Question about HP iPAQ H5550 Pocket PC
How do i do a FULL RESET on my ipaq 5550
How do i do a full reset
  • HP Master
  • 13,433 Answers
Hey,
instructions are here
http://geopocket.org/AngellHallAudC/ipaq_5550.htm
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 02, 2009
I FORGOT MY PIN CODE.
Posted on Oct 08, 2009
2 Suggested Answers
  • 36 Answers
SOURCE: hp ipaq 5550
To do a full reset, you hold the calendar and itask buttons (buttons 1 and 4) down at the same time, then insert the stylus into the little hole on the bottom and press gently. Hold all for 4 seconds. The screen should begin to fade. Now release all. If successful, you will not be able to start the machine by pressing the on button. You will have to reconnect to ac power to start it.
That is all there is to it.
Posted on Mar 09, 2009
I forget my password....so how should i break it?
the password can not be broken, but you can perform a hard reset that wipes the device clean including the password. all content is lost.
1. Press and hold the lower left and lower right buttons.
2. Press the Reset button on the bottom of the iPAQ Pocket PC
with the stylus.
3. Hold all buttons until the displayed image begins to fade
(approximately four seconds).
4. Release the program buttons and stylus.
You can verify a full reset by pressing the power button. If the
iPAQ Pocket PC has been fully reset, it will not turn on.
5. Reactivate the battery by doing one of the following:
Connecting the iPAQ Pocket PC to AC power
Pressing the Reset button with the stylus
Nov 06, 2010 | HP iPAQ H5450 Pocket PC
On IPAQ hx2700, how do I do a hard reset? I want
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
IPAQ 5550 can I override the pin number?
Simple Solution:
Perform a hard reset and then attempt to login repeatedly (10x).
You will then be prompted if you wish to reset the pin entirely.
Good luck,
-AndyPants-
Jun 15, 2009 | HP iPAQ H4150 Pocket PC
Hp ipaq 5550
Jan 24, 2009 | HP iPAQ H5550 Pocket PC
HP H5550 keeps going blank and wont restart
See manual for 5550 from hp.com for description of how to do hard reset. You can download it.
Jul 16, 2008 | HP iPAQ H5550 Pocket PC
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
Jun 22, 2008 | HP iPAQ H5550 Pocket PC
Full Reset
You need to press buttons 1 + 4 + Reset until the screen turn off, after that wait for 60 seconds and press the reset button again. remember that hard reset erase everything from your ipaq like personal information, programs that you installed, etc.
Xracer
Dec 05, 2007 | Compaq iPAQ H3955 Pocket PC
IPAQ 5550
Performing a Full Reset A full reset is sometimes referred to as a ?hard reset.? Perform a full reset when you want to clear all settings, programs, and data from RAM. A full reset deactivates the battery. The power button does not function until the battery is reactivated. CAUTION: If you perform a full reset, your iPAQ Pocket PC returns to its default settings and loses all information that is not recorded in ROM. To perform a full reset: 1. Press and hold Application Buttons 1 (Calendar) and 4 (iTask) on the front of the unit and, at the same time, use the stylus to press the Reset button on the bottom of your iPAQ Pocket PC. 2. Hold all buttons until the displayed Full PDF document can be found here: http://h20000.www2.hp.com/bc/docs/support/SupportManual/lpia8006/lpia8006.pdf
Aug 19, 2007 | HP iPAQ H5555 Pocket PC
Ipaq RZ 1710 won't switch on
If you've backed up your PDA, I'd strongly suggest trying a hard reset. This has happened before to one of my RZ1710 pda's. The only solution was to hard reset it. This can be done by pressing the two extreme left and right buttons (The Calander, and Home button) and the reset button on the bottom of your iPaq with the stylus.
Sep 11, 2005 | HP iPAQ RZ1710 Pocket PC
HP iPAQ H5550 Pocket PC Logo
594 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
