Recently found that my previously functional Sharp DV-600 DVD player at first would not work. Then just sound, but no video. I bought it used so I have no user guide. What can I do to correct this problem?
  • 4 more comments
  • corv60 Mar 02, 2009
    Yes, I did touch the red, white and yellow connectors. I disconnected them and then checked for proper connections. That is when I got sound only! This DVD player worked fine on a previous TV set, but now I have different (old, used) one. I looked all over the web to find a user guide without success. I could sure ue one. Evidently, Sharp discontinued these user guides due age of product
    about 9 years old!). What TV station are you supposed to have TV on while using this? I have tried all from 01-50. All of them will get sound only!
    Tried pressing stop button with no success.
    Does anyone else have any ideas as to why I am getting no video on my Sharp DV-600 DVD player?
    Remember, I bought this second hand. It did not come with any software. As for the procedures you are referring to, I am lost!
  • corv60 Mar 03, 2009
    Have yet to get answer to no video on my Sharp DVD player that solves the problem! Can anyone else please help?
    Am not presently at home where DVD player is located, but I am confiedent that this guide, which I was not able to locate on the web, will solve my problem, so I am accpeting this solution with my thanks to you!
  • 19,396 Answers
Hi, nice to know that you hare happy with a support given. Surely the users manual will help.
However I wanted to suggest double checking the cables at the back, unplugging and plugging them back, and eventually testing alternative video cables.
The cables and connectors are the most common cause for problem of this kind.
Check also your TV settings following the manual.
I
Posted on Mar 04, 2009
  • 479 Answers
If checking the cables did not work then this is the lens issue so get it checked by a professional.
Posted on Mar 03, 2009
  • 6,784 Answers
  • Check power and to see if the disc is inserted right side up.
  • Clean the disc if dirty with a soft lint free cloth. Do not wipe in a circular motion. Your may also cleaner with a disc cleaner, available at your local dealer.
  • If there is condensation in the unit, turn it on for 1-2 hours before using the unit.
Posted on Mar 02, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters Mar 02, 2009
    • 4:3 PS – (Pan & Scan mode) When wide screen
      video material is played, this mode clips the right and left sides of
      the image so that it can be viewed on a conventional TV screen.
      Some wide screen DVDs that do not permit Pan & Scan mode playback
      are automatically played in the letterbox mode (black bands top and
      bottom).
    • 4:3 LB (letterbox mode) When wide screen video material is
      played in this mode on a conventional TV screen, black bands appear at
      the top and bottom of the screen.
    • 16:9 (Wide screen TV) this is the correct mode for playing wide screen videos on a wide screen TV.
      You must also set the screen mode on your wide screen TV to “Full”.
  • Michael Masters
    3 or 4 are good channels for analog reception.
  • Michael Masters
    I would try using a coaxial(cable) for transfer. the input block seems to be malfunctioning.
  • 916 Answers
Check your connection cables make sure they are not loose. If you have another set of cables you know are working try those and see if there is a difference.
    Scholar:
  • 165 Answers
I think manual will help u do the diagnosis of problem as it has all the wiring and connecting procedures with pictures.download or view the manual for dv 600 model from link below: http://www.usersmanualguide.com/sharp/dvd_players/dv-600s
thanks.
  • 679 Answers
You could reinstall the software, unless you reformatted, the files should still be on your machine. If you deleted them with one of those Reg Cleaners, just re install, try this first. Start, control panel, system, devive manager, hardware. Locate drives press the plus sign to expand, and highlight the DvD driven click uninstall. Then reboot, it will find the hardware and reinstall the software for it automaticlly, you should be good to go at that point, unless the files were removed from the machine, but try this first, Good luck
  • 10,594 Answers
I think your Sharp dvd player shifted to progressive scan mode and requires to set back in interlace scanning mode.
Please press STOP button for 5-6 seconds to cancel progressive scan mode.
  • Shahid Electronics
    Shahid Electronics Mar 03, 2009
    OK,
    DVD player has Yellow (video) Red and White (audio) output RCA jacks as rear.
    Please locate same combination of Input (1 or 2 or 3 etc) at rear of your TV and hook RCA cable yellow-red-white between TV and Player. Please double check yellow to yellow, red to red and white to white between TV and Player.
    Now turn your TV and player On and select TV Input ( where you hooked DVD Player) and put disc in dvd player press playback.
  • 13,433 Answers
Have you touched the connectors? if you haven't its probably failing, if you have something may not be properly connected.
If you want the user guide I can get that for you. Hows warranty?
  • Ekse Mar 02, 2009
    Please try welcomejees solution and can you double check the model number? look in the front, back, below, top.
  • Ekse Mar 02, 2009
    Could you also send your Tv Brand and model. Thanks.
Does my Sharp DV-RW34OU dvd recorder+vcr have microphone capability? If so can I purchase a compatible microphone online?
Ur Sharp DVD Recorder/VCR combo have any HDMI ports.Yes,Tries websites like Amazon.com,Ebay.com to buy a Digital microphone use the HDMI port it work fine.No tries researches buy the analog microphone.Just ask the vendors info.for the device functionable or compatible to ur device.
Jul 03, 2010 | Sharp DV-RW340U DVD Recorder/VCR
Sharp dvd codes
Of all the things, Google found the following in a Bulgarian text file..
Sharp DV-SL1500W
- switch on DVD player
- press eject (tray open)
- press stop
- press 734466
select 0 on OSD for region free
Aug 12, 2009 | Sharp DV-SL1500W DVD Player
Trouble recording to DVD - connections are not done right - Sharp DVD-RW340
I had to run from the RCA outs of my DVR into the inputs that are on the front right of the RW340...behind the little door.  Now I can easily record from live cable or from my Comcast DVR recorder.  Couldn't get it to work from the backside inputs.
Mine is just the DV RW340 (no U).  And yes, the manual is brutal.  We had to call tech support to find what disc will actually work in the darned thing.
Now my big problem is finding more 4x DV-R disks. Shoulda bought more when Comp USA was clearing them out a few years ago!
I have had great success with Dynex Model: DX-DVD-R25 discs.  And they play equally nicely on my Toshiba DVD player in the livingroom.   I have also given several away to people after I had transfered home videos to DVD and those people all had good results playing the discs that I made on my lowly Sharp Dv-RW340.
Sep 13, 2008 | Sharp DV-RW340U DVD Recorder/VCR
How to change to all regions on dvd player
easy type : Sharp DV-NC 100 dvd/video combo hacks in to google .
many pages will give you some ideas .
riz.
Nov 19, 2007 | Televison & Video
Sharp DVD disc error
I've found out that the recording speed is important for this model. The speed on the dvd must be 4x or less. If your using an 8x or 16x it will not work. Hope this helps.
Maybe you can help me. I'm looking for the 4 digit code that goes into the remote to make it compatible. I think it's in the operators manual, which I no longer have. If you can find this number I would really appreciate it.
Oct 12, 2007 | Sharp DV-RW340U DVD Recorder/VCR
No audio
Most of the time its the amps that are bad and need changing. This will be transistors on heatsink in the reciever. Part number should be on the amp.
Sep 19, 2007 | Onkyo TX-DS494 Receiver
Disc error
I have this same problem so I called Sharp.  This model is  a little older.  When you buy the disks there is a number with an X after it.  If you buy the - R disk the number has to be 4X or less,  for the -RW it has to 2X or less.  Apparently they can still be bought at Office Depot or online.
Aug 11, 2007 | Sharp DV-RW340U DVD Recorder/VCR
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
