Question about Gateway MT6707 Notebook PC
Fan Died on my Gateway MT-6707
Computer would not power up, so I checked the power plug and no result.
I then put the batter in and it booted up. I took the battery out and was able to boot it up, until I picked up the computer and it dies instantly.
When is was working I noticed that the fan was not operating.
So... is there a problem with the AC power connector on the computer... and have you heard of the fan not working?
Over time will the fan quit funntioning if too much heat builds up?
Is there a part of the circuit that will "kill" the fan if there is a problem with the AC power?
  • 404 Answers
Fans can die without any reason that's possible and because of that your laptop is shutting down due to overheating because the processor isn't being cooled so you may need a new fan (but test the pin if there is any voltage there). it could be the motherboard not giving any power to it.
you may also have a problem with the DC socket not charging your laptop thats easy to test, plug the charger into the laptop with the battery and without switching it see if there is an amber light that shows the ac is fine.
Posted on Mar 02, 2009
Gateway GT5468 will not boot power light fan runs thats all
The power-supply must output several different voltages.
If it is partially broken, then only the power-lamp and the fan(s) will spin. Replace the power-supply
Feb 09, 2015 | Gateway GT5468 Desktop PC
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway MT 3422 problem
There has been a lot of problems/ complaints about this particular product. That is why I always recommend HP notebooks.
You can take it to a service centre where they deal in Gateway products but I bet you might need to replace your motherboard.
Good luck.
May 21, 2009 | Gateway MT3705 Notebook
Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Apr 26, 2009 | Gateway 500GR PC Desktop
Ijust replaced the cpu fan and now the computer won't boot - it just flashes the gateway logo
make sure that the power reqs for the fan are the same as one you replaced and make sure that the new fan is the same prong (3 or 4). Also make absolutely sure you plugged the new fan power supply inti the CPU fan slot
Apr 15, 2009 | Computers & Internet
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
Gateway MX3231 won't boot and I just bought a new power adapter
Based on what you have stated, it looks to be your AC connector that is loose or broken from the motherboard. This connector just needs to be soldered back onto the motherboard. Have a technician look at this before you start spending money on a new battery.
May 07, 2008 | Computers & Internet
I believe you power supply is bad and needs changing,,
however try this first before changing the power supply
unplug your system.
1.) Open up the computer
2.) remove the memory
3.) Remove the mainboard battery 4e78012.jpg see the silver pin to the right> pull that ayaw from the battery and it will popout
4.) hit the power button 5 times
5.) put your memory and battery back in
6.) put your powercable back in and try booting it..
Jan 18, 2008 | Gateway GM5072 Desktop PC
Gateway MT6707 Notebook PC Logo
189 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
