Question about Casio G-Shock GW300CA-1V Wrist Watch
Cannot put the backing of my casio wrist watch back on,do I need a special tool?
  • jaiarussi May 11, 2010
    it should have screws if it's digital. if it pryed off, then you have to have a special tool to force it on. a watch repair shop should help you.
  • 2,334 Answers
No, you do NOT need a spec tool. All you have to do is to reassemble watch strap completely(with all the bits and pieces, insl. wings, armour,etc).
Posted on Mar 03, 2009
How do I replace the battery, in a Casio G-Shock G-2300 9V watch?
Your watch is a solar powered watch and normally you don't need battery change .Nevertheless,if (as it is an old Casio model),you are convinced that battery is the cause of your problems,then replace.
1) You have to be absolutely sure that you are able to carry out the procedure.
2) IMPORTANT!! Pse note that the specific battery IS NOT an ordinary battery as it is rechargeable.DO NOT TRY TO REPLACE WITH AN ORDINARY ONE.RISK OF EXPLOSION on your wrist.+total damage of the watch.New battery has to be exactly the same with the old one (ID.code).Can be ordered on E-Bay,I suppose.
3)TOOLS:Watchmakers screw drivers + philips small size screw driver (for backcover screws) + watchmaker tweezers + 2 finger rubber gloves.
Turn the watch upside down and carefully remove the four screws (try not to loose them).Remove the strap if needed.Gently remove the back cover.Pay attention as there must be 1 or 2 tiny springs embeded on the mechanism.Keep them in place and try not to loose them.You have to remove the plastic cover (pay extreme caution to the spring/s) in order to have access to the battery.Unlatch and remove (if needed) the battery holder ( if can be removed-remember the position to put it back correctly).Take out the battery and check for possible leaks.Check the battery compartment cleaness.DO NOT TOUCH WITH BARE FINGERTIPS THE CONTACTS OF THE BATTERY COMPARTMENT.DO NOT TOUCH THE NEW BATTERY ON BOTH SIDES WITH BARE FINGERTIPS.Use the finger gloves.Put the new battery in place (do not force) and secure back the battery lamina holder.There is a AC(All clear-reset) contact on the mechanism.Using the tweezers touch one end on this contact and the other to the metallic body of the mechanism.Lift the watch very carefully(as it is,upside down-without disturbing spring/s) and check if display is activated.By paying much caution put back the plastic cover correctly in position PAYING CAUTION TO THE SPRING/S. Clean up the back cover,gasket,and gasket furrow from dirt as good as possible.Check the gasket condition.Replace if needed.Apply a little amount of special gasket silicon compound all around the gasket,both sides.Put the gasket in place.Put back gently the back cover and screws in position.MAKE SURE TO POSITION THE BACK COVER CORRECTLY(in place and not upside down).Press it gently when in correct position before you screw.CHECK ALL AROUND FOR CORRECT CONTACT. DO NOT SCREW TOO TIGHT,DO NOT FORCE.Screw with fingertips until you meet resistance.
I hope this will help.
Jul 04, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
Adjust the bracelet
There are tiny pins either side of the wrist band next to the clasp. Remove these pins and you can take out up to two links (and a half link on some models.)
A jeweller could do it, needs a special tool to tap them out and put them back
Nov 03, 2013 | Rolex Oyster Perpetual Submariner Date...
How do yu remove raymond weil watch strap pins?
It depends on the strap as there are several different types.
But I suspect the one you have has pins that go through the whole metal wrist band.
You need a special tool that pushes out the pin, these normally only come out in one direction.
There should be very small direction arrows on the back of the strap if that is the case.
When putting them back in again they must go in the correct direction.
Look on ebay for wrist watch strap removal tool, looks like a mini vice with a small handle and pin pusher the other end.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Watches
How do you set the analog and digital time on the casio aw-s90 wrist watch?
you can get
instructions from the Casio web site.
Go to the casio web site "".
Select "support" and the "manuals",
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Oct 03, 2010 | Casio AWS90-9AV Wrist Watch
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How to adjust ******** Casio 2519 A179W watch
I presume that you have not got any instructions for the watch.
You can download a copy for your watch if you go to the Casio web site (, select "support", then "manuals", then "watches" and then after "agreeing" , select "watch manuals archive" and put in the information off the back of your watch.
Jan 20, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Replacing watch band on pathfinder pas410. can't get pins out to replace band.
Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
Rate me, plz.
Jan 08, 2010 | Casio Pathfinder PAS410B5V Wrist Watch
Need to remove back of watch
If you are shure that your watch has a removable caseback then you have to use special case opening tool (looks like knife with very short and curved blade). Insert blade into the groove and applying great and steady pressure turn the opener upwards. The back should come off. Make sure the blade doesn't slip, oterwise you will damage the movement.
As your watch model is obsolete, I compared it to MQ24-7BLL and find that this movement should be opened from the front- First the glass must be removed, then stem with crown and then movement itself. In this case you will not be able to do it yourself as special tool for removing glass is needed. If you will try it anyway, you will end up with snapped glass as it is set with great pressure to make case water resistant.
Dec 16, 2008 | Casio MQ24-7B2 Wrist Watch
Casio prg60-1av
go to another website like watchuseek where it's free!!
fixya didn't help me at all!! beware they are trying to make money by making you pay for the "premium" service!!!
Apr 05, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio WS300B-1BV Wrist Watch
Punch in the 4 digit module number found on the back of the case.
Jan 18, 2008 | Casio WS300B-1BV Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
96 people viewed this question
Top Casio Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
