Question about Bosch 15 Amp 14" Concrete Cut-off Machine/saw 1365
I need replacement switch for bosch 14in 1365 concrete saw
I need replacement part for my bosch 1365 14in saw.
    Problem Solver:
  • 16 Answers
You can order it from boschtoolsservice.com
Posted on Mar 10, 2010
Want to buy a hand held circular saw
1) Buy the most expensive, name-brand saw that you can afford, from a store that has been selling tools for a long time.
2) Remember: Price is almost always an indicator of quality in power tools! Stick with Bosch, Porter-Cable, Makita, DeWalt, Ryobi or another of the "big names."
3) Be sure the saw you buy has a motor shaft lock; it will make blade changes much easier and safer.
4) DON'T buy an extended warranty unless you are going to be doing work that you KNOW will damage the saw (cutting concrete or metal, cutting dirty wood, etc.).
Nov 28, 2017 | Saws
Bosch circularsaw flips breaker
Did you replace cord and switch to fix the problem, or has the problem occurred since replacing parts?
Definitely a short somewhere, and if you replaced parts because of the problem the only other thing has to be the motor.
Feb 18, 2013 | Bosch 7-1/4 Worm Drive Circular Saw
How to repair a water pipe leak under a concreat slab
Things to consider are cut and replace -1. Concrete saw the affected area replace and re-concrete (impact hammer is another option but a concrete saw is neater and you can control the cut better.. 2. You can bypass the pipe. 3. Dig under the slab - you obviously would need to be near an edge.
Jan 18, 2013 | Brett Plummer Android Apps
Looking for a short curcuit wire
If you are referring to the wire that kills the engine it will be attached to the coil at one end and the on/off/choke lever/switch at the other end. If you need to replace it then contact a Stihl dealer.
Aug 13, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
Motor replacement for Bosch Mitre saw
Most often the entire motor doesn't go bad. It would be a componen't like armature, field, brushes, Switch. I very seldomly see a whole motor go bad. look for a single problem. The saw is not junk it is very repairable with some testing of parts.
Jul 12, 2010 | Bosch 10" Slide Miter Saw
Bosch 4000 table saw will not start. I changed the switch and still won't start, not even a sound. The saw is relatively new, and the outlet works. What should I try next?
A real Weakness of this saw is sawdust and debri entering the cooling ports of the motor causing intermittent contact of brushes which damages the motor speed control board ($40.00). Don't ever operate this saw with out a vacuum saw dust extraction system. Also when you replace the Speed control board also replace the Brushes ($6.00). It helps extend the operational life of the motor components to blow out the contaminants regularly with compressed air through the motor cooling ports (turn off saw first).
You can bypass the speed control board (if you want to disable this wonderful engineering feature by attaching black and white power wires directly to the black and white wires to motor.
Feb 22, 2010 | Bosch 4000 - 07 Electric Table Saws
Have pole with 8inch saw and will it work for 14in saw
If you have a Remington pole saw, then no you cannot not get a bigger saw to fit the pole you have. The pole was only designed to fit and support the weight of the saw it came with.
Apr 23, 2009 | Remington Polesaw Wizard
Bosch 15 Amp 14" Concrete Cut-off Machine/saw 1365 Logo
161 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
