Question about Philips 55P8341 55" Rear Projection Television
55" Phillips Projection needs coolant changed
I have a 55" Phillips projection and the color is getting pretty bad. I had someone come look at it and they said the coolant needs to be changed. I found a kit on the website listed below and wasn't sure if I really needed everything they offer in the kit to replace the fluid or if I can just change the fluid with out replacing any parts. I'm not sure what the best way to do it is and I was wondering if someone could help me. I would like to know what I should get or need to fix my TV and I want to do it so it will last to the fullest extent. Thank you.
    Problem Solver:
  • 4 Answers
GREEN AND BLUE IS MOST POPULAR TO GET OIL DIRTY SO,YOU NEED TAKE ONE BY ONE DISCONECT FIRST ONE TAKE OFF ITS EASY OUTSIDE GET A SPRAYER AND **** THE OIL AND AFTER THAT OPEN THE PICTURE SEPARATED THE LENS AND CLEANED
Posted on Mar 02, 2009
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
55
755
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your conver55" Phillips Projection needs coolant changed - 2c07611.png are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look d55" Phillips Projection needs coolant changed - 578ba6c.jpgange, etc. You may even see halos around images.
Picture of a s55" Phillips Projection needs coolant changed - 65af323.jpgds the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 22, 2009
I have a Phillips 60PP9202/17F rear projection TV. its getting worn. The overall picture seems to have a slight haze and also seems to have lost the color contrast. yellows and whites are very similar and...
Thats most likely a CRT coolant issue where you will need to remove and replace the coolant in the CRTs ( picture Tunes) Thats a very common problem with Phillips rear projection. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for a 3 CRTs and the CD with instructions.
Jul 22, 2011 | Philips Televison & Video
I have a 52 or 55 inch phillips magnavox ptv 805 rear projection tv but the color isnt right on it everything else works fine i can see the picture fine but its just the color what can i do
Thats a common problem caused by the CRT coolant needing replacement. The Phillips CRT coolant kit is available from www.tvrepairworld.com which contains the coolant and the CD with instructions.
Jun 30, 2011 | Televison & Video
We have a Phillips rear projection tv, about 9 years old. The color has been getting progressively worse over time. Dark scenes are almost impossible to see. It almost seems that only blue and red are...
Tv have halo pictures and dulls colors?Yes,the tv have bad Coolant chemicals on those colors guns R,G,B CRTS tv Tubes.Must replaced those CRTS Coolant chemicals on those CRTS tv tubes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced those CRTS tv Tubes coolant chemicals.
Nov 13, 2010 | Philips 55PW9363 55" Rear Projection...
The color on my 55
Change the coolant fuild in R/G/B Tubes.
Dec 30, 2009 | Philips 55PW9363 55" Rear Projection...
Picture seems to be losing its sharpness and colors bleed
most likely scenario is that the coolant in the CRTs need replacement very common problem with phillips magnavox TVs, The picture will get hard to focus and the color will lose its intensity. You can get a coolant replacement kit for phillips at the following link under the repair kit category. The kit contains all the coolant needed and a CD with step by step instructions on how to do the repair. Heres the link.
http://servicemanuals.vstore.ca/
Feb 08, 2009 | Philips 55PP9401 55" Rear Projection...
Clearer HDTV picture?
quite possible that the coolant is getting contaminated as thats a normal occurance with phillips after a few years. If the color seems dim and not focusing properly its almost certain that the CRT coolant will need changing
Dec 28, 2008 | Philips 55PW9363 55" Rear Projection...
Phillips magnavox 55" projection
The coolant needs to be changed in the CRTs ( picture tubes) this is a very common problem with all phillips and magnavox rear projections. Changing the coolant will restore the color and brightness and stop the halo effect. You can get the phillips CRT coolant kit at the following link and it includes all the coolant and the step by step instruction CD with pictures. Its actually a fairly easy job. Heres the link its listed under the repair Kit category.
Oct 14, 2008 | Televison & Video
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
Help
Change the CRT coolant in the green and blue tubes thats a comon problem with that model. You will be amazed at the results that changing the coolant will have on color, it will make it look like new again.
Jun 13, 2008 | Philips 55P8341 55" Rear Projection...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
465 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
