Question about Logitech Harmony 880 Universal Remote Control
880 universal remote volume button broke. little rubber botton on inside that pushes the volume button on inside broken.face plate cracked and arrow button on left right underneath face broken and missing grand daughter dropped it on tile floor. works fine if not for volume button broke. wanted to get it repaired or a refurbished one. i was told they would deal if i sent in mine.
  • rweyer1598 Mar 02, 2009
    how do i fix the volumne button
  • 59 Answers
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Posted on Jun 20, 2009
Why when I push the mute button there is no response?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts.
Sep 14, 2014 | Universal Remote Control MX-880
Remot control working but not properly
Option 1: Purchase replacement remote
Option 2: Purchase a universal remote
Option3: Like most remotes they can be disassembled and the board and rubber pads cleaned with de-natured alcohol and reassembled. This may work but is tedious. Unless batteries have leaked in the remote. Then replacement is your only recourse.
Mar 15, 2014 | Televison & Video
Casio Exilim EX-P505 the left arrow key doesn't work. is it setting or broken? what should i do?
Most likely the arrow key switch is broken or the contacts are corroded. If it's a snap-button switch, it needs to be replaced. If this is bad, I recommend replacing the others also. If it's a conductive rubber button (like most TV remote controls), the conductive patch on the inside is worn and needs to be repainted with carbon/silver conductive paint. A miniature snap-button switch is generally less than a dollar from Mouser Electronics - soldering skills are required for replacement. Conductive paint for rubber button switches is $10.45 for a 1 gram tube. It has a very limited shelf life once it's opened, so use up the rest on the other camera buttons, and the power, channel and volume buttons on your favorite TV remote control (if you can get it apart without breaking the case)
Cameras are typically difficult to take apart for repair. You'll have to consider the value of the camera versus the effort to get to the control buttons. The electronics inside are sensitive to static electricity damage, so you should work on an anti-static mat and use an anti-static wristband with it..
Nov 14, 2017 | Casio Exilim Pro EX-P505 Digital Camera
My four year old was messing witht he bottons on the front of my Apex AT2702 television set, and not all it shows is a blue screen with a key symbol in the bottom left hand corner.
There are 7 buttons with its front panel including power ON/OFF switch button.They are; From left to right:- Video, Menu, Volume(-ve), Volume(+ve), Channel(-ve) and Channel(+ve). If these buttons are not there, it will be difficult to operate this set without a remote control. If you haven't the remote contro with you now, buy one universal remote control. The universal remote control suited for this set is COMCAST ON DEMAND CUSTOM-3 UNIVERSAL REMOTE control. The setup codes are:-
0748, 0765, 0767
Jul 11, 2011 | Apex Digital Televison & Video
I cant push my power botten because it is pushed in
Try removing the face plate and pressing the button from underneath where the power button is. It is possible that the piece on the faceplate that presses the "actual" button has broken off. The face plate is removable.
See the link here for photos:
Mar 14, 2011 | Microsoft Xbox 360 Console
When I go to the guide grid om my Directv right arrow doesn't
Found instructions in another post for removing the back plate. Trying to clean contacts and buttons to make it work.
Sep 11, 2009 | Logitech Harmony 880 LCD Remote Control
The volume up button is not working. All buttons are working fine. It is just the volume up button that has stopped working.
If you can manage to open it, just clean the rubber pad, slightly rub with cotton moisten with alcohol
Aug 17, 2009 | Logitech Harmony 880 LCD Remote Control
just hit the main menu botton twice it will automaticly play all for you.
Jun 20, 2009 | GE JASRM24912 Remote Control
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
May 28, 2009 | Kenwood VR-6070 Receiver
Universal remote wont work with this TV
Questions: Who is "Sansui", the digital box ? or the TV? Is the "digital box=remote control"? turn on what you want to control.
Face the RC face down or away from TV,or whatever you want to control. Usually:: push & hold TV & SEARCH button until light blinks, two, three times? FACE THE TV and put the code for the [TV=Sansui ?] You said #189 try 0189 [zero,one,eight,nine]
2nd) TV power ON!,....HOLD down (and if you have a SEARCH) button and the tv power button on RC, two or three blinks, push up arrow once, press power button for TV on RC, nothing!, continue...up arrow, power button. when the TV turns off, you have found the code,. YOU MAY HAVE TO DO THIS 50-150 TIMES because the RC is looking through EVERY code!
Apr 26, 2008 | Sansui CDVD1300W 13 in. TV/DVD Combo
Televison & Video Logo
767 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
