Question about GE Microwave Ovens
GE Profile JE2160BF 03 microwave...purchased 07/07...keypad buttons 7,8,9 suddenly stopped working...what's broken?
  • William Miller
    William Miller May 11, 2010
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work,
    leave it unplugged for about 5 minutes. Then let us know if the hard
    reset does not fix it.
    Is it possible that some
    spray cleaner accidentally got into the controls?
    Direct spraying of
    cleaners on the keypad and steam from the
    cooktop can damage the controls.
    I always recommend that you spray non-ammonia
    cleaner on a
    soft cloth (not a paper towel which can scratch) and gently wipe the
    And I always recommend that you use the vent fan when cooking on the stove top to keep heat, steam, and
    grease out of the controls.
    If it does not dry out
    over time, it may need to be manually dried or blown out.
    The keypad may be
    damaged or worn out, or control unit may be damaged.
    Let us know what you find and we'll take it from there.
SOURCE: GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Posted on Sep 21, 2006
  • 19 Answers
SOURCE: GE Profile Spacemaker XL1800
pull the cover off of the microwave and check for anything loose. ie fan bracket covers. check the 4 nuts that hold the magnatron in also. if that doesn't fix it maybe you can go to an appliance repair place and see if that have a magnatron tester which is just a piece of plastic with 4 bulbs in it and if the magnatron is working properly with that tester in the it will look like a red strobelight going off in the microwave. if not then your rumbling noise is the magnatron getting ready to go out good luck
Posted on Dec 30, 2007
SOURCE: I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
Posted on May 28, 2008
SOURCE: GE Profile over the range microwave
I have a GE space maker the model number is JVM1860.
Same grinding sound when truntable is turning. Stops when you turn turntable off.
Can this be fixed by a layman?
Posted on Jun 10, 2008
  • 9098 Answers
SOURCE: How to replace keypad on LG Microwave
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
Control locked
Press and hold the stop button for 5 seconds.
Feb 17, 2013 | GE Profile Spacemaker XL 1800 36"...
GE microwave suddenly stopped. Plug is OK, fuse not blown. Is there a way to reset?
No! if your microwave oven is 7 years old or less it will most likely have a inverter board that often causes trouble, or the keypad control board is defective.
May 17, 2012 | GE Microwave Ovens
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Microwave simply stopped working. Initially thought it was the fuse. When I opened the casing, I saw that the cord had burned-off at the contact point in the images. Fuse is still good. The unit is...
you can obtain ge components from are a GE parts supplier...if they don't have it...then try the way... I would change the whole assy.
Mar 28, 2011 | GE JVM1653 Microwave Oven
My microwave GE Profile Spacemaker 2.0 keypad does not work, I unplugged it and reconnected it and it works at times for a while then it stops again.
You have a failing membrane keypad.
To help you further, I would need your brand and the full model number from the tag on the unit.
It's best to repost a new message to FixYa or contact me directly.
Dec 31, 2010 | GE Profile Spacemaker Over-the-Range...
Microwace buttons suddenly stopped working. Only
Your membrane keypad is failing.
Contact Danby Customer Service US / Canada
If you;re not from the US or Canada, consult your owner's manual or the dealer you purchased it from to contact Danby to find find your nearest Danby servicer.
Jan 14, 2010 | Microwave Ovens
GE Profile Microwave Keypad
I have the exact same problem at exactly 12 moths and 22 days. Just out of warranty, wouldn't you know. Sears says it will be $150 just to show up. What a piece of junk.
Sep 12, 2009 | GE JE1540 Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave Ovens Logo
137 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
