Question about Sony DAV-FX10 System
Sony 5 disc dvd player says c 31 00
- Turn on the DVD player
- Goes to the first disc slot (and it rotates inside to find the right slot)
- Tries to load the DVD inside (as the "stuck" sound starts)
- The sound (the "stuck" sound) comes back
- It sounds like it's trying to process the DVD but nothing's happening, just the sound. Like something's trying to rotate but it can't.
- It displays the error: C 31 00 (not to be mistaken with C 13 00)
  • mccormackts Mar 02, 2009
    yes it is and i have tried restarting like it says but it still doesnt help i'm ready to pull my hair out
  • 4,234 Answers
C31 usually means a motor error. In your case, it sounds more like the loading sequence is not completing. Can you please confirm that the model is the DAV-FX10 system?
Thanks,
Dan
Posted on Mar 02, 2009
  • ABRsvcs Mar 03, 2009
    A restart will not resolve this. EIther the driver IC is defective, a belt is slipping or the unit is out of timing and needs a rebuild. This unit requires service. This is not the type of repair I would suggest for an unexperienced person. Please see a Sony authorized service center.
    Dan
    New Friend:
I have the same problem my model is DAV HDX 465
Posted on Jan 17, 2015
Why does my sony DVP display "No Disc" for every disc; when they play fine in any other player?
Sony tend to have a notorious disc lasers... couple of things you might want to try..
1. clean the lens using a standard Lens cleaning CD.
2. Try playing a CD (music) instead of DVD (if this works...it is likely that the lens is not reading DVD)
N
Jun 02, 2014 | Sony Dvp-C660 Component Dvd Players
Sony DVD player reads NO DISC when there IS a disc
Buy a lens cleaner made by TDK or others. If you can see the picture from the lens cleaner disk The lens is clean but your semiconductor chipset can not read the dvd reflections because it overheated. Use it more often with the lens cleaner, the chipset damaged by humidity may dry up and work perfectly again.
Feb 08, 2012 | Televison & Video
It says loading for a while then cannot read disk...sometimes it will work out of nowhere and then it goes bad again
All the disc u trying to play are original DVD disc and no scratches or dirt layer on it?Laser eye reader could be going bad.Tries websites like Amazon.com,Ebay.com buy a DVD laser eye cleaner and used it might help might not but the the only choices u have.
Aug 26, 2011 | Sony DVPFX970 9 in Portable DVD Player
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
I put the dvd in the slot and the machine takes a very long time loading and the the it says no disc. I also noticed one time it said ps off
Tries it with many other DVD discs,If u have the same result the DVD player Laser eye is having problems and it dying,not reading Data's from the DVD disc anymore.If not,that only DVD disc,that have problems,than check DVD disc for smushes,grims and cracks on the DVD disc itself.If it is the DVD player having problems with it Laser eye and it dying.The DVD player is junk not worth repairing.The DVD player sell really cheap these days,like $40 for a brand new one.
Nov 15, 2010 | RCA DRC247N DVD Player
Sony 5 changer dvd player won't work. displayed code 31
Hi:
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
It sticks during play. the disc is rotating but
open the cover and clean the laser with alcohol....or your dvd disc is damage
Mar 13, 2010 | Sony DVP-NC800H DVD Player
When I put a DVD or CD into my player (which is a 5-Disc), it makes a grinding/high-pitched whine and will not play the disc. It just tries to go to the next disc. I tried putting a lens cleaning disc in...
i think you have a defective lens there's an adjustment right under the lens which would require a precision screw try to adjust it by turning it a little at a time and check if it reads after every turn. for dvd players there are two adjustments and one for cd players.if this doesn't solve your problem then you have to replace the lens of your player
Oct 15, 2008 | Televison & Video
DVD player isn't showing anything
do you hear movement inside like disc rotating, if so then the switch that closest lid is damaged. This is when you fold dvd down it hits this switch to turn monitor off. It could be damaged. If there is no noise or movement then power supply has damaged or batt dead and no power goes to it from power cord.
Aug 21, 2007 | Mintek MDP-1760 Portable DVD Player
Sony DAV-FX10 System Logo
2,384 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
