Question about Hitachi 53FDX20B 53" Rear Projection Television
Focus Color is not focused
  • 3 more comments
  • bporter453 Mar 03, 2009
    53FDX20B
    53FDX20B
    53FDX20B
  • Anonymous Mar 16, 2009
    I had the same problem. Now I cannot get the tv to Magic Focus. It is in Static Mode. Can this corrected???
  • gotrosie12 Apr 06, 2009
    dan i can do some soldering help me fix this
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
  • 4,234 Answers
If by not fucuse, you mean that it appears like a 3D picture, then the problem is in the convergence circuit. If you can solder, you can fix this yourself. Please confirm the model number and let me know if you wish to attempt this repair and I will provide additional details and instructions.
Dan
Posted on Mar 02, 2009
Colour code 2006 focus
2000 Ford Focus body color codes. Color Code(s) Color Description M6290A, MK Twilight Blue Metallic M6373A, UA Ebony M6640A, WT Performance White M6720A, TS Silver Frost Metallic
Sep 20, 2016 | 2006 Ford Focus
Will not color focus
Convergence amps need repair. Requires troubleshooting with meters, and soldering with new parts. A more common problem on RPTVs.
May 02, 2010 | Hitachi 57F500 57" Rear Projection...
Jvc av65wp55 out of focus
When you say you changed the focus block, did you adjust each color individually ? Most projection sets are adjusted by covering 2 lens and focusing each one seperately. Try this , it has always worked for me
Sep 04, 2009 | Hitachi 46F510 46" Projection HDTV
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
I have a Nikon D200 camera. It's now 2 years old and I'm having difficulty with the auto focus. The camera focuses but it comes in and out and I have to depress the shutter several times to get it clear....
the auto focus works on the basis of contrast. If you aim your chosen auto focus square at an item that fills that square with only one color or shade of color light a blank wall or a solid blue sky the camera can't focus because it is trying to compare the contrast in order to focus the camera. try to make sure that you choose an item with contrast to aim your auto focus square on like someones eye and part of their cheek so the camera can see somre contrast to evaluate then focus. Obviously you depress your shutter half way to activate the auto focus let the camera do its thing keeping the shutter half way depressed move your field of vision to where you want it then fully depress the shutter to take the picture. the camera relys on seeing some contrast within your autofocus square in order to auto focus
Jan 14, 2009 | Nikon D200 Body Only Digital Camera
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Setting color and focus inside case
The only way to do that is by eye. To Adjust the screen controls the best thing to do is turn them all down then slowly adjust one up until you get retrace lines (arched lines across the tv) then turn it down until the lines re not visible then go about 1/4 turn more, repeat this for the 2 remaining colors, after that its just done to eye for the best color. if you are still having trouble getting the color right you can go in the menu to the video settings and turn the color all the way down then you will have a black and white picture and you can adjust for a perfect black and white picture then turn the color back up in the menu.
As for the focus controls its best done by covering 2 of the tubes so you only have one color on the screen then adjusting to the best looking focus for that color. then repeat this for the other 2 tubes.
If you need more help or clarification please let me know
Tim
Sep 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Color problem
No I haven't found a solution to the problem. However I understand that you have different options of support and some of them requires a payment service. I will try and get some assistance here locally in the area. Thank for the response.
Big12
Apr 05, 2008 | Samsung HCN5527W 55" Rear Projection...
Color Alignment
get a shop manual,it tells how to do the whole convergence process and how to store it to the rom memory to save it.
Mar 15, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
151 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
