Question about Maytag Atlantis MDE7400AY Electric Dryer
There is a lot of lint below the trap. I want to vacuum it out. How do you remove the holder for the lint trap ? Can I do it by undoing the screws at each side of the trap holder ?
I have the same problem. If you find out the solution, please let me know. donjo1943@yahoo.com
Posted on Mar 02, 2009
How do I get into my whirlpool duet front loader dryer to clean the lint out
Hello. First, turn the power off to the dryer or remove the power cord from the AC outlet. Next, locate the 2 screws in-between the upper and lower front panels and at the bottom front of the dryer--there will be 2-3 screws, usually 1/4 inch hex head, and remove them--use a magnetic nut driver, it makes it a whole lot easier! (note:sometimes, to replace the panel, you have to push up on the bottom of the panel hard to get the screw holes to line up again.) Set the panel aside. Open the dryer door and remove the lint screen from the holder. Close the door. Next, notice the blower housing cover, pic 3, #45, lower left corner. There should be 3-4 screws holding the cover to the blower housing. Remove the screws and cover--use caution--most metal edges inside a dryer are unfinished and razor sharp--akin to putting your hand inside a box of razor blades(ask me how I know this, lol). Remove any lint build-up inside the cover with a vacuum. Again, using a vacuum, suck out any lint from inside the blower housing and fan as best you can. Take care to not damage the fan blades! Now, try to remove as much lint build-up as you can with the vacuum. Be especially careful when vacuuming around the mouth of the heater element. Do the best you can. At this point, re-assemble the dryer using the reverse of assembly. If there is still a lot of lint inside the cabinet and you can't reach it--STOP! In order to remove the remaining lint requires removal of the front bulkhead(large metal plate that supports the front of the drum), drum belt, and drum from the cabinet. This is INVOLVED and can be very difficult to re-assemble if you have never done it before. Call for service. I hope I helped you!
Oct 02, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a dv448agp dryer - a wonderful machine, as is the matching washer. I am trying to remove the lint trap holder in order to vacuum down into the base. I have taken out about a half dozen screw -...
You will need to disassemble the entire front panel to get access to 2 other screws inside. Remove the top panel first, then the control panel and then remove the front panel.
Jun 26, 2011 | Samsung DV448AGE Gas Dryer
When drying clothes, there is a loud banging noise, almost like if the clasp to overalls is hitting the inside of the dryer. Right now I am drying towels, so there is nothing metal or hard that could be...
Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a banging sound. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks.
Check to see if the drum is supported on wheels or rollers. Sometimes these can wear and require replacement.
Good luck and have a nice day
Jul 03, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Have Kenmore 90 series elec. dryer...will start, but then cuts off and doesn't dry clothes. Trying to clean the lint out of it. We've taken all the screws out of the back, but can't get the back off!...
Hi-I just cleaned out mine. You take off the clamp that holds the exhaust duct from the bottom of the back of the dryer and you will be able to vacuum it out. Then you can remove the kickplate on the front of the dryer by lifting it hard and pull the top of it out. Then you can remove the lint trap holder once inside by unscrewing it, remove it and clean it out(take out the lint filter first). I vacuumed out the inside of the exposed bottom gently cause it was so full lint! Hope this helps!
Jan 23, 2010 | Kenmore Dryers
How do I remove the lint trap holder. I have lint
you have to remove the top then the control pannel then the entire front. are you ready for this?
Jan 08, 2010 | GE Washing Machines
Remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Jan 30, 2009 | Zanussi ZWF1440 Front Load Washer
How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Jan 21, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
F&p dryer issues
Yes, there is a filter inside of that one. You are just emptying a receptical. Unplug the machine, remove the screw inside of where you remove the lint trap. remove that cover and vacuume out the area, you can use a blower to get more out (canned air). The two metal bars below the receptical are sensors, sometimes the back side of these become packed with lint and must be cleaned out as well. If the wires from the sensor comes off one must attach to the bottom bar and the other to the top. NOTE: On mine It is possible to connect the wires to the same bar, at opposite ends, this can cause damage.
Jan 07, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
183 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
