, 2009
My Lexmark printer when turn on it makes noise and it can not print with a error code 2200
Hello thanks for using Fixya
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Step1.
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes:
Continue to step 2.
No:
Attempt a test scan. If the error message does not reappear, the error is resolved.
Step2. Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.Did the error message return?
Yes:
Continue to Contacting Lexmark.
No:
Continue to step 3.
Step3: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes:
Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No:
Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Step4: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes:
Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No:
Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 11, 2011 | Lexmark P4350 All-In-One InkJet Printer
Error remove and check color cartridge this message keeps appearing even after removing and replacing cartridge
Use the following steps to make sure the carriage can move freely.
  1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. Allow it to move to that position.
  2. Without turning off the product, disconnect the power cord from the back of the product to reset the print mechanism and allow the moving of parts by hand. WARNING: The following steps require you to move parts by hand. There is a risk of electrical shock if the power cord in not unplugged.
  3. Disconnect the power cord from the wall outlet.
  4. Look in through the cartridge access door or the output paper tray to make sure the cartridges are secure in the carriage and have not come loose.
  5. Check for any obstructions under or around the carriage that are preventing it from moving.
  6. Make sure the carriage can move freely across the width of the product by firmly pushing the carriage to the left, and then to the right.
  7. Clear any obstructions. You might have to reach through the output paper tray to access the carriage.
  8. Close the cartridge access door, and then reconnect the power cord to the back of the product and wall outlet.
  9. Press the power button (c00636182.gif ) to turn on the product, make sure that there is paper loaded in the product, and then try to print a document.
also u can try
Step one: Download the update
  1. Make sure that the product is turned on and connected to the computer.
  2. Hold down the Shift key and click here to open the Software and driver download page in another window.
  3. Under Locate your product to get support , type the product model and then click Next .
  4. If necessary, click the product number under Select your product from the list below .
  5. Under Select your operating system , click the appropriate operating system.
  6. On the Software and driver download page, in the Update section, click Resolves certain print cartridge rejection and scanner failure error messages .
Step two: Install the update
  1. Follow the on-screen instructions to install the update.
  2. If a device update error screen or another error screen appears, restart the computer and try to install the update again. The update might fail if it has already been applied.
  3. After installing the update, make sure that the product is turned on and loaded with paper.
  4. Try to print a document.
Nov 16, 2010 | HP PSC 2355 All-In-One InkJet Printer
Getting error code 2200 on Lexmark P6250 Photo All-In-One InkJet Printer. Programme asked to refer to user guide. Error code not in user guide. Unplugged printer while on. Restarted PC then replugged...
hi
here is what i have found -- follow to all instructions accordingly
although its for another model, these isntructions apply according t their techsupport i spoke with
.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
here is where i found the error http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&question=2200 error#1
hope this helps -- God's speed
Nov 15, 2010 | Lexmark P6250 All-In-One InkJet Photo...
Error 2200
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
IF THE ERROR MESSAGE DID NOT COME BACK....
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Feb 06, 2010 | Lexmark P6350 All-In-One InkJet Printer
The printer cartidge carrier keeps jamming. How
Solution
Follow these steps until the error message is resolved.
Step one: Turn the All-in-One off and on again
1. Press the On button ( ) to turn the product off.
2. Press the On button ( ) again to turn the product on.
If the error message is not resolved, continue to the next step.
Step two: Clear any paper jam
1. Turn off the product and unplug the power cord.
2. Turn the product around to access the back of the product.
3. Open the rear access door:
1.Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
2. As the door shifts to the right, pull the door out slightly to release.
3.When the door is released, gently remove the door by sliding the door out and to the left.
4. From the rear access opening, gently pull the jammed paper out of the rollers.
5. Replace the rear access door:
1.Insert the two posts on the right of the door into the holes on the right side of the opening.
2.Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
3.As the door shifts to the right, push in the left side of the door to lock it into position.
6.Reconnect the power cord and turn the product on.
Step three: Make sure that the print carriage can move freely
Follow these instructions to make sure the print carriage can move freely.
1.With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2.Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4.Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5.Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6.Press the On button to turn on the product.
Step four: Remove the print cartridges
Improper placement or installation of the print cartridges can cause a carriage stall error condition. Follow these instructions to remove the print cartridges.
1.Make sure the printer is turned on.
2.Open the print cartridge access door, and then wait until the print carriage is idle and silent.
3.Press down lightly on the end of each print cartridge to release it.
The tri-color print cartridge is on the left.
The black or photo print cartridge is on the right.
4.Slide both cartridges out and place them on a clean sheet of paper.
5.Disconnect the power cord.
6.Move the carriage all the way to the left with your hand.
