Question about HP PSC 1315 All-In-One InkJet Printer
I just changed my ink and my printer wont even light up, the only thing that lights up is an exclamation point next to the pictbridge port
    Problem Solver:
  • 5 Answers
Look for papir jamed on a copy string and inn the door is a smol pices that is blocking contakt
Posted on Mar 02, 2009
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
The ink cartridge holder will not move across the machine as usual. The COPY light is lit, also a red exclamation point. I cannot make copies or print from my computer There is an error message: Printer...
You could try a couple of things - firstly, check to see if there are any foreign objects stopping the cart from moving - this happens regularly, even lollie wrappers can stop it! I once found a comb in a printer!
Secondly, you could try unplugging the printer entirely, turn upside down and give a firm shake, this will assist in clearing debri.
Or finally, Phone 0800 2 EPSON (NZ number)
May 13, 2010 | Epson Stylus C64 InkJet Printer
The light next to the exclamation mark on the front cover is on -- What does this mean?
This means there is a problem with one of your ink cartridges or one is missing. Change the cartridges and it should stop blinking. Hope this helps. Cheers.
Oct 02, 2009 | Lexmark E250dn Laser Printer
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Changing ink carthrige
hi try to clean the contact point of ink and ink carrier.if it's not work 2 thing you need to consider....
1.maybe your ink is not compatible or not detected..
2.maybe your ink carrier is most likely defective.
hope this would help you...
Oct 27, 2008 | HP DeskJet 820cxi InkJet Printer
Yellow Light on HP K550 indicating open panel will not turn off.
If the printer is connected to your computer - check to see if there is a blinking Red exclamation point / printer icon in the system tray. Sometimes mousing over this icon to see the tooltip is the only way to figure out what error message the printer is trying to tell you.
For us - when this happens, the printer is complaining about an "incompatible" ink cartridge - even though 99% of the time it will print from that cartridge without problems. So try removing and re-inserting all of your ink cartridges too.
Sep 30, 2008 | HP OfficeJet Pro k550 Printer
Dell 962 all in one printer
the yellow blinkin exclaimation point is usually an indication that there is a printer cartridge problem. It usually means the ink is low.
Mar 08, 2008 | Dell 962 Photo All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
117 people viewed this question
Ben Johnson
