Question about Sharp Office Equipment & Supplies
Sharp Copiers Error code : F1-14 - Sharp Office Equipment & Supplies
I was making copies through the document feeder and got the F1 error, and it's blinking and I can't make copies. Any ideas? Thanks!!! Christine
Posted on Sep 29, 2009
  • 37 Answers
The code F1-14 is stack tray problem, if your machine is AR-280, AR-285, AR-335 and series of these models try these steps:
Step1: Press continuously PROGRAM then press Interrupt then press Clear then Interrupt
Take note: ( Pause = Interrupt )
Step2: You are inside the simulation if the display turns off but if not do again step1.
Step3: Press 14 then press print button
Step4: If not canceled try step1 to step2 again then press 15 then press print button, also try 16 and 17 if not canceled
Posted on Mar 03, 2009
3 Suggested Answers
mickspaceNET
  • 115 Answers
SOURCE: Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
Posted on Nov 22, 2008
goodgold
  • 389 Answers
SOURCE: error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Posted on Sep 24, 2009
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
Clearing service man on 5320 sharp copier
Hello, NICOLAS
Let me give you, a url when you can find sharp error codes and fix by youself, if you have any other cuestion, please write a comment, im here for help you.
How to solve the h4 subcode 00 error message on sharp AL-2030 copiers
http://www.en.rellenadodecartuchos.com/2014/05/how-to-solve-h4-subcode-00-error-message-on-sharp-al-2030-copiers.html
thanks for comment if need more help
Nov 16, 2015 | Sharp Office Equipment & Supplies
H5-01 ERROR CODE
The following is from the Sharp website on error codes: SHARP MX M503N ERROR CODES Trouble Codes
H5 01 = 5 TIMES CONTINUOUS POD 1 NOT-REACH JAM
Mar 03, 2015 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
Drum error code
Hi, drum error codes in digital sharp copiers are non-existent. May be drum error symbols or display messages on touch screen types. They differ depending on model but the most common is reset code 24 sub 7 for example sharp 5015 you rest by pressing; C,Interrupt, 0, Interrupt keys and then inputting the above keys. You may specify your copier model.
Dec 14, 2011 | Sharp Office Equipment & Supplies
Error f1
Sep 23, 2009 | Sharp SF 2020 Copier
Sharp SF 2020, how to clear F code
GO ON LINE AND TYPE THE FOLLOWING:
SHARP SF2020 COPIER ERROR F CODE
ENTER
OR
WWW.SHARP.COM/COPIERS
ROD
Feb 10, 2009 | Sharp SF 2020 Copier
Error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
820 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