7.Close the print cartridge access door.
8.Reconnect the power cord.
9.Turn the product on, if necessary.
If the error message is resolved, the placement of the print cartridges caused the problem. Complete Step five: Reinstall the print cartridges. There is no need to complete any steps after Step five.
If the error message is not resolved, complete Step five: Reinstall the print cartridges, and then continue with the subsequent steps.
Follow these instructions to reinstall the print cartridges.
1. Make sure the product is turned on, and then install the proper print cartridges:
1.Hold the print cartridge so that the nozzles are down and the contacts face toward the printer.
2.Place the cartridge in front of the correct slot.
Tri-color cartridges are marked with a triangle and go into the left carriage slot.
Black cartridges are marked with a square or pentagon and go into the right carriage slot.
3.Push the cartridge firmly into the slot until it snaps into place.
2.Close the print cartridge access door.
3.Align the print cartridges.
1.Press OK at each of the prompts on the control panel to start print cartridge alignment.
2.After the page prints, alignment is complete.
4.Try the print job again to see if this step resolved the issue.
Step six: Make sure the control-panel faceplate is correctly installed
If the front panel faceplate (overlay) is already installed, and your product has been working for some time, do not attempt to re-install the faceplate. Press firmly on the faceplate to make sure it is fully seated, and then continue to Step seven: Plug the product directly into a wall outlet.
If the product has not been set up before, follow these instructions to make sure the front panel faceplate is correctly installed.
1.Position the control panel faceplate above the product.
2.Press down firmly on all edges of the faceplate to secure it.
3.Try the print job again to see if this step resolved the issue.
Step seven: Plug the All-in-One directly into a wall outlet
Follow these instructions to make sure that the product is properly connected to a suitable power source.
1.Make sure that the computer and the product have a three-prong power plug.
2.Unplug the power cable from the back of the product.
3.Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
4.Plug the power cable into the back of the product.
5.Try the print job again to see if this step resolved the issue.
If the error message is resolved, you do not need to continue with the rest of the instructions on this page.
Step eight: Perform a partial reset
Follow these instructions to perform a partial reset of the product.
1.Turn the product off by pressing the On ( ) button.
2.Unplug the power cord from the back of the product.
3.Plug the power cord back into the product.
4.Turn the product on by pressing the On ( ) button.
Step nine: Print a self-test page
Follow these instructions to print a self-test page.
1.Load letter, A4, or legal unused plain white paper into the paper tray.
2.Press the Setup ( ) button until Print Report appears, and then press the OK button. Self-Test Report appears on the control panel display.
3.Press the OK button.
The product prints a self-test report.
Step ten: Service the All-in-One
Jan 26, 2010 | HP PSC 1610 All-In-One InkJet Printer
Sharp AR-M550 with a paper tray error F3-12
When I first arrive to any service call the first thing I look for is the service log.
Locate the service log on the rear,side or inside the front cover.
Check the last error code and corrective action.
F3-12, Paper does not lift in the tray
Identify how many lift tray is inside your machine.
Check each sensor(s) for smooth operation.
LOOK inside for crack plastic on the lift tray.
Sensor can be defective (non-operational) and no cutting off power to the motor and damage the motor,metal frame and plastic tray.
Use a small METRO VACUUM with a clean bag,
Vac the interior of the unit,
Look for fragment of plastic tray or sensor arm inside the vacuum bag.
Pass the information to a Sharp authorize shop.
Dec 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Cartridge seems to move smoothly. Just get the
There could be 2 reason for this error. You can either reset the error or try and clean the printer from inside which might be causing the problem. Below are the 2 steps:
STEP 1: Clean the printer from inside
  1. Opened the cover and checked the front right of the printer near the waste ink pads
  2. Carefully turn the cogs to move the ink cleaning mechanism
  3. There might be a load of paper jam debris blocking the mechanism from reaching its port
  4. Carefully cleaning this out and putting the printer back together
STEP 2: Reset the error
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Apr 26, 2009 | Canon PIXMA iP90 Mobile Printer
I keep getting carriage jamb messages and copier doesn't
Remove both the ink cartridges from the All-In-One. also all the papers in the tray
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.(You can apply a little more pressure and try moving)
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.(If possible insert it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
Good Luck
Oct 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Cartridge gets jammed, but I see no obstruction hp 4315 all-in-one
Please try the steps mentioned bellow
Remove both the ink cartridges from the All-In-One. also all the papars in the tray
Plug the power cord directly to a wall outlet without surg protector (If possible connect it to a different outlet)
Good Luck
Oct 06, 2008 | HP Officejet 4315 All-in-One Printer
Error code 50c
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
May 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
326 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
