Question about Samsung SGH-a737 Cellular Phone
What does it mean when it shows a little man running in right top corner
  • 4 Answers
Yes, it does in fact mean that your AIM is open or running. You need to go to your programs, open IM, and close or log off. Its the only way the 'little man' will go away. If you leave it there, just know it will cost you internet use money.
Posted on Mar 14, 2009
You are connected to aim (aol instant messanger)
Posted on Mar 07, 2009
Meaning of symbols little man left hand corner etc
I can't find the answer either.
Dec 28, 2012 | GPS
Cancel my daughters twitter account
If you can Log In to your daughter's account, you can then do the following:
  • Click the [little white man] in the top right corner of the webpage
  • In the menu that drops down, select [Settings]
  • Scroll all the way down to the end of the page and select [deactivate my account]
  • Then, click [ Deactivate @<insert daughter's screen name here>]
The account should then be deactivated
Sep 06, 2012 | Twitter Tweets
We no longer have our manual. The Little man is lit up and also the dotted circles to the right of the triangle. What does it mean?
the little man means time for service, that is replace the drum and toner developer units,
the maint. man has to be reset by aservice tech, you might try the sharp support site for the reset instructions .
good luck ,tinyman
Jul 19, 2011 | Sharp AR-153E Copier
How to Replace the Right and Left Run channels on a 2004 Toyota Corolla S?
I suspect you mean the glass runs that get all deformed at the top rear corner and front corner by the mirror?
Open the door and lower the glass all the way.
Grab the rubber at the top center of the door frame and dig it out of the channel with your finger nails.
Once you have a bite, pull it off to the corners, then at the front and rear corners pull upwards to pull the rest of the run out of the rail.
To install, it helps to lubricate the back edge of the new glass runs with silicon spray or similar.
Place it into the rail and grabbing a fistful near the top push doward with firm force to slide the rubber down into the rail. It will get more difficult once you reach the glass.
If you get to a point where you can not get it to down any further yet you have further to go, run the window up partially, then while pushing down on the down window switch, force the rubber to slide with the window. The glass will help carry the run the rest of the way down.
When you get the front and rear to the correct heights so the corner line up, peel the tape off the front corner by the mirror and stick the run full into the rail at the mirror and the rest of the way over the door to the rear corner If it is a little short you can tug on it to get a little slack.
Sep 10, 2009 | 2004 Toyota Corolla
Whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Green key shows on screen, cannot delete that photo
The key means that the picture is locked so you can not erase by accident. You need to remove the key be for you can erase the pic. If you have the manual it will tell you how. if not get me the model of camera and I will get you a manual.
Jan 18, 2009 | Olympus FE-220 Digital Camera
No discs will load
if the circle is always showing up on the top right corner of the screen and doesnt load any games that means that you laser pick up is already busted.bring it to the nearest sony workshop for a replacement.
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
Picture is bowed down from top left corner to top right corner and bowed up from bottom left corner to botton right corner. Colors are seperated a little in corners and middle top and middle bottom.
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
May 07, 2008 | Televison & Video
Samsung SGH-a737 Cellular Phone Logo
103 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
