Question about Canon PIXMA MX310 All-In-One Printer
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
  • Canon Master
  • 19,396 Answers
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Posted on Mar 07, 2009
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Canon Expert
  • 307 Answers
Costco and Fry's Electronics (along with a few Best Buy Canada stores) utilize the BEST industrial refilling equipment found in the world today. With over 1800 trained personnel in USA/Canada/Mexico and some UK stores you will get a high quality refill while you shop, with typically 10-20% extra ink volume in each refill, at a fraction of the cost compared to an OEM ink cartridge.
Costco Ink Refill Price List:
http://www.costcoinkjetrefill.com/pricing
Please visit Inkjet411.com for any other inkjet printer refill support questions or general printing problems you may encounter:
http://www.inkjet411.com
Posted on Jul 25, 2013
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
Tip
How to refill the INK Cartridge ?
How do i refill my INK Cartridge ?
There are 2 distinct method
1) Black has a bladder
2) Color contains sponges - we need 3 sirenges with needle
to fill the Color cartridge with sponges - simply punch
COLOR CARTRIDGE
1. If you see the Cartridge turn it round and locate the filler holes by removing the plastic top cover of the cartridge.
You may need to pry plastic top or hole cover off using a thin metal blade.
please make sure that you do not damage the sensors on the back of the cartridge whilst doing this.
2. Using the picture(on the cartridge which shows you the 3 differed colored spots), fill syringe with the corresponding color ink.
3. Insert the syringe into the correct hole of the color being filled and push all the way down.
Notes : You will feel resistance as there is a sponge inside.
So Slowly inject approximately 8ml of ink until you can just see the ink surface on the top of the sponge, any more and it is over-filled.
If this happens simply draw back on the syringe a little.
4. Rinse the syringe and needle thoroughly before proceeding then repeat the process for the other colors.
8. Re-attach the cover securely with adhesive tape and continue using the cartridge.
BLACK CARTRIDGE
1. Fill the syringe with approximately 20ml of black ink.
2. Push the syringe all the way into the filling hole and SLOWLY inject all the ink into the cartridge or until the reservoir is full.
3. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
4. If necessary leave cartridge in printer for up to 24 hours. (This allows ink to flow to the print head).
on Jan 04, 2010 | Office Equipment & Supplies
I don't know how to refill?
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover.
2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle.
3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta.
4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole.
5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel.
6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
Aug 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
HOW TO REFILL
I love to give the answer for your question but we don't know which printer model you are talking ?
Following the the common procedure for refilling the Ink Cartridge
COLOR CARTRIDGE
BLACK CARTRIDGE
Jan 22, 2010 | HP Office Equipment & Supplies
How do i refill my cannon mx300?
Go to this link. In the search window in the center of the screen, type "replace ink" and click on the Search button. Now select "how do I install the ink cartridges". You will have an illustrated guide (removing cartridges is shown at the bottom).
Aug 20, 2009 | Canon MX300 Office All-In-One Printer
How to refill canon pixma ip1600 ink colour? the hole is too small.
IF YOU HAVE BUY THE INKS THEN YOU GET NIDLE AND SIRING THEN YOU WILL USE THE TECHNIC DOCTOR USE TO SWAP THE LIQUID FROM THE CONTAINER AND INJECT IT IN THE BODY YOU WILL USE THE SAME TECHNICS GET THE INK IN TO THE SIRING AND PUT IT IN THE CARTRIDGE BUT MIND YOU LOOK AT THE HOLES VERY WELL RED HOLE WILL BE MARK RED, BLUE WILL BE MARK BLUE WHILE YELOW WILL BE MARK YELOW SO ALL YOU NEED TO DO IS FOR YOU TO PUT THE INK IN THE RIGHT HOLE IN SOME CARTRIDGE THE HOLES WILL GUIDE BY A OBJECT REMOVE CAREFULLY THEN AS YOU FINISH REFILLING EACH HOLE PUT THE OBJECT BACK.
Nov 13, 2008 | Canon PIXMA iP1600 Printer
Refilling a cartridge
You need to use a very thin needle (25 gauge medical needle works well) on a syringe. There is a tiny hole in the canon 40 cartridge under the label which you need to fill. To refill the color cartridge (canon 41) as you look at the cartridge, the hole at the top is magenta, the hole to the left is blue and the hole to the right is yellow, use a separate syringe and needle for each color. Every now and then you will need to use some cartridge cleaner to soften/clean the sponge in the cartridge. I use 0.5cc of cleaner then let sit overnight before adding ink. You need to be sure the label is replaced well or use good tape to keep the ink from escaping.
Sep 06, 2008 | Canon PIXMA iP1600 Printer
Refilling an ink cartridge
The holes are under the top label - I'm not sure which hole is for which colour.
Apr 11, 2008 | Office Equipment & Supplies
Cannon IP1800 Ink Refill
need to know how to refill the cartridges. I don't see a place to refill them. It is cheaper for me to buy a brand new printer than it is to buy the new cartridges when the ink runs out. Thats crazy.
Nov 27, 2007 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
1,084 people viewed this question
old marine
old marine
