Question about Uniden Cordless Phone
Programming numbers into GE cordless telephone
    Problem Solver:
Thanks anyway, but I figured out how to program my telephone WITHOUT a manual by pressing different buttons.
Posted on Mar 03, 2009
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
I have lost my user manuel and I need to reset my Base GE5.8GHz I have a GE 5.8 GHz cordless phone system
Your system must have been rebranded by GE since their page for telephone manuals doesn't have the number listed you gave:
GE Phone manuals
In case you made an error in the model number, you should be able to find your manual there.
Aug 25, 2009 | GE 21091GE3 2.4GHz Dual-Handset System...
Need help programming autodial feature on my ge-27923-ge cordless phone
how do you change GE Model 27923 2.4 GHz cordless phone from pulse dial to touch phone dial? I lost my instruction manual Thanks
Apr 15, 2009 | Lands Phones
Can I use cordless phone answering machine even if I have voicema
You do not have to cancel the phone company voice mail service. You need to change the number of rings the phone uses to answer the voice mail.
For example, if the telephone company voice mail answers if 4 rings, set the telephone answering machine to answer in 3 rings or less.
Good luck.
joequevedo@charter.net
Mar 03, 2009 | GE 27992GE5 Cordless Phone
Unable to Program Telephone Numbers
you don't get your answer on Internet. if you want to take my opinion then just learn all the numbers by heart.
Jan 24, 2009 | Uniden Cordless Phone
Caller ID telephone GE 25922 5.8 GHz Cordless
I dialed my own phone number and that accessed my voice mail.
Feb 18, 2008 | GE 25922 Cordless Phone
GE 5.8 ghz cordless phone
Get another telephone and connect the telephone cord from your cordless phone to it. If it works, then you know the problem is with your GE cordless phone. If it doesn't, try replacing the telephone cord. If still no good, call your telephone company.
Nov 05, 2007 | Uniden Cordless Phone
AREA CODE
Just purchased the GE 25922 today. Looks like you can skip (ignore) the option to enter an area code.
United States' Area Codes are three-digit numbers. If the phone 'requires' entering a number you can use any three digit number. The purpose of this option is to display a local telephone number with only the 7 digits.
Example:
603 - 123 - 4567
'603' is the area code
123-4567 is the 7-digit local number.
If the area code option is programmed to '603', then if that number called '123-4567' would display on the Caller ID display.
Which now reminds me: you would need to also subscribe to Caller ID with the Telephone Company for the numberic display to occur.
Oct 27, 2007 | GE 25922 Cordless Phone
GE 21008GE2-A Dual-Handset cordless phone
Here's what seemed to work for me.
Hit the button that says ringer. then hit the number 1
then hit the button marked program (it is also the
mute button). Some combination of those moves
helped me go from Ringer OFF to Ringer ON.
Rocky on the River
Aug 15, 2007 | GE 21008GE2 Dual-Handset Cordless...
Uniden Cordless Phone Logo
73 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
