Question about Toshiba 57H81 57" Rear Projection Television
42h83 hyperboard mvpu14 problem i had the schematic
I paid for the schematic to do this the right way but the hyperboard schematic in no way matches my part the part was directly behind the AV connections and labeled mvpu14 and needed to be desolderd in 4 points to remove it. after i removed it i desoldered 4 tabs to take off the front top shell i just want a diagram to repair this board or and location to buy a new one for a reasonable price. I would prefer to fix mine since I have all the right tools and many free parts available to me. tex64 @ hotmail. com (without the spaces is my email)
if you want a picture of my board and a copy of my schematic let me know but i'm pretty sure its different and i do have experiance reading these from work but I could be wrong 50h52 65h82 is what the manual says and the company sent me something stating its the same
some guidence please
Joe
  • tex64 Mar 02, 2009
    i had the described wavy horizontal picture but the menu's were very clear so i pulled the hyper board assuming this was the problem and started to change the larger smt capacitors i thing i burned part lz35 and i'm assuming it was an inductor after i changing a few caps some of wich tested bad after i pulled them i went to test the board in the tv and the tv red light comes on but seems to almost not power up so i want to test the board I'm much better at testing boards w/ a schematic to follow. I started by changing the 100uf capacitors and not the 10uf caps since i pulled the wrong ones first. lz35 is located in the top left corner of the board if someone other than that I think i changed all the 100uf 6v and 16 v w/ 50v rated caps and would continue w/ the 3r 10 16v caps next and change them w/ a 10uf cap rated at 16v or above
  • 4,234 Answers
It is common to use similar or the same board in multiple models. 'Can you describe your problem with the set and what you have done thus far to resolve it.
Thanks,
Dan
Posted on Mar 02, 2009
  • ABRsvcs Mar 07, 2009
    Sorry about the delayed response. I did a little research on the initial problem and believe that you may have a power supply problem. Normally when the menu appears OK but standard video has waves it is poor filtering in the power supply. Since the menu is generated directly further down the video processing line, the AC present in the DC power supply lines don't effect it. Look for a bad cap on the 12V or 5V lines.
    Keep me posted.
    Dan
No Video
The VVPU14 hyper module in that unit is a trickey installation because they have their can tabs soldered to the motherboard and next to each of the solder points on the pad are fine wire traces on top and bottom of the board that can easily be broken or over soldered... Check there first, with a fine magnifier. To answer your question, no, there are no resets or anything else you need to do to after the H/M install. Good Luck. Bill
May 29, 2007 | Toshiba 42H83 42" Rear Projection...
The picture is wavey tried everything and i am unable to fix can u help me?
The hypeboard has failed. There are about 12 capacitors (surface mount) that need to be replaced. Unless you have very good soldering skills you shouldn't attempt the repair. The hyperboard will be marked with MVPU14 I believe. It should be located directly behind all your input connections in enclosed in a metal can. It is about 8" inch square module that plugs into the signal board.
The metal housing will need to be unsoldered from the signal board, before you can remove and service the hyperl board.
Feb 19, 2011 | Toshiba 50H82 50" Rear Projection...
My toshiba 42h83 tv is dead. It won't turn on. I
hello if you've never looked inside a tv before then you'll be wasting your time with out the right equipment it will be hard. get quote from an engineer good luck
regards
shaun
Jul 31, 2010 | Toshiba 42H83 42" Rear Projection...
Will a REBUILT PTS PART number pd0637 toshiba hyper, number on part MVPU14 2L20DD work as a hyperboard in a 2002 50h82
Most of these hyperboard are inter changeable.But must Check the 2 STK convergence ICS munbers on the ICS parts have the same printed #---?
Apr 01, 2010 | Toshiba 50H82 50" Rear Projection...
Toshiba 57hx81, has a slight squikgly line near the top of screen, colors seemed faded, not bright. i did the convergence adjustment and adjust the colors/focus with front lower right screws..Is there a...
jhinsincity: you dont need to be here, do you? the problem are the caps on the hyperboard, 10 -16v@ 10uf, rear access right hand green board, model 57hx81, the hyperboard must desoldered from main board. read the post on wavy lines,,
Dec 30, 2009 | Toshiba 57HX81 57" Rear Projection...
I have double vision on my projection tv (toshiba 42H83).
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 11, 2009 | Toshiba 42H83 42" Rear Projection...
Music match8.2
Music match 8.2 will not run in vista {According to ma knowledge} right click properties, compatibility, change it 2 windows service pack 2} some time it will run.....
Jan 30, 2009 | Musicmatch Jukebox Deluxe v8 for PC
Toshiba 50h13 hyperboard
You need part #23148024.  The part is NLA.  I have 1 in stock or you can send yours to PTS electronics 800-844-7871 for rebuild.
Oct 15, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
790 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
