Question about Acer AL1916W 19" LCD Monitor
My screen turn a bluish tint - Acer AL1916W 19" LCD Monitor
Have you tried an on line image correction ?
http://www.lagom.nl/lcd-test/
very complicated but good.
Posted on Mar 03, 2009
KDF-E50A10 - hard to see details during dark scenes and a dark bluish tint can be seen in background. When tv is turned off the screen goes black but has bluish tint toward the edges before it all goes...
Hate to tell you this but it sounds like your picture module is going bad. The bluish tint tells me it is leaking to the outside. Some problems with the LCD picture module can be fixed but I never had to fix one. Might check out some videos on repairing LCD picture tubes on YouTube.
Gillight
Dec 03, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
I have a five-year old Amtrol water system tank, model #CH4202. For some reason, despite regular changes of my well filter, my water has suddenly taken on a bluish tone. Coincidentally (?), it's the...
This is not related to the well tank. A bluish tint to the water is generally related to the PH and copper corrosion of plumbing. Electrolysis caused from degradation of dissimilar metals and softened water can cause this to occur also. It is rare for the PH of water to change drastically but the water chemistry can change, hardness, iron, H2S etc. I have seen Tannins in water impart a bluish tint also when they are present in very slight amounts. Have the water tested and check for any corrosion of plumbing in the home.
RJ
May 21, 2011 | Plumbing
Monitor has bluish tint
You should check to make sure the cable is tight at both ends (back of the computer and back of the screen). If it is, and you've already replaced the monitor, it's probably the video card in the computer. If your computer is still on warranty, I would suggest contacting the manufacturer or the retailer where you purchased it. If not, it looks like you'll need a "PCI-Express x-16" graphics card, which you should have professionally installed.
Jan 16, 2010 | Gateway GT4022 PC Desktop
BLUE TINT ON MY SCREEN
Philips tv's have always had this problem. Between the picture tube and focus lens there is a layer of coolant fluid. The coolant fluid, over time, will break down and turn a brownish cloudy color and it usually starts with the blue. Something to do with the color frequency. Have a good repair shop check it out and if the fluid is the problem have them change all the fluid in all 3 picture tubes (there is a red, green and blue tube). Don't feel bad, like I said all the philips projo's had this problem. Thanks
Oct 29, 2009 | Televison & Video
Same exact problem
The screen is on it's way out I'm sorry to say. The way you can verify this is to hook the screen up to another computer and check to see if the tint is still there. If it is the phosphors in the monitor have died out and it needs to be replaced. Is it possible that it's still under warranty?
Jun 24, 2009 | X2Gen MG19MY 19" LCD Monitor
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Sony Wega 50" DLP bluish tint
the issue is the optical block. replace the optical block
Jan 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Background has a bluish tint instead of white
the lens , glass inside your scanner is dirty with dust you need to clean this up and calibrate once again cheers
Nov 26, 2008 | Canon CanoScan 9950F Flatbed Scanner
Acer AL1916W 19" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
