Question about Dell Latitude D600 Notebook
Laptop will not turn on
Press power button, all three lights come on, within 10 seconds laptop turns off. Dell Latitude D-600. I put in new hard drive, still have same problem.
  • nijoma Mar 04, 2009
    I have tried the adapter check and the green light stays on when not plugged into computer and also stays on when plugged into computer. Still have same problem. Anything else I can try. Thanks
  • angel rodriguez Mar 05, 2009
    I HAVE A DELL LATITUDE D600 WITH A SIMILAR PROBLEM. AT FIRST. I WAS HAVING HARD DRIVE FAILURE. I WAS ABLE TO PURCHASE A HARD DRIVE AND INSTALL IT, WHEN I GOT MY PROGRAM INSTALLED AND AFTER SEVERAL MINUTES OF HAVING IT RUN IT STARTED TO FREEZE. AFTER A WHILE OF MESSING WITH IT I FOUND THAT LIGHTLY PRESSING IN THE AREA OF THE PROCESSOR IT WOULD UN-FREEZE OR GIVE ME A GRAY SCREEN WITH WWW.DELL.COM AND THEN IT WOULD SHUT DOWN. WHEN I TRIED TO RESTART IT THE THREE LIGHTS NEXT TO POWER BUTTON WOULD TURN WITH POWER BUTTON LIGHT AND STAY ON FOR 5 SEC. THE MOST AND NOTHING WOULD HAPPEN, NO MONITOR, HARD DRIVE OR FAN. I ALSO APPLIED SOME THERMAL COMPOUND TO THE PROCESSOR HOPING THAT IT WOULD FIX IT, I WAS WRONG. HELP ME PLEASE.
    Scholar:
  • 155 Answers
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Posted on Mar 04, 2009
Want power on . When i push the power button to turn on it does nothing.bought new battery and ac adapter.
Remove the battery and ac adapter. Press power button for 10 seconds then connect the ac adapter. Turn on the system. If this didn't work. You need to go to a service center to test your motherboard.
Jun 26, 2010 | Dell Latitude D610 Notebook
My Dell Latitude will not turn on. When I press the power button it will come on for 5 seconds then go off. Can anyone help ?
Plug in the AC power cord, remove the battery, and try powering up. Anything? Any lights?
Remove power cord, hold in the power button for 30 seconds, then try plugging it in again and powering up without the battery. Any change?
Mar 13, 2010 | Dell Latitude D800 Notebook
Any idea why my Dell D610 is not booting up and showing a dark screen only
You can try the following steps:
1. Unplug the power from the laptop and remove the battery then press the power button of the laptop for 15 seconds
2. Put the battery back in, turn on the laptop without plugging the power to the laptop (If this didn't resolve the issue)
3. Remove the battery and press the power button of the laptop for 15 seconds, after that, plug the power cord and turn on the laptop (if this didn't resolve the issue)
4. Remove the power cord and press the power button of the laptop for 15 seconds, disconnect the Hard drive and turn on the laptop (If this didn't resolve the issue) reconnec the hard drive
5. Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
6. Remove the memory chip, if you have 2 memory chips installed in the 2 memory slots (remove both of them) now test each one of the memory to each slots turning on the laptop. (If this didn't resolve the issue) Put the memory chip back in
7. Reseat the CPU and try to make sure that it's installed properly. Turn on the laptop and test if it's gonna work (If this didn't resolve the issue)
8. Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
9. Disconnect everything and just leave the CPU installed and turn on the laptop.
10. If all else fails, there's a big possibility that the problem may be with the power supply or the motherboard of the laptop.
(Note: you may try to clean your computer if there is a large amount of dust. You may try to remove the CMOS battery)
regards,
sl4x
Feb 13, 2010 | Dell Latitude D600 Notebook
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
Jul 12, 2009 | Dell Latitude D600 Notebook
Dell latitude d820. press power button. no display. hard drive light on for a second and turns off. reseated memory, hooked up to external monitor. nothing.
This may be a really stupid question, but you could have overlooked it... Are you sure the power cable is attached to the laptop correctly? It seems like it's just short of power.
Jun 07, 2009 | Dell Latitude D600 Notebook
Computer will not turn on
Do you hear the hard disk spin up? is there a hard disk boot password configured? can you see a bios screen as it tries to boot? is the light on the power supply lighting up?
May 28, 2009 | Dell Latitude D810 PC Notebook
Dell D600 Wont turn on sometimes.
Reseat the harddrive (take out the screw and slide it in and out)
You can run diagnostics, during startup (just after Dell logo) press F12,then select Boot to Utility partition, or Diagnostic partition.
It may reveal you issue
Hope this helps
Feb 04, 2009 | Dell Latitude D600 Notebook
Dell Latitude cpx
Try to connect and external keyboard to it
with the external monitor.
If the shortcut is in the keypads where most off the beer propably came in contact.
will now be seen if its boots up.
If it boots up with external keyboard the ptoblem is in the beer soaked keyboard.
change or clean the keyboard with isoprophanol
to dissolve moisture and beer.
This is the solution. Please vote!!!
Jul 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude C610 Laptop won't turn on
If the light comes on for three seconds and then go out ,generally means a power distrubution problem . remove the optical drive and memory from the system and try powering it on. If u get the same result , its time to take it to service tech , as your motherboard needs to be checked
Apr 07, 2008 | Dell Latitude C610 Notebook
could it be your hard drive...... and have you tried getting into the bios at all.... if you can get into your bios, change your boot order to cd drive first, install your os disk and try doing a repair . if that dont work try a new hard drive.
Mar 14, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
239 people viewed this question
Alun Cox
