Question about Brother Office Equipment & Supplies
How do I set my copier up to scan? I can copy and fax already but I would like to learn how to scan with it.
You didn't include the model number, which makes it very difficult to give any type of instruction, and if you want to scan I would suggest to start by installing the scanning software, and it may be somewhat explanatory after that
Posted on Mar 02, 2009
How should i set my printer
Copy & fax not working?
Does it print & scan?
Mar 20, 2014 | HP Officejet 4500 Wireless All-in-One...
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
I get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 12, 2010 | Brother MFC-9440CN Laser Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Low Ink
I get that when I have just refilled the cartridge, but I usually ignore it and it is still ok for a while; have you checked that you are using draft or normal not best settings?
Jul 29, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer does not power up
None of the leds are flashing or indicating the power.
First Possible solution is change power cable or put the one which is already working Cable. If Its not getting power Check the fuse of Printer. If nothing Works Consult to service center as it seems to be under Warranty before doing any manipulation in the circuit.
Regards
Rafique
Mar 03, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Title misleading: not a printer at all
Wow you are correct there.
This looks to be a tricky use of words, it is called Multi-purpose not multifunction.
Thats extremely interesting but here is the marketing info.
Sorry you were mislead on that one.
Marketing Information The SF-560 laser facsimile is a multi-purpose office solution that combines the power of Samsung technology, with a combination of faxing, copying, and scanning. The stylish and compact SF-560 is easy to set up to immediately tackle your most demanding office needs.
Dec 20, 2007 | Samsung SF-560 All-In-One Laser Printer
Scanner failure
You can copy, but not scan or fax from the flatbed...
You can copy, but not scan or fax from the feeder...
Am I reading this correctly?
Oct 18, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Samsung 3160fn
This is a multifunctional unit: it copies, prints, faxes and scans. There are three green buttons listed as "FAX", "COPY" and "SCAN". You need to press COPY if you want to make copies, since the default setting is FAX. The user's manual contained in the CD will show you how to change the default setting to COPY.
Sep 06, 2007 | Samsung CLX 3160fn All-In-One Printer
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
